Question about TruTech PLV16320 Television
I have a PLV-16320VM television that just stopped working .I dont understand why? I unplugged and plugged back in and still nothing ,not even a power light.please helpf you can. thanks.
    Champion:
  • 367 Answers
Are you still having problems,Please let me know.Thank You very much!
Tyler
Posted on Apr 07, 2011
Amp keeps blowing fuses
Blowing fuses, was caused by many thing.
Short of rectifier,resistor,elco,tube heater,tube pin, and also trafo itself (primary or secondary winding). It must check step by step.
CAUTION :
THIS IS HIGH VOLTAGE AREA.
RISK OF ELECTRIC SHOCK THAT CAN KILL.
DON'T DO THIS IF YOU ARE NOT TECHNICIAN OR NOT FAMILIAR WITH VACUM TUBE CIRCUIT. THE CIRCUIT MAY STILL CONTAINS ELECTRIC SHOCK EVEN IF IF THE AMP IS NOT POWER PLUGGED.
The simple steps (see picture) are:
  1. Disconnect all connection from secondary of power trafo (PLV,PDCH,PACH and PHV).
    Power ON the amp. If fuse is not blowing,trafo is good.
  2. Power OFF the amp. Unplug the cord.
    Connect PLV1-PLV2-PLV3 (this are Bias voltage,+/-15VDC and Backlight PCB voltage) to power trafo.Power ON the amp. If fuse is not blowing,PLV circuit is good.If fuse blowing,there are parts is damage (dioda,elco,7815/7915,resistor) in this PLV circuit.
  3. If step 2 is good,go to next step.
    With PLV circuit stay connected,connect PDCH 1-2 and PACH 1-2 to power trafo. Power ON the amp.
    If fuse is not blowing,PDCH and PACH circuit is good and all tubes heater/filaments are lights after a few seconds.
    If fuse blowing,there are parts is damage (dioda,elco,tube heater pins) in this PDCH/PACH circuit.
  4. If step 3 is good,go to next step.
    With PLV,PDCH,PACH circuit stay connected,connect PHV 1-2 to power trafo.
    Power ON the amp. CAUTION: HIGH VOLTAGE AREA is ON.
    If fuse is not blowing,PHV circuit is good.
    If fuse blowing,there are parts is damage (dioda,elco,tube pins) in this PHV circuit.
Notes:
  • Steps had to be done sequentially from 1 to 4, not upside down.
  • If tube/heater pin is short,it can't be repair. The tube must be replacing.
  • PDCH circuit is voltage for V1-2-3-4 heater/filaments.
  • PACH circuit is voltage for V5-6-7 heater/filaments.
  • Always replace fuse with same type.
Oct 02, 2015 | Peavey 6505 Plus 120W Guitar Amp Head
My plv-z4 projector makes a crackling noise when i plug it in
Hello
download its user manual to understand about these trouble. If the cooling fan's leaf has any break, this sound will be there. Click here to down load its user manual.
Feb 24, 2012 | Sanyo PLV-Z4 Multimedia Projectors
My television continues to display the phrase "DIGITAL CHANNEL SIGNAL STRENGTH IS LOW" I ahve called the cable company several times and had this checked to see if it was maybe a defective box...
Go to Menu - then channel - then memory channel - let the tv reconfigure the channels. You might need to unplug tv (the light to tv might still be on - press the on button to release the juice). Then plug tv back in. I did this and it worked.
Nov 21, 2010 | Sansui DTV2760 27" TV
I have a memorex MLT 3221 and the up and down channel changing buttons on the tv and remote stopped working and i dont know why can anyone help me with this problem ?
I can suggest you to use fresh batteries for the remote, and unplug the TV for a while (30 minutes) then plug it back in. Perhaps, the panel where those buttons go might not be making a good contact. It is my understanding that this TV has a 90 day warranty.
You can reach Memorex at 1-877-363-6673.
Aug 01, 2010 | Memorex MLT3221 32 in. LCD TV
My ps3 doest display anything nor makes any sounds please help
Just a gander, but your PS3 may be set for HD output thus not displaying on your non HD television, your best bet in this case is to find an HD television, friend, coworker, etc, connect to it and switch the settings back to regular. Also if I understand correctly leaving the ps3 completely unplugged for 72 hours may also reset all settings. Good luck!
Jul 03, 2009 | Sony Playstation 3 (PS3) Console
NO Picture! NO POWER! NO NOTHING! ILO 27' LCD
The way to resolve the problem would be by replacing or repairing the power supply. If the TV does not power ON, needs to be unplug to make it work; those are symptoms of a dying or defective power supply.
I repair these power supplies, if you need further assistance write to jah2mil@hotmail.com
Feb 17, 2009 | iLO 2600 Television
Sanyo Television PLV-55WHD1
i heard same popping sound and my power button flashed red and will not turn back on.?
Sep 15, 2008 | Sanyo PLV-55WM1 55" HDTV-Ready LCD TV
Keeps resetting back to dynamic
I understand that you dont want to run your LCD in 'Dynamic' mode all the time! I don't! Its a great way to preserve the life of the backlight... All I can suggest is unplugging the Set from the wall outlet for 10 seconds, then plug it back in-- hopefully this resets the unit -- otherwise this is a defect and hopefully you have a warranty that is still valid!
Good Luck!
Aug 16, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
NO PICTURE ON SCREEN
My picture went out but I was still able to here the audio. I unplugged my tv and plugged it back in and it worked. If this problem is similar to yours and you have not tried unplugging and replugging give it a shot.
Jan 11, 2008 | TruTech PLV16190 Television
TruTech PLV16320 Television Logo
48 people viewed this question
Top TruTech Televison & Video Experts
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
