Question about Car Audio & Video
The battery warning light comes on after 10-15 minutes of driving. After stopping for a whle & then restarting, all is well for another 10-15 mins, then warning light comes on again. Alternator has been replaced. Renault Megane diesel
  • Car Audio & ... Master
  • 4,869 Answers
Are you sure that the fan belt is tight enough and not slipping?
Posted on Apr 04, 2011
Diesel engine runs then stops then runs stops every few minutes
Mate I use to drive a freightliner and it cut out on me one day, I eventually got it started but cut out again after about 5 minutes, I rang a mechanic to come out and he found a heat sensor wire came off the radiator and that caused the motor to cut out... Hope I haven't wasted your time.......
Mar 09, 2016 | 2007 Chrysler Grand Voyager
2010 venza stalls while driving
ever do the 60k mile tune up, stated in the glove box , operators guide?
Feb 09, 2014 | 2010 Toyota Venza
2003 Sunfire automatic 245000km runs well, engine stops while driving, clicking under the dash, then restarts , runs fine until next time
with the details that you have provided, it sounds like it may be either a ground, or ignition relay, but I've also encountered the same problem being the starter wire to the starter. The reason I think that is because of your dash lights coming back on .If you have use of a voltmeter you can test and see how much power is actually going to the starter An ignition relay could do the same, but usually won't interrupt the engine after it's running.
Jan 01, 2013 | 2003 Pontiac Sunfire
Peugeot Expert Van- Erratic temp guage & 'STOP' dashwarning light
temperature sender unit top of engine cylinder head make sure its okay
and make sure wire going to it is not grounding
if it grounds or earths it will send the gauge up and down
Feb 22, 2010 | Peugeot Liberte Cars & Trucks
AUTO warning light comes on - 2004 Renault Scenic Petrol Auto
Auto warning light comes on but goes off when car stopped and restarted. Temp also goes higher
Aug 17, 2009 | 2005 Renault R5
Air Suspension system Problem 1990 Lincoln Towncar
Unplugging the Connector will cause the Check Suspension light to come on as its listed as a fault as it cant run.
But with it unplugged the compressor shouldnt been able to start. If you want to kill the compressor pull its relay from the engine bay. located above the battery.
But i'd suggest correcting the fault as if those bags do pop your going to end up being grounded. as the rear will drop a fair bit!
Jul 16, 2009 | 1990 Lincoln Town Car
Message system reads "engine system maintenance required"
WHAT HAPPENED IS WHEN YOU SHUT DOWN AND RESTARTED YOU (RESET THE ENGINE MANAGEMENT COMPUTER) AND THE SERVICE LIGHT SHOULD GO OUT AFTER 10 MINUTES OF DRIVING
Mar 16, 2009 | 2003 Volvo S40
2005 Saturn Ion problem starting
Maybe 5 or 6 years , depends . Battery in my chevy cavalier lasted 6 yr's .
Mar 19, 2017 | 2005 Saturn ION
1999 CLK 320 occasionally stops while driving
Have a problem with my A/C. was leaking not holding proper charge. When that happens the Eoconomy light comes on and can't turn it off until system is prpoerly charged. Is their a reset on this system to turn that off once the proplem is corrected?
Nov 19, 2008 | 1999 Mercedes-Benz CLK
Car Audio & Video Logo
93 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
