Question about Casio G-Shock Atomic Solar GW610DA-1V Watch
The band on my Casio G-Shock GW610DA watch keeps poping off, it looks like the hole is now elongated where the band attaches to the top of the watch, is there a way to fix it and find the parts?
SOURCE: need too set time on my g shock casio watch
Press Adjust and hold until blinking city appears.
Press Mode until DST appears flashing.
Press Recieve until mode that you want appears ON OFF AUTO
Press Adjust until not blinking city code.
Posted on Mar 12, 2008
  • 13433 Answers
SOURCE: watch alarm
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
If you don't have a pdf reader you can get one from
http://www.foxitsoftware.com/pdf/rd_intro.php
Posted on Jun 10, 2008
SOURCE: how to adjust metal wrist band on casio watch?
Take it to walmart or any store with a jewelry section, they'll fix it
Posted on Sep 20, 2008
Yes
Posted on Nov 02, 2008
Nobarai
  • 57 Answers
SOURCE: Broken wrist band
The easiest is to bring it to Wal-Mart, or another store with a watch section in their store, if you buy a new wrist band, they;ll put it on for free. If you're feeling DIY, pull the watch band to the side, untill the metal bar inside is ejected form the slot in the watch, from there, insert the new band's bar into the slot, and voila!
Posted on Nov 16, 2008
Casio gw-500, trying to change the bands, screws keep turning
For G Shock GW500Uthe screws holding the ******** are actually just one pin per strap the screw end is for decoration. To remove just get small headed flat screwdriver and push pin through it is fidely but can be done it took me 10 mins first time. Casio sell straps direct for about 10 pound cheaper than putting into casio dealer .
Jun 11, 2011 | Casio G-Shock GW500A-1V Wrist Watch
Adjusting a casio s940db watchband
  • On the inside of the band, locate the links with the arrow etched on them. The arrows mark the removable links.Lay the watch on its side on a flat surface with the arrows pointing downward. Be sure to leave about 1/2 cm of space between the bottom of each removable link and the flat surface. Using a 1/32" flat head jeweller's screw driver (or metric size 1.0), insert the tip of the screw driver into one side of the removable links' pin holes. You will find that the pins have an end that looks like a screw head. This is misleading - press down very firmly on the other end. Press downward firmly to make the pin pop out the other side. Be careful not to lose it.Remove the pin on the other side of the arrow-marked link.Repeat as necessary to remove half the needed links. You will remove the other half from the other side of the band to maintain equal band length.Flip the watch over so the arrows are pointing upward.Align the holes in the remaining links. Insert the rounded edge of one of the pins into the open link hole. The pin will go in without trouble until the top.Holding the pin in place, carefully flip the watch over again and firmly push the pin fully into placing using the flat surface. The pin will snap into place.Repeat for the other half of the band as necessary.
  • Sep 26, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
    How do i change watchband for casio bg169wh
    Take the watch with the broken watchband and place it on the table. With a ruler, measure the width of the broken band at the point where it is attached to the watch. Now, measure the total length of the watchband when it is in one piece and fits around your wrist. There will be a crease on the band where it is normally buckled.
  • Step 2 Go to the local store and select a band that you like. You should make sure that the width of the band at the point of attachment to the watch is the same as the old band. Also make sure that the new band will be long enough and not too long to fit your wrist. Purchase the band and return home to change the band.
  • Step 3 Clear a spot to work and make sure that there is a small towel covering the table top so that you can see anything that may drop or pop out during the process of changing the band.
  • Step 4 Use a magnifying glass to look at the point where one side of the band is attached to the watch. You will see a small pin connecting the band to the watch on either side of the band. Carefully use the jeweler's screwdriver to depress the spring loaded pin from the watch to the band and release it from the watch. When the tension on the spring pin is released it may pop out of the band and you will want to take care not to lose it. Repeat this process with the other half of the band.
  • Step 5 Take the new band and slip the spring pins into the small holes on the end of the band where it will attach to the watch. Working with one end at a time, slip one side into the pin hole in the watch body.
  • Step 6 Use the jeweler's screwdriver to depress the other side of the spring pin and guide it into the pin hole in the other side of the watch body. Repeat this process with the other half of the watchband and other spring pin. You now have a new band for your broken one.
  • Jun 20, 2009 | Casio BabyG BG169WH3V (Size: ) Watch for...
    Casio G-Shock GW-300 replacement bands
    I have a Casio g-shock gw-330a and now find myself again replacing the band. So far, $60 on bands. They last me two or three years. To install the band, take the band and watch to a Jeweler. My local Sears does it for me. $5 for installation; $5 for purchase shipping; $20 for band. $30 every couple of years.
    This cost disturbs me.
    Jun 09, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
    Casio G plastc watch case holder replacement source.
    i need a replacement case for g shock gw-002e,any ides where i can get 1.im in essex,uk
    Feb 25, 2009 | Casio G-Shock GW500A-1V Wrist Watch
    Change casio g shock resin watch band
    It can be done and not too difficult i think but look out that the leather band ain't too wide for the band orginal place,
    make sure you keep all original parts in case of toruble
    Post a photo if you can after the change will be nice to see the change
    Tom
    Nov 10, 2008 | Casio G-Shock GW500A-1V Wrist Watch
    Casio Wave CeptorModeule #2735
    I drilled a coupleof very small holes in the plastic part of the case and also in the watch band where it attaches to the case. I mixed strong epoxy glue (two part) and held the two pieces together with clamps over night. That was 6 months ago and it is still holding. The holes helped squeeze the glue into the joint. Good Luck!
    Joe
    Nov 08, 2008 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
    How do you replace the watch band on a casio g-shock
    The following proccedure mentioned can be implied for replacing only resin(plastic) strap.
    If you have a spare Band, you can replace it with the help of one small four mouth screw driver and one small 1, 2 or 3 no. screw driver which you can get from any electronics/ computer hardware shop.
    Band = Strap
    You just need to remove the strap with the help of 1, 2 or 3 no. screw driver which ever you find convinent by removing the Spring Bars. After removing the strap put out spring bars from both sides as these may be used for again fixing the band.
    If you find difficulty in removing the Band, you just need to unscrew the screws on for side of the watch case and remove the ring and after fixing the strap you can fix the ring again.
    The new band can be fixed in the same way as it has been removed. You need to put the spring bar in the hollow space of strap and keeping the buckle side part of starp above the watch i.e 12 position over the space where it has to be fixed, then put one end of the Spring bar on one hole in the watch case and press the spring bar to get inside from other side (hole in the watch case). In the same way you can replace ******** other side.
    In case of any difficulty take your watch to nearest Casio Service Centre for assistance or solution of problem.
    Jul 20, 2008 | Casio Watches
    Casio G Shock (Model G2300)
    you have to remove the pins located under the band
    Feb 26, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
    Casio pathfinder SPF 70-s titanium band adjustment
    I purchased a Casio Pathfinder solar/atomic watch, with compass, altimeter, barometer, thermometer, model 1200T-7WC (titanium).
    Has the titanium band - on this particular band each link is somewhat waveshaped {i.e., there are 2 "arms" from the link making contact with the middle part of the link above (above meaning towards the watch body), and 1 arm fitting between the 2 arms of the next link down). Unlike described in the first solution, the pin is not split, but solid (doesn't look like a slotted screw on 1 end, so the solution at http://www.wikihow.com/Adjust-a-Casio-S-935L-Watch-Band is no help). Here's what to do if you have this band:
    1. Note: before you start, be advised there is a tiny loose 1/8" part (sleeve) that will fall out as you pull the links apart, so work over an appropriate surface to "catch" it. Push pin (from the upper "arrow end) of one of the removeable links (those with the arrows on the backside) out of its hole with a fine poker (I used a 1/32" jeweler's screwdriver, an unbent paperclip would also work, just more likely to bend as you push pin out). This takes some force to do - in my case, after pushing, the pin projected out about 1/2 of it's length, I used needle-nosed pliers to gently pull it out the rest of the way). CAREFUL - once pin is removed and you pull the link away from the one above, a small (1/8") constriction sleeve should fall out of the center arm of the link above. SAVE THIS SLEEVE!
    2. Using the same procedure, remove the pin from the bottom end of the link you're removing. again, SAVE THE SLEEVE.
    3. to rejoin the band once the link is removed, look at the single/middle "arm" of the upper link, looking for the hole where the pin goes through. One side of the hole should be noticeably larger/wider than the other side - this is where you will place the SLEEVE - I used tweezers, or needle-nosed pliers will work - it will drop into hole. Keep this upright so that sleeve doesn't fall out, and slide the 2 arms of the lower link in place around the center arm.
    4. Slide the pin you removed into one of the outer link arm holes - I found it easier if I started from below, pushing it into the center arm - it will stop when it reaches that 1/8" constriction sleeve. I set the extruded end on the pin on a magazine (i.e., slightly padded surface) and then pushed the top side of the band down, forcing the pin through the constriction sleeve and up into the upper arm hole, and Voila, your band is reconnected. The sleeve is important (without the sleeve in place, the pin will simply fall back out).
    Dec 17, 2006 | Casio G-Shock G7000D-8V Wrist Watch
    Casio G-Shock Atomic Solar GW610DA-1V Watch Logo
    20 people viewed this question
    Top Casio Watches Experts
    Kazim ERGUNEY
    Kazim ERGUNEY
    Ansel Alberto
    Ansel Alberto
    Are you a Casio Watch Expert? Answer questions, earn points and help others
