Question about Dell Computers & Internet
I have dell vostro 1000 labtop an the screen is just black wen i turn it on there is no light but i can here the sound so i no it is on i just can see anything can anyone help. pleasurezone74@yahoo.com
  • Dell Master
  • 6,771 Answers
Hook a spare monitor to the video output on the back of the laptop, if it works! it rules out the video graphics card on the motherboard, which means the problem is the inverter board "more than likely" or the back light behind the screen has failed. The inverter board is located under the LCD screen and can be replaced. The back light is built into the display and most technicians will opt to replace the LCD, an expensive venture.
Posted on Apr 04, 2011
  • 221 Answers
It sounds like the laptop is set to use an external monitor.
Check the function keys for an icon that looks somewhat like a monitor
turn the unit on and wait until it is started
then press and hold the function (fn) key
While holding the fn key press the function key with the icon (it is a stepping control)
this should, after one or two presses bring up your on-board screen.
Good luck, I hope this helps
I updated the bios on the dell vostro 1000 and it wouldn't start. The power light stays on and you can hear the fan. This is followed by a long beep and 2 short beeps while the screen stays black.
Hi alkeith...
Turn on the computer while tapping F8, this will take you into the Safe Mode.
While your in the Safe Mode you can do a system restore.
Restore your computer back to an earlier time when it was working before you installed the bios change.
Left click on Start>All Programs>Accessories>System Tools>System Restore.
This should solve your problem.
Please take time to rate me
Aug 05, 2011 | Dell Vostro 1000 Laptop Computer (AMD...
I have a dell vostro 1000 laptop when i turn on the computer the screen just stay black no light on the screen it just stay black but i can hear the sound that it was on i just could not seen any thing.
Have you accidentally turned off your lcd? Some laptops have a shortcut key for turning off the lcd, usually the FN key combined with the function keys (F1 to F12). If you have a spare monitor and your laptop has a VGA output, try connecting your laptop to another monitor. If it shows up, then you may have a faulty lcd.
Apr 04, 2011 | Computers & Internet
I have a dell vostro 1000 and when, i turned it on it seems to be runnig, but gives a fully black screen...
ok.Tell me more about this problem.
Have you tried to connect an external monitor to the laptop?
Nov 23, 2010 | Dell Vostro 1000 Laptop
Dell vostro 1000 laptop power problem.when you plug in the power supply before its plugged into the computer the green lite is onwhen you plug the adapter into the laptop the light goes out and there...
older vostros usually have a broken dc jack right where the power connector plugs in. otherwise try another ac adapter and also try removing and replacing the battery underneath.
Jan 30, 2018 | Dell Vostro 1000 Laptop
My dell vostro 1000 won't turn on the green light
Try to do this: (Draining flea power)
1. Unplug the ac adapter (if connected)
2. Remove the battery
3. Press and hold the power button for at least 10sec.
4. Put back the battery and ac adapter
5. Turn it on
- check if you can now boot to windows, if not there could be a hardware problem and next step would be running some diagnostic test on the computer for hardware problem.
Dec 07, 2009 | Dell Vostro 1000 Laptop
Vostro 1000 black screen an i can hear it running, but can see..
A blank screen with evidence that the motherboard is working (the Capital "A" green light is probably the CAPS LOCK on your computer's keyboard) initially points to an output or video problem. One quick way to see if that is the case is if you connect the computer to an alternate screen. Do so with the "sick" computer powered off at first. After being sure the connections are snug, be sure that the test monitor is powered on and then turn on your "sick" Dell. If the test monitor runs as your laptop's monitor ran when it was healthy then you know there is a cabling/backlight/inverter/screen problem. Some of these can be solved very easily, some more expensively as replacement may be required.
On some laptops pressing down firmly on the keyboard may seat a screen cable to motherboard connection. That often works on IBM Thinkpads with screens that fade in and out due to a poorly seated screen cable connection to the motherboard.
So let's see how the test to a known working screen goes.
Apr 18, 2009 | Dell Vostro 1000 Notebook
Update Dell Vostro 1000 BIOS now wont turn on, nothing on display
You may be in for some trouble, a failed bios update isn't always an easy fix. if you can find the cmos battery try to remove that for a few seconds. you will also need a disk version of the bios, download that from dell on another computer and copy it to floppy or cd and see if you can boot to that and reinstall the bios.
when you press the power button what happens, does it light up and run the fan? Nothing appears on the screen?
Dec 29, 2008 | Dell Vostro 1000 Mobile AMD Sempron...
Computers & Internet Logo
191 people viewed this question
Alun Cox
