Question about Samsung CLP-510 Laser Printer
Engine fuser error
Ive tried unpluging the cord and replacing but the problem seems to persist.
What is the engine fuser? and is this a major and common problem?
Cheers
  • Anonymous Sep 06, 2008
    err msg every morning : Engine Fuser Error
    Master:
  • 638 Answers
Fuser is the behind the heating element of the printer. made of thin glass.its very costly to replace.
Posted on Aug 16, 2008
50.0 fuser error
SOLUTION: Follow the steps listed below:
  1. Turn the printer off and unplug it for 30 minutes; then turn the power back on.
  2. Try a different power cord. DO NOT use extension cords to plug the printer in.
  3. Remove the surge protector or UPS/CVT device and connect the printer directly to a power source.
  4. Try a different electrical circuit. There could be an issue with the line voltage going into the printer from the power source.
  5. Turn the printer off and unplug it. Let it sit for 30 minutes to let the fuser cool off. Carefully remove the fuser; IT MAY STILL BE HOT USE CAUTION. Examine the fuser, if any damage is apparent the fuser may need to be replaced. If no damage is noted reinstall the fuser, plug the printer back in and power it up.
For More info Source... Hp Error Code 50 Service Errors 50 Fuser Printer Repair
Thanks,
HP Printer Support
Jun 26, 2014 | HP LaserJet Pro P1102
Dell 1600n low heat error
Remove the fuser lamp and put it back in place, it is not heating properly.
Apr 02, 2008 | Dell 1600n All-In-One Laser Printer
Received fuser error u4-1. Replaced fuser, and still get same error
Try to hard reset your printer. To do this, unplug the cord at the rear of the printer while still powered on. Then remove it the plug from the socket. Let it sit for a few minutes. Then, plug the power cord and then reattach the cord at the back. The printer should power on itself, if not just power it on manually by pressing the power button.
Doing the hard reset should clear off any error messages from your printer's memory.
Feb 06, 2013 | Xerox Phaser 5500/DN Laser Printer
HOME SENSOR EROR
Deve Home Sensor Error
There is a problem in the fuser unit.
Unplug the power cord and plug it back in. If the problem persists, Replace to the Main board.
Aug 30, 2011 | Samsung CLX 3160fn All-In-One Printer
What does low heat error mean?
Pls do the following
[Low Heat Error]
unit.
in. If the problem persists, please
contact a service representative.
Thank you.........
Jul 26, 2011 | Samsung SF-560 All-In-One Laser Printer
50.2 fuser error on HP printer 2840. Received this error, change the toner Q3964A for new one but still having same error code. Tried turning off and waiting 10 minutes and trying again but still same...
  1. Turn off the device, and then disconnect the power cord.
  2. Remove the fuser and then wait at least 20 minutes. To do so, complete the following step
  3. Turn off the device, and then disconnect the power cable.
  4. Rotate the locks on the fuser to the unlocked position, On the rear of the printer.
Grasp the fuser handle and pull the fuser assembly from the device, .
CAUTION: The parts on the internal surface of the fuser are very hot. To avoid being burned, do not touch those parts.
Using both hands, slowly and steadily remove any print media from inside the device. Then, carefully reinsert the fuser and secure the locks.
  1. Reconnect the power cable, and then turn on the device.
  2. Wait for the device to initialize.
  3. If the error persists, replace the fuser assembly.
Jul 07, 2011 | HP LaserJet 2840 Printer
Open heat error in scx4100 printer
usually, Open Heat Error = There is a problem in the fuser unit.
Unplug the power cord and plug it back in. If the problem persists, go here and foolow that guide for 4500. it is basically the same.
Dec 22, 2010 | Samsung SCX-4100 All-In-One Laser Printer
User error
FUSER ERROR:
. Turn the printer off, wait 10 minutes, and then turn the printer on. 2. If the message persists, reseat the fuser. If that does not work, replace the fuser. To check the fuser, turn the printer off and remove the fuser. Measure the resistance between the fuser connectors. If it is not within the proper range, replace the fuser. If there is not continuity between the fuser connectors neutral and hot with the fuser removed, replace the fuser. If the problem is not related to the fuser, replace the engine controller board.
Mar 27, 2009 | HP Color LaserJet 5550hdn Printer
Xerox Workcentre M201 says open heat error
Fuser Error, Open Heat
Error, Heating Error and
Overheat
fuser unit.
problem still persists, please call for service.
Dec 09, 2008 | Xerox WorkCentre M20i All-In-One Laser...
Open Heat Error
the thermal switch on the fuser are damaged. my problem is that I don't know the temperature of activation to this. And do not buy a replacement under this conditions. somebody help me.
Sep 27, 2006 | Dell 1600n All-In-One Laser Printer
Samsung CLP-510 Laser Printer Logo
79 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
