Question about Honeywell HZ519 Baseboard Heater
What is the use per KW Hr on the Honey well HZ 519-20
  • Honeywell Master
  • 5,187 Answers
This unit uses 1500 Watts (1.5 kW) in one hour at its maximum setting. (12.5 A * 120V AC) The total cost will depend on how long the heater is on each day and the utility charges at the time of use (for example, if you have day/night rates).
The manual is available here: http://www.kaz.com/kaz/support/manual/?ProductManualAction=renderProductManualById&ProductManualId=fc5e11ee85619a5101b4c15f217911d6 .
I hope this helps.
Posted on Apr 04, 2011
KW to BTu's
To convert KW to BTU use the following:
1KW= 3412.142 BTU/ hr
Hope this helps.
Bob
Jan 17, 2014 | Intertherm 56000 Btu Gas Furnace
Coleman Powermate 5000W has HIGH RPMs until a 3KW load
This generator is less than ideal to use as a home unit. see www.advanced-power-technologies.com and look at residential videos. Basically the voltage is governed by a capacitor on your unit, and ouput is directly propertional to speed. Also the engine is mechanically governered versus an electronic system. This is a common mistake using portables to power home equipment. You will damage your home digital equipment, do not use recommended
Jan 25, 2013 | Coleman Powermate Powermate 5000W...
Why do my clocks run fast when my Briggs & Stratton 15kw generator is running?
Electric clocks use synchronized motors that run on 60 Hz AC. The power company provides AC power with a precisely regulated frequency of 60 Hz. That means that the voltage jumps back and forth (positive to negative) 60 times per second. Your generator would do the same thing if it could run at precisely 3600 rpm (that's rev's per minute) - but it can't, because the engine is not that precisely controlled. In your case it tends to run (on average) a little fast. I hope you found this helpful. By the way, in Europe 50 Hz is the norm. If you run a clock designed for 50 Hz on 60 Hz power, it will run 20% too fast! Al K
Jun 20, 2011 | Briggs & Stratton Briggs Stratton 7 kW...
Grace walks 80m in one minute. how far does shewalkin one hour in kilometers
First we look at the constants that we know. First we know 1 m = .001 km so, 80 m = .08 k. Second we know 60 min = 1 hr or 1 min = .016667 hr. So, plug in piece by piece what we know 80m per 1 min = .08 k per 1 min = .08 k per .016667 hr. this can also be written as .08/.016667 k per hr which is 4.8 kilometers per hour.
Apr 05, 2011 | Sharp EL-1701C Calculator
6) If two lights of capacity 80W replaced by 20W, which run for 6 hours per day. What will be energy savings per month (30 days) in KW/hr?
For the 80W bulbs you'll be using 2 x 80 x 6 x 30 = 28800 W/hr = 28.8kW/hr.
For the 20W bulbs, it's 2 x 40 x 6 x 30 = 7200 W/hr =7.2 kW/hr.
The monthly saving is 21.6 kW/hrs, a saving of 75%.
Sep 04, 2010 | Office Equipment & Supplies
Can't find a manual for air conditioner
BTU means "British thermal units" and is a measurment of cooling and heating capacity. Other units are Kw "Kilowatts", and HP "Horse Power".
To convert
Multiply by
To obtain
kW
1.341
hp
kW
3,413
Btu/hr
hp
2,545
Btu/hr
May 21, 2010 | Fedders Q Chassis A6Q10F2A Air Conditioner
Hi, Yesterday I bought haier 12000 BTU air
To determine the cost of using this air conditioner, you will need to find out what your electric company charges per kw/h. This is the standard unit that electricity is charged for. Next determine the wattage of the air conditioner. This should be found on the unit name plate. If you can not find the wattage by the name plate, the take the voltage and multiply by the amperage, this will give you watts. Next multiply the wattage by 24. (watts per hour x 24 hours) Finally divide this number by 1000. This will give you the total Kw that the unit will use in a 24 hour period. If you multiply this number by the cost per Kw that will give you the operating cost of your unit for one day.
ex. electric company charges .25/Kw The unit uses 1000 watts 1000 x 24 = 24000 watts 24000/1000 = 24 Kw 24 Kw x .25/Kw = $6.00 day
Note: all figures shown above were randomly generated in my head, and have no correlation to your calculations. Hope this helps.
May 04, 2010 | Heating & Cooling
I have a General ER - 34 JW(W) Fridge and I need to know the wattage of the fridge
Hi
This Fridge uses 668 KW/H/ Yr. as per Energyguide US gov. tests.
This come to 80 Watts per Hr.
Regards
Berry
Feb 01, 2010 | General Refrigerators
How much power (kw/hr) does a D55152 use at full capacity?
Below you will find the power requirements for your compressor. I would recommend not to use an extension cord due to possible damage to capacitor. My dewalt a/c, with same motor, is actually using 17.5 amps right before shut off. Good Luck!
  • Drive: Direct
  • Horsepower: 2.7 MAX HP
  • Tank Size: 4 gal
  • Power Supply: 120V AC, 15 amps,
    >60 Hz, 2 pol induction motor
  • CFM @100 PSI: 3.8 CFM
  • Pump Speed: 3400 rpm
  • Tool Length: 18"
  • Tool Width: 18"
  • Tool Height: 16"
  • Tool Weight: 65 lbs
  • Oct 15, 2009 | Dewalt Heavy - Duty 1.1 Hp Continuous 4...
    Cost per hour to run Model # 5840 heater
    take the wattage of the heater, divide it by 1000 then multiply that by your cost per KW/hr from your electric bill, then multiply that by the number of hours you operate the heater. That will give you the exact cost to operate at full heating per hour.
    Oct 02, 2009 | Heating & Cooling
    Honeywell HZ519 Baseboard Heater Logo
    95 people viewed this question
    Top Honeywell Heating & Cooling Experts
    Bill Long
    Paul Carew
    vance jones
    Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
