Question about Kenmore Washing Machines
My washer drains while its filling - Kenmore Washing Machines
  • Kenmore Master
  • 8,220 Answers
Raise your drain hose up to a higher level. The gravity is letting the water run out because the hose is too low. Drain hose must be at least 30 inches above the floor but no higher than 5 feet.
Posted on Apr 04, 2011
Fills Constantly
check the drain hose. Is it in the drain below the fill line of the washer?
In other words -- the drain line should be above the level of the washer lid top and in the line about 4-6 inches
Feb 20, 2014 | GE GTWN3000MWS Washer
What does the IE error code mean? The washer wont drain.
The IE fault code indicates that your washer is not filling properly with water This error code is displayed if the washer is not fully drained within 10 minutes. I will give you troubleshooting tips for both the fill problem and the drain problem.
To troubleshoot a drain problem, follow these steps:
  • Follow the steps on page 17 of your owner's manual to clean the drain pump filter. If you do not have your owner's manual, you can access it on our Manage My Home website.
  • Check your drain hose for kinks or clogs.
  • Make sure that the drain hose is properly installed according to the installation instructions for your washer.
Here are some troubleshooting steps for the filling problem:
  • Make sure that the water valves behind your washer are fully open.
  • Check the filter screens on the inlet valves where your fill hoses connect to the back of the washer. If debris is clogging the screens, remove the screens and thoroughly clean them. Flush the inlet openings thoroughly with water to prevent debris from entering the washer and corrupting the inlet water valves.
  • A drain installation problem can cause siphoning of washer fill water. Make sure that the drain hose is properly installed per the installation guidelines for your washer.
Jan 13, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Roper washer leaks when filling
It's in the drain hose somewhere,during the fill the water gets as deep in the drain hose as it does in the washer,during the wash the pump runs in reverse keeping the water level in the hose low,during the drain the hose is filled again.
Prop the washer up in front on a couple bricks or boards,start putting in water until it starts to leak and take a peak under the machine.
Sep 27, 2009 | Washing Machines
Washer will not fill up!
The water is siphoning out as it fills. Your drain hose is too low or has a air block. Remove the drain hose from the drain. Set the washer to fill. Hold the drain hose up higher than the washer. If it fills correctly and starts agitating,correct the drain hose problem.
Sep 23, 2009 | Admiral AW22 Top Load Washer
Fills and Drain...
Check your washer drain line for a possible siphoning condition. The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
Read through the link I provided. Your problem may be a simple matter of drain hose placement. If this does not solve your problem, please post back and let me know. I hope this helps you.
Jun 22, 2009 | Kenmore 98702 Stacked Washer/Dryer
Washer fills and drains at the same time. doesn't change cycles
check the washer drain hose, it is probably sipening the water back out, try pulling it out of the drain a few inches
Apr 07, 2009 | Kenmore 24032\24036 Top Load Washer
Top loaing washer fills then mostly empties repeatedly
Check you drain line. It may be too low or the air gap is blocked at the drain pipe.
A test is remove the drain pipe from the wall drain. Hold it up high and turn the washer on to fill.
If it fills and stops, then starts agitation. Repair the drain hose.
Mar 23, 2009 | Kenmore Washing Machines
Maytag washer
Check to make sure your drain hose has a loop at least as high as washer top.  If the drain hose is not looped higher than tub water will continue to drain and it won't stop filling.  If it doesn'y reach the correct fill level it won't agitate.
Oct 29, 2007 | Maytag PAV2300 Top Load Washer
Washer clothes
Does the washer fill normally and just stop? Or, does the washer fill, go through a complete cycle, and just won't drain? There could be a couple of problems that cause a no drain issue. 1. FILL NORMALLY & STOPS, WILL NOT SPIN - This is usually a bad lid switch. If you open and close the lid, you should hear a "click", indicating the switch is working. 2. FILL NORMALLY, AGITATES, WILL NOT DRAIN - This could be a clogged drain pump, pinched hose, clogged rain line. Also, you need to make sure timer is advancing properly. If the timer never advances, the washer will fill, but won't go into agitate or spin. Let me know if this is helpful.
Aug 09, 2007 | Whirlpool LSR5132J Top Load Washer
Washer fills then drains
Daisy, check your drain hose going into the drain. It sounds like you have a siphoning problem. If the drain hose does not have a air gap the water filling will siphon right out. Check this first and post back, Catriver.
Sep 21, 2006 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
49 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
