Question about Kenmore Washing Machines
Washer 144590-000B Dryer 970-17802-20 horrible noise intermittent operation
5 Suggested Answers
j_alcaidinho
  • 107 Answers
SOURCE: My Kenmore 417.94812301 stacked washer/dryer makes
What you need to due is take front off dryer and either you're blower is making the noise, or the idler pulley and even the support wheels could be as well
Posted on Feb 26, 2010
blueextc3221
  • 15935 Answers
SOURCE: My kenmore 970-17802 stacked dryer
It appears your belt and POSSIBLY pulley/tensioner has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
blueextc3221
  • 15935 Answers
SOURCE: I have a 2002 Kenmore washer dryer laundry system.
It appears your clutch assembly has failed in this instance.
Posted on Oct 01, 2010
TheMobilian
  • 8220 Answers
SOURCE: DRYER RUNS BUT NO HEAT.WHERE
If it runs but no heat that is probably your heating element.
I recently worked on one of theses and got my grandson to snap a few photos of the repair.
417.91702000 Broken dryer belt and felt replacement
Posted on Jan 30, 2011
The washer made a horrible noise and the tub seems to be loose from the machine. Can I fix it? The tub in my Frigidaire stacked washer all of a sudden with a fairly heavy load of jeans started making a...
you need to remove the agitator and check the bolts that hold the trunion to the shaft and make sure they are not broken.if one is just replace them make sure that the bracket is in the flat key way on the tub hope fully the tub seal is still good.
Oct 15, 2010 | Frigidaire FEX831CS Top Load Stacked...
My Kenmore 417.94812301 stacked washer/dryer makes a horrible squeaking noise when the dryer is on. It is not overloaded.
Feb 20, 2010 | Kenmore 98702 Stacked Washer/Dryer
Makes a horrible noise. Seems to dry fine but before its done it sound like it going to explode.
The blower wheel may be stripped out or broken.
This will cause a loud rumble noise while operating.
Jan 16, 2010 | Maytag PYE2300AY Electric Dryer
DRYER IS MAKING NOISES
A common broblem with dryers and washers alike is the underwire out of womens bras coming out and getting through one of the holes in the drum wich makes a horrible racket. Open the door and use a flashlight to look inside to see if you can see the underwire in one of the holes. They also get stuck in the front seal where the drum rides around this is another good place to look.
Jan 04, 2010 | Dryers
Dryer comes on for a few minutes, makes horrible sound and goes off. now won't start at all. Frigidaire stackable
It could be the belt was partially broken, and as it came apart causing the dryer to no longer start,,, it made the noise your talking about. If the dryer still heats up, and you can hear the motor running,,, these would all be signs toward a broken belt.
Mar 13, 2009 | Frigidaire FEX831CS Top Load Stacked...
Horrible noise
The noise could be coming from the blower housing, as this unit does not have bearings, it does have 4 rollers however. If the unit is working on timed dry and not sensors there may be a problem with them. Check your venting though, if it is too short it may not have enough back pressure for the sensors to operate properly. This could also cause your thermosats to blow, the one is a manual reset, either way you are going to have to get a gas tech out there.
Sgt 48
May 30, 2008 | LG DLG5988 Stainless Steel Gas Dryer
Washing Machines Logo
55 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
