Question about Minolta 2430DL Color Laser Printer
Print quality print rubs off page, toner not adhering
  • 300 Answers
The fuser is not getting hot enough, check the menu settings
Posted on Aug 06, 2008
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
My phaser 6180 color printer, toner not adhering to paper
hi.it could be your print cartridge.end of life.and very costly
Nov 19, 2013 | Xerox Phaser 6125 Laser Printer
Have a Lexmark C510N laser colour printer. The print quality has become streaky and poor. Have only used genuine toners
You probably need to replace the photodeveloper cartridge.
Also check the fuser, they sometimes get sticky and pull the toner off the paper. Look for anything stuck to the fuser's rollers. Also check the print outs by rubbing them to see if the toner is stuck to the page well, if not, it's the fuser.
Both need to be changed every once in awhile,with heavy use they need to be changed more often.
Nov 27, 2012 | Lexmark C510n Laser Printer
TONER COMES OFF ON OUR HANDS, HAVE CHANGE PHOTOCONDUCTOR AND RESET COUNTER, STILL PRINTING, BUT TONER NOT ADHERED TO PAGE AND COMES OFF. HELP!
If the toner does not adhere to the page this may be a fuser or power supply failure.
I suggest you contact Lexmark Technical Technical Support for further assistance.
Oct 21, 2011 | Lexmark E250d Laser Printer
Dell 3110cn Color Laser Printer Certain colors will not adhere to the page when printed on heavy paper. Combination of green/black wipes off the paper when rubbed.
Either the paper is just too thick for the printer to fuse the toner correctly, or you've NOT selected the right paper type (in the printer driver options.
If you're just printing that same as you would on ordinary A4 paper, the fuser can't get enough heat through the thick paper to fuse the toner.
May be a wrong toner problem if you've done this successfully before, but only had this problem since changing toner cartridge(s)
Oct 19, 2009 | Dell 3110cn Laser Printer
The toner of the printed document does not adhere quite well on the paper. Wipping wich the pand over the paper the toner will come off partly. I thought it was a problem of the toner, however after buying...
If you've been using Okidata original cartridges then it sounds like there's something wrong with the fuser unit in your printer. The fuser is what heats the paper to "melt" the toner onto the page. If you haven't been using Okidata cartridges, the one you purchased could either be laying down too much toner or low quality toner that can't be properly adhered to the page.
Oct 17, 2009 | OKI B4100 Laser Printer
Hp Laserjet 1320 toner rubs off page
when the toner rubs off means it wasnt fused which means you need to replace the fuser
Feb 27, 2009 | HP LaserJet 1320 Printer
Toner Does Not Adhere to any Type of Labels
You need to specify that you are using labels in the printer properties, so the printer raises up the fuser temperature for printing on labels.
If you have the user guide, instructions are on page 28, chapter 5.
If not, here's how:
1. Open the straight-through output door.
2. Open tray 1 and adjust the media guides to the width of the media.
3. Load media in tray 1. Make sure that the top of the media is forward and the side to be printed on
(rough side) is facing up.
4. Open the printer Properties (or Printing Preferences in Windows 2000 and XP).
5. On the Paper/Quality tab or the Paper tab (the Paper Type/Quality tab for some Mac drivers),
choose the correct media type.
Feb 07, 2008 | HP LaserJet P2015dn Printer
Minolta 2430DL Color Laser Printer Logo
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
