Question about Intel D845GVSR Motherboard
I am unable to get other resolution other than 600 pix
  • 1,179 Answers
You need to install the drivers for your graphics card/chipset.
www.Nvidia.com
or
www.AMD.com
Depends on the type that is in your Intel Motherboard.
I think it will be Nvidia.
Click download drivers.
damnor01
Posted on Apr 04, 2011
  • damnor01
    damnor01 Apr 06, 2011
    How did it go?
    damnor01
Cannot change resolution on screen
Normally if you can't change the resolution to a level that is supported by your screen and video card your problem is going to be your drivers. Update your drivers and the situation should resolve.
Nov 10, 2011 | Samsung N150 Notebook
How to increase resolution from 1024 x 576 pixels to 1280 x 600 pixels. I tried to change it by clicking start>control panel>display>settings but won't get desired results.
make sure wether the disply of your monitor and graphics card supports the resolution if the monitor doesnt support sthe resolution you will not be able to increase the resolution the mobilor becomes black
Sep 04, 2011 | HP Mini 1000 Netbook
Unable to get 1024 x 768 resolution on philips 105e
Hello, that resolution should be available but only at a refresh rate of 60hz as per the specs pasted below. Can you see this resolution setting on your graphics card? If not then perhaps you need to check you have the latest driver for your graphics card and just make sure that your graphics card does support that setting anyway.
Display
Diagonal Size 15" Viewable Size 14" Dot Pitch / Pixel Pitch 0.28 mm Max Resolution 1024 x 768 / 60 Hz Max Sync Rate (V x H) 120 Hz x 54 kHz Video Bandwidth 65 MHz Factory Preset Resolution Modes 1024 x 768 / 60 Hz
800 x 600 / 85 Hz
640 x 400 / 70 Hz
640 x 480 / 75 Hz
640 x 480 / 60 Hz
800 x 600 / 75 Hz
Regards,
nicam49
Dec 26, 2010 | Philips SoHo 105E 15" CRT Monitor
Picture Projection
The default to enable the external VGA is Fn+ F8, it toggles between LCD, LCD + External and External only.
You may need to wait up to 15 seconds for the switch to occur.
There also may be issues with the resolution of the projector and or detection if using some type of adapter in the connection.
Resolution of the projector is 800 x 600, so you may need to reduce the system resolution to that too.
Feb 17, 2010 | Dell Inspiron 2200 Notebook
Problems regarding visibility of details while playing...
Adjust the graphics/video settings that suite your system, try the best resolution for your system that works fine eg 800*600 or 1024*768.
try changing other settings too.
mostly it works when u select the right resolution
Jun 19, 2009 | Microsoft Age of Mythology for Windows
Game wont play
hit start, go to control panel,click apperance and themes,click display,select sitting tool bar set screen resolution to 800 x 600 and color quality at 32 bit
hope this helps
Mar 13, 2009 | Arush Entertainment Playboy: The Mansion...
Reducing resolution
Set the resolution you want to use in the GAME. Under the Settings heading, when you go into the game!
damnor01
Jul 14, 2008 | LG Flatron L1515S 15" LCD Monitor
FUJITSU SIEMENS AMILO PRO V200D
Hi
It sounds like Drivers for the Video card is not loaded properly.
What is the current screen resolution?
Are you able to increase the resolution to say 800 x 600 pixel or preferably 1024 x 768 pixel?
If the current screen resolution is 640 x 480 pixel and you are unable to increase resolution to the above pixel levels, try updating Windows Drivers for your video card.
AMILO Pro V2000 Display - Intel® 82852/82855 GM/GME Graphics Controller Family (Intel® 852/855 Chipset Family) (WinXP, W2000) Version: 6.14.10.3792.
Directly download - http://support.fujitsu-siemens.com/download/ShowDescription.asp?SoftwareGUID=325da0bd-fe5f-41e6-84d9-d628c5411188&OSID=665F4A20-6E31-43C3-82C2-D98CE773007C&Status=True&Component=Intel%20855GM
Regards
Mike
Mar 18, 2008 | Fujitsu Siemens AMILO Pro V2000 Notebook
Screen resolution
What is your monitor manufactoring year? Because old monitor could not set up to 1024x800 pixels. Please check the refresh rate also at the monitor property tab.
Dec 10, 2007 | Gateway FPD2275W LCD Monitor
Driver for Polyview V17E 17" LCD Flat Pane
if you are using windows and it just won't let you go on the other resolutions try checking the monitor settings in your control panel
Nov 06, 2007 | Polyview V17E 17" LCD Flat Panel Monitor
Intel D845GVSR Motherboard Logo
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
