Question about Garden
Gas powered pressure washer in storage over winter will not stay running.
  • 577 Answers
Drain old gas out and clean the carb out, should run like new then
Posted on Apr 07, 2011
  • Robert Beasley Nov 08, 2011
    I finally emptied out the gas, took the carberator appart and everything looked ok.
    I then realized that the gas line from the tank came down to the suhtoff valve then horizontal to the engine. I put the valve horizontal which was the off position. Putting the valve vertical corrected the problem and the washer ran for hours after that.
    So all those insulting comments for help desks like is the computer plugged in really are necessary.
    LOL
Float is stuck in closed position after winter storage.
problem is the main jet --probably blocked or insufficient fuel flow due to bad rubber hose from tank or corrosion in the carby
ethanol did affect rubber parts so you may have to pull and check all fuel related parts
Nov 29, 2016 | GAS Motorcycles
Is there a lubricant I can use to unstick frozen pressure washer pump?
If pressure washer got frozen over the winter, the pump is bad. replace! Use winter pump protector during winter storage!
Mar 29, 2016 | Honda 2500 PSI Gas Pressure Washer
Stihl winterize pressure washer
To winterize , be sure to run all of the gas out of the unit... also make sure no water is left on the pump. If so, the water will freeze and expand causing blown seals when you try and start it next season, you won't have any pressure... DO NOT USE STABIL.
Remive all gas, even from the carburetor... to do that, loosen bottom bolt on the bowl of the carburetor and let the gas leak out...OR run it until it stalls from being out of gas... keep your plug in, don't remove it. Some people do BUT it's silly to do so because it allows debris to fall into the hole and which could damage the cyclinder walls...
I keep mine in my basement to take no chances.. if you have a basement, you won't have to worry about wintering since it will be warm enough inside... especially if you have an expensive Stihl, lol, I would.
Nov 07, 2015 | Garden
How do I winterize Gas high pressure washer.
Pump will freeze in cold weather from water left in sump. Get it running and instead of hooking it up to a water hose, use a short length to take a gallon of so of antifreeze.
Oct 02, 2014 | Briggs & Stratton Power Products 1539...
Will not continue to run after start. new gas tank was empty prior to use after winter storage.
was the carb drained before stowaged? if not carburetor cleaner is needed to clean the jets and float bowl out from varnish build up
Jun 11, 2011 | Honda Black Max 2600 PSI Pressure Washer
How to winterize my gas powered presserwasher
THEY SALE FUEL WINTERIZER SOLUTIONS AT ANY HARDWARE STORE AND AUTOMOTIVE PARTS STORE. AND YOU CAN PUT SOME ANTI FREEZE IN THE PUMP TO STOP IT FROM FREEZING AND CRACKING.
Dec 11, 2010 | Karcher K2.26 Electric Power Washer
What do I have to do to winterize my pressure washer? It will be in an unheated shed all winter.
Gasoline goes bad after sitting for an extended period of time.
Old school people would drain the gas out of the tank but found this lead to rust forming in the tank.
Now it is best to fill the tank with high octane gas and use a winterizing fuel additive to prevent problems.
Also remove any water from the hoses.
In the spring replace the gas and change the oil and you should be good, changing the spark plug would also be beneficial.
Oct 10, 2009 | Northstar Pressure Washer 2800 PSI
Pressure washer won't run. It starts and runs for a second then stops. I've tried and tried, several days. Methinks it's the carburetor gummed up since I left it outside all winter, sheltered, and...
Although this costs a little money, it covers most home gas/electric and industrial portable kerosine/diesel fired hot water pressure washers. Worth sharing... ">
Mar 09, 2009 | Psi Blue Max 2200 High Pressure Gas Power...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
