Question about GE Refrigerators
FAN IN DEFROST SYSTEM NOT WORKING FOR MODEL ZFSB23DRB GE REFRIGERATOR SS SIDE BY SIDE. FEFRIGERATION BOX NOT WORKING
SOURCE: GE Side-By-Side Refrigerator Model GSS 23QSTA SS
I have a GE refrigerator and just had a technichian repair it. My problem was with the condesor relay and also the ice dispensor controls would not work. The tecnician replaced the main electical board on back of fridge and said that GE extended the factory waranty on this part. He was surprised that I wasn't having any cooling issues. He said that when most boards go bad there is a cooling problem.
Posted on Jun 19, 2007
  • 1314 Answers
SOURCE: Auto defrost not working
a manual defrost will help in the sense that it will healp save your food now if you dont mind spending a little cash may i suggest you go buy a eurika 350 hand held steamer its great for defrosting and about 1000 other thuings around your house you canget it at lowes places like that after defrosting the unit will freeze again in about two to three days depending on how many times you open your door reply to this thered with the appox age of your unit and i can better advise from there some times as in the case of a stuck theroma stat if seen it fix them but i wouldnt count on it hold my rating tii we are done
Posted on Jan 19, 2008
  • 184 Answers
SOURCE: GE side by side refrigerator defrost problem
CHECK THE DEFROST HEATER FOR CONTINUITY. IF IT IS O.K. CHECK THE ELECTRONIC CONTROL FOR A FAULTY SOLDER CONNECTION ON THE DEFROST RELAY. THE ELECTRONIC BOARD SHOULD BE LOCATED ON THE BACK WALL OF THE REFIGERATOR BEHIND AN ACCESS PANEL.
Posted on Apr 10, 2008
SOURCE: GE side by side - upper freezer warming once a week then freezing
Had the same problem. Bottom of freezer was about the right temp but the upper part was way too warm. Fridge side was fine. Ice maker stopped making ice - it wasn't broken, but it won't run through its cycle if the temp is too high. Cubes already in storage hopper melted and water refroze as it ran to lower, colder part of fridge. Problem: Fan controller for freezer compartment was faulty. The fan itself was fine. Fix: GE replaced the main circuit board that controls everything on this model, including the freezer compartment fan. Once that was done, temp returned to normal, ice maker is happy again. The board had undergone several revisions from the factory installed one (could tell this by comparing the part number on the old and new boards - they increment it when they revise it.) Bad news: the part/labor were expensive and of course failed after the warranty ran out. Good news: the board is now guaranteed for 5 yrs. (Why wouldn't the factory-installed board ALSO be good for five years instead of just one? It's not like the replacement boards are made better.) Labor is covered only for 90 days though so it won't be free if they have to come back after that.
Posted on Jun 13, 2009
MNTECH
  • 1543 Answers
SOURCE: GE Profile Fridge Model No. PSC25MSWA SS not making ice
Check to see if there is any obstruction (object of any kind) in the ice cube mold area. If nothing found, you will have to replace the icemaker, as individual repair parts are not available.
Posted on Aug 04, 2009
Where Is The Defrost Timer Located On My Ge Refrigerator Model GSL25JFTABS
Where is the defrost timer in my General Electric freezer model number PSS26NSTB SS
Feb 28, 2013 | General Electric GSS22JET Side by Side...
I HAVEA GE SIDE BY SIDE, THE FRIDGE AND THE FREEZER ARE ONLY COLD IN THE BOTTOM HALF, FROST BUILD UP IN THE FREEZER, BOTTOM HALF,
HI you have a bad defrost heater, located in the freezer behind the rear panel at the bottom, the part cost around $50-70.00.
Sean
Mar 28, 2011 | GE Refrigerators
The temp has gone way down in both sides of our refrigerator. First the freezer went down then the frig side went down later today. It is a GE model# GSH25SGPA SS The power is on and we saw fan working but...
That is most likey because the defrost heater and defrost thermostat need replaced. Look into rear of freezer and look over the rear wall if frost is building up then the problem is it has a huge block of ice behind that rear wall. I will get you part numbers and return, Thanks, Sea Breeze
Mar 18, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I have GSS25SGP SS with no condenser fan operation. Components very hot, but unit is still cooling. Is this fan shut down a part of the defrost cycle or a fan motor failure? aerolog2
The fan has to run when the compressor is running. Usually does not run during defrost cycle. Could be bad fan motor, or the fan has lost power.
Jan 02, 2010 | GE GSS25SGPSS Side by Side Refrigerator
GE Model PSC23SGRC SS Serial #RH418861. Refrigerator make a howling noise Dave eci.david@gmail.com
I suggest a defrost with doors open over night, what often happens with this model is that you get an ice build up near the fan which causes an extremly loud noise, very common problem.
Sep 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer is freezes it self up and a giant block of ice froms but refrigerator is warm
Hi: your model number dosn't get a match on a search. Did you check the defrost heater? I hope this helps Jeff,
Jun 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
hdrubinpe Even if GE had denied the excessive noise issue, they definitely can not denied wrong temperature. Milk must stay in good condition till the expiration date on a bottle. Call GE for service. Gendos...post back
Feb 23, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
