Question about Sport & Outdoor - Others
Purchased a used Proform treadmill space saver 580 SI 0-10 mph with 2.5 hp dc motor 16" x 50" treadbelt and didn't receive a instruction manual and wondering how we can get one
SOURCE: Proform 520
Not sure what's happened here. treadmill won't turn on when red key is inserted. checked electrical plug to make sure it worked. I couldn't see that there's anything wrong with the red key. Have any ideas?
Posted on Sep 12, 2009
jyackle5
  • 8197 Answers
SOURCE: Instruction manual for proform 990
The only way to get the manual is to contact proform on link below.
http://www.iconservice.com/CustomerService/contactUs.do?dr=PF
Posted on Jan 27, 2010
maxtreadmill
  • 832 Answers
SOURCE: Proform 2500 treadmill stuck in incline position
Under the motor shroud their is a instruction mini manual it will have a how to calibrate the incline motor, if that does not fix it then you may have to manually adjust the incline motor and sometimes it will take awhile to realign . If that does not work replacing the motor maybe the only option
Posted on May 06, 2010
maxtreadmill
  • 832 Answers
SOURCE: I have a proform xp 580. when I turn it on,
Press the Stop and the Speed Up keys down while inserting the safety key.
Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
Press either incline key and the incline will calibrate automatically.
After completing calibration of incline, press the Stop key and then remove the safety key.
Posted on Jun 14, 2010
SOURCE: I am looking for an
I need the manual for the ProForm 485pi
Posted on Feb 09, 2011
Treadmill will run for about half a second and stop?
LED Blink Patterns on the Control Board Treadmill Treadmill Maintenance How To Lubricate Treadmill Belt
Follow this steps in order to fix it.
However if the problem persist, time to REPLACE the complete Controller board motor. Some IGTBs is faulty.
Blessing.
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
Oct 06, 2017 | Proform XP CrossWalk 580 Treadmill
Proform xp 580 trips the breaker as soon as you turn it on
Treadmills have up to a 15 amp power draw. They are like space heaters, Proform often recommends having a dedicated 15-20 amp circuit for a treadmill. Ellipticals have less power draw.
I repair most Icon products, is this a new problem with an old treadmill? If it is a new treadmill, call the number in the front of the manual, if they can't fix it over the phone, there is a good warranty on it. At least for a little while. ;-)
Jan 21, 2013 | Proform XP 580 Trainer Treadmill
I have a proform 580 trainer whose speed fluctuates. if it is set to 4 mph it will go down to 3.2 mph then back up to 4 mph and anywhere inbetween those speeds.
1) Tess by RUN the sofware calibration for easy diagnose, troubleshooting and fix it.
2) adjust the speed sensor, test for open or faulty, clean it and tight the plug very well. see the diagram attached.
3) Test the inclination motor for overheating Try to LUBE
4) Lube the deck belt according with the schedule maintenance.
God bless you
Dec 18, 2012 | Proform XP 580 Trainer Treadmill
Loud clunking noise in rear roller of proform 580 treadmill
You must LUBE the deck belt first, this happen because you do not lube maintenance schedule, Do it every week from use.Maybe you have a WORN deck belt.
2) LUBE the rollers bearing front and end, use WD-40
3) Test the drive belt motor, for cracking or worn, and replace.
God bless you
Nov 29, 2012 | Proform XP 580 Trainer Treadmill
My pro form 580 si won't reach max speed. Why is
Dear Sir:
Adjust the speed sensor very weel see the diagram attached, tigh the connector wires very well, and clean the s. sensor very well.
2) Run the software calibration for easy diagnose , fix it, and trouble.according with your manual instructions.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua.
Apr 03, 2012 | Proform Exercise & Fitness
Calibrate new console
Dear Sir:
Please see the instructions 1) some models attached under the Hood of the main motor 2) Other model is under the cover of display board.
3) Follow the instruction from user guide.
Adjust the reed swithc see the attached diagram
If you do not have user guide. go : www.proform. com go to customer service go then parts% Manuals, give your model, etc, and download for free your u. manual.
ernesto cuadra
managua, nicaragua. c.a.
Feb 29, 2012 | Proform XP 580 Trainer Treadmill
My proform 580 runs for 1/2 second, shuts of, and resets and will repeat this as many times that you push the start button
HI,
Your treadmill have problem with the motor control board. The motor control IGBT is faulty thats why its stars at high speed and shuts off immediately by sensing over current drain. The solution is replacing the motor control board or replacing the IGBT on the motor control board. To replace the IGBT you should have a through knowledge in electronics. If you need any more assistance feel free to contact me through FixYa.
AJIN
Jan 19, 2012 | Proform XP 580 Trainer Treadmill
The treadmill seems to work fine at first then the belt kinda sticks. It like stops and goes. Electrical seems fine
It's possible that your treadbelt needs lubrication, or simply adjusting. Here is a tutorial on adjusting your treadbelt:
Here is one link to purchase a lube kit, there are probably many others online also:
Should you actually need to purchase a new treadbelt, I would try to identify which specific model of the Proform 530 you have from this list and then in the parts list for that treadmill scroll down to "Treadbelt"
Oct 14, 2010 | Proform 530 Treadmill Walking Belt
My treadmill Proform caliber walk... belts keeps
The deck needs to be lubricated. The lubricant can be purchase @ gympart.com. LUBRICATION PROCEDURE: 1. Turn off and unplug treadmill. 2. Cut off the end of the tube of lubricant. 3. Holding the tube in one hand, insert the tube underneath the treadbelt halfway between front and back and halfway between right and left. 4. Squeeze the full contents of the tube onto the deck in a circular pattern in the center 1/3 of the deck. 5. Plug in2_bing.gif and turn on treadmill, then walk normally on treadmill at 0.5 mph for five minutes
May 08, 2010 | Proform Crosswalk 500 Treadmill
Stops while in motion
May 01, 2010 | Proform CrossTrainer Treadmill
Sport & Outdoor - Others Logo
54 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
