When i press the button to start my computer,its start but nothing on the screen and that's it... what seems to be the problem? thanks
    Genius:
  • 1,157 Answers
Hi andre_naviga,
If system wont display anything after booting up, you might have a display issue. The easiest way to correct this problem is to perform a power drain. Here are the steps on how to do a power drain.
1. Turn off the computer completely.
2. Now, unplug the AC adapter from the power outlet.
3. Remove the battery from the system.
4. Press the power button for about 15-20 seconds.
5. Put back the battery in and plug the AC adapter to power outlet.
6. Turn the computer on and observe the system.
Hope it helps.
Thank you for using FixYa.
Posted on Apr 04, 2011
Comes up with press dot screen nothing I do seems
Have you tried a screen calibration? Turn off the unit then press and hold the upper left of the screen as you turn it on. A dot will show up on screen and then press the dot firmly as it moves around the screen. When it is done it will say screen calibration complete.
I also assume you tried a reset by pressing the reset button or on the newer units just hold the power button while turning it on for about 15 seconds until it reboots.
Thanks for using FixYa
Sep 25, 2011 | Garmin nuvi 1450 GPS Receiver
Hello I have a LENOVO-Y430 laptop, suddenly my laptop stopped functioning, It gets stuck in the STARTUP LENOVO SCREEN, I get two options in the bottom of the screen, press F2 for SETUP & Press F12 for...
Welcome to Fixya
Make sure first that there are no devices plug in to the usb when you boot up the computer. Check if the harddrive is being detected by the computer. Press F2 to go to BIOS menu and see if the computer can detect you harddrive. It should be under the main menu and will say below harddrive. It should give you infromation of the harddrive. If there is no information of the harddrive then the problem there is the harddrive already.
Please reply to this email for any update.
Thank you for using Fixya!
Feb 02, 2011 | Lenovo IdeaPad Y430-3231U Notebook
Blue screen after I have done system restore on compaq presario CQ60. I have tried F8 on start up to run in safe mode but nothing seems to starp the blue screen on start up now.
Welcome to FixYa
Dear user
Perform a Hard Reset first.
Disconnect devices including USB devices and media cards. Disconnect the AC power adapter, remove the battery Press and hold the power button 15 seconds . connect the power adapter -do not connect the battery- Press the Power button, Look for blinking LEDs near caps lock and num lock keys, and Listen for sounds of a disk drive and fan turning.
Hope this helps...Thanks for Connecting FixYa...
Dec 04, 2010 | Compaq Presario Notebook
Have used for 3 1/2 years no problems. 1 day on working great, left for about hour & back to black screen. When computer first starts, I get welcome screen, then nothing the menu lights on right light...
Have you tried it on another computer? if not please do it. Your monitor problem seems with the CPU not booting up properly. You can also try with another monitor on the computer. Please confirm after you are done with the results. Thanks.
Aug 17, 2010 | Gateway FPD2275W LCD Monitor
My dell xps m1530 laptop seems to be on but nothing on screen
Remove the battery and power cable from the system and press the power button for about 5 seconds, then plug in the charger and start the laptop. it will work. shutdown it and put the battery back and start once again . now you can see its working
Feb 12, 2010 | Dell XPS M1530 Laptop
Breadman TR875 powers up but none of the buttons seem to
After powering it up, press and hold the start button (these are instructions from customer service). On a good machine this doesn't seem to reset anything. If this doesn't work, try holding in the start button while you plug it in and than release after a few seconds.
Jan 17, 2010 | Breadman TR875 Bread Maker
Compaq F572US won't start (led turns on, but nothing happens)
I have been having the same problem. At first I thought that the motherboard was fried and the laptop was a paper weight, but I kept it plugged in and kept pressing the power button several times over the days. It would always seem to start (screen remained off/black) and then it would just go off again in seconds. But persevarence has paid off, finally almost after a week it started up like normal and started working again as normal. I then had the same episode repeat a few weeks later, the computer was useless for a few days and again started up as I kept pressing the power button several times a day.
I believe the problem is with the standby mode. Each time the problem happened, it seems like the computer was going into standby mode and the power button was pressed again before it could competely go into standby or the button was pressed again while it was coming out of standby.
To sum it up, nothing is wrong with the cimputer components, there is some problem with the standby routine. Keep pressing the power button and hopefully you can get lucky in getting the computer to start again. Long term, I am thinking about checking whether there was a new flash update that came out that could fix this problem. I purchased the laptop compaq F72US in 2008 and never updated anything. Also worth noting that I called HP and they didn't stand behind their product.
Sep 28, 2009 | Compaq Presario F572US Notebook PC
Print Screen Button not working
Yes, there is a button, up by the function buttons, that says "print screen". I've tried pressing just that button; pressing that button and the alt button together; and pressing the "Mode F" button and the print screen button together, but nothing seems to work
Jul 23, 2008 | Logitech LX 300 Keyboard/Mouse
Comp won't start
maybe there is something wrong with your power supply.. i think you need to change it
Mar 01, 2008 | Computers & Internet
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
