What are the torque specs for the head off a 1999 toro workman,,,model# 07200....mitsibishi engine..3 cyl...xmtxs.6602ra....
  • 25 Answers
SOURCE: 87 samurai bolt torque specs for engine
The haynes book is not recommended since there are numerous mistakes and they still will not update. One of the biggest is the firing order.
The factory service manual is the only way to go.
Head bolts - 46 - 50.5 lbs (there is an order sequence for the bolts)
Intake & exhuast manifolds- 13.5 - 20 lbs
Flywheel - 41.5 - 47 lbs
Clutch cover - 13.5 - 20 lbs
Posted on Mar 17, 2009
chuck943
  • 783 Answers
SOURCE: Head bolt torque specs needed for 96 tbird 3.8
Head bolts are torque to yeild so you MUST use new bolts.
Tighten cylinder head retaining bolts in numerical sequence in three steps as follows:
  1. 20 Nm (15 lb-ft).
  1. 40 Nm (30 lb-ft).
  1. 50 Nm (37 lb-ft)
Loosen retaining bolts one at a time two to three revolutions and retighten as follows:
Long bolts:
  • Tighten to 40-50 Nm (30-37 lb-ft).
  • Rotate an additional 175-185 degrees.
  • Go to next bolt in sequence.
Short Bolts:
  • Tighten to 20-30 Nm (15-22 lb-ft).
Here is a pic of the sequence
http://i253.photobucket.com/albums/hh43/chuck943/Headboltsequence38L.gif
Posted on Mar 19, 2009
SOURCE: need torque specs for a 85 s10 chevy with a 2.5 engine?
here you go!
Posted on Jun 21, 2009
inspectmycar
  • 233 Answers
SOURCE: 94 mazda B3000 3.0L cylinder head torque specs
Step 1 torque to 59 ft pounds
2. Loosen one full turn
3. 37 ft pounds
4. 68 ft pounds
Use torque sequence below
Posted on Sep 17, 2009
ZJLimited
  • 17970 Answers
SOURCE: need the head bolt torque specs for a 1999 grand
Fig. Cylinder head bolt tightening sequence-3.1L engines & 2001-04 3.4L engines
Fig. Cylinder head bolt tightening sequence-2005 3.4L engines
Hope this help (remember rated and comment this).
Posted on Mar 30, 2010
Cylinder head to engine block torque sequence and ft lbs
    images for Cylinder head to engine block torque and ...
    More images for Cylinder head to engine block torque and sequence
    Small Block Chevrolet V8 Engine Specs ' Torque Specs ...
    boxwrench.net/specs/chevy_sb.htm
    their specs. Click Here! 3/8 Connecting Rod Bolt, Engine Oil, 45 ft-lbs. 11/32 Connecting Rod Bolt, Engine Oil, 35 ft-lbs. Cylinder Heads. Engine oil. (blind hole).
    [PDF]
Nov 29, 2015 | Cars & Trucks
Where can I buy Toro Workman 3200 carburetor?
go to Toro commercial service center. They are expencsive. I have the same set up as your workman for fertilizing and spraying. Where are you located? I am in Holland,, Michigan
Dec 12, 2013 | Toro Workman 3200
I AM DOING THE HEAD GASKET ON 1999 SAAB 95 4 CYL I NEED THE TORQUE SPEC ON CYL. HEAD
Torque spec
Step 1- 44 Ft.Lbs.
Step 2- 59 Ft.Lbs.
Step 3- Tighten bolts an additional 90 degrees.
Here the head bolt's tightening sequence.
Nov 11, 2010 | Saab 9 5 Cars & Trucks
Head bolt torques spec
3.8L V6
cylinder head bolt torque
step 1 37 ft lbs.
step 2 an additional 130 degrees
step 3 4 center bolts an additional 30 degrees
Jul 07, 2010 | 1999 Buick LeSabre
Need the head bolt torque specs for a 1999 grand am - i am trying to replace the heads on 1999 grand am with 3.4 engine
Mar 30, 2010 | 1999 Pontiac Grand Am GT
Always use new head bolts.
1)tighten to 40ft/lbs
2)back off 1/2 turn
3)tighten back to 40ft/lbs
4)tighten an additional 90 degrees
5)tighten an additional 90 degrees.
Aug 16, 2009 | 1999 Ford Escort
I need head bolt specs for a 1992 bmw 325 i
I presume you want torque setting. If so here is
BMW 6 cylinder engine
According to my manual as follows:
cyl head to engine block
stage 1 30nm(22ft-lb)
stage 2 + 90 degrees
stage 3 + 90 degrees
cyl head to lower timing chain cover 10nm (89in - lb)
Loosening sequence is from oustside to inside crossover and tightning from inside to outside.
Jun 16, 2009 | 1992 BMW 3 Series
Need to the torque specs for a 1999 Dodge Durango
Head Torque sequence Step 1: torque to 50 Ft/Lbs Step 2: torque to 105 Ft/Lbs recheck final torque in sequence.
Torque intake manifold: Step 1: 12 inch/Lbs, (hand tight) Step 2: 72 inch/Lbs, (6) Ft/Lbs Step 3: 12 Ft/Lbs
torque intake plenum: Step 1: 24 inch/lb (hand tight) Step 2: 48 inch/lb (4) Ft/Lbs Step 3: 84 inch/lb (7) Ft/Lbs (To torque bolts, start in center using crisscross pattern)
Apr 07, 2009 | 1999 Dodge Durango
Cylinder head torque specs
Cyl. Head Bolts torque
200in.lbs
16.5ft.lbs
22.5Nm
Mar 26, 2009 | Craftsman Garden
Televison & Video Logo
85 people viewed this question
Top Televison & Video Experts
Electro Med Services...
