My laptop is running so slow i tried to do a full recovery but it wasnt doing anything and also i have not sound at all on my archos laptop can you help please.
  • Computers & ... Master
  • 27,725 Answers
Try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f this should schedule to happen on reboot which will scan for and attempt to recover bad sectors and automatically fix any corrupt files on your hard drive or
click startcontrol panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
then you should test or replace all leads make sure they are securely seated and are not bad/faulty that are attached to your (((motherboard to your hard drive)))
then click start all programs accessories system tools defragment your hard drive
you might have to install more RAM random access memory to check how much ram you have
to check the details on your computer
click start right click on my computer select properties you will see all imformation about your computer including installed ram
scroll to the bottom toolbar (bottom of screen) right click you can select task manager applications also processes you will see whats running on your computer you might have virus slowing your computer also select users you will see who is using your computer
no sound
if you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Posted on Apr 04, 2011
My acer aspire 5315 running vista basic will not reset properly. I have factory reset it a couple times but errors occur when it boots up. It is very slow but i can access some programs and the net. Trying...
You may have to do a Full Factory System Recovery from your Recovery Partition. Before you do anything, do ALL the Windows and Acer Updates, rebooting when asked. Post results.
Mar 02, 2013 | Acer Aspire 5315 Notebook
Recovery (code 104)
From Archos' support website FAQ:
When I switch on my Archos device, the following message is displayed: "Would you like to recover your system?" What does it mean and what should I do?
You are on the recovery mode screen. It means that your hard drive has been damaged and must be repaired or formatted.
With this system recovery mode, you will have to select between "Repair Disk" and "Format Disk".
Start by selecting "Repair Disk" and follow the instructions displayed on the screen. See the full PDF manual (available on the Archos web site) on how to use the Repair and Format options.
If repairing the disk did not work, try formatting the disk by selecting "Format Disk". Note that the formatting will erase all data.
If you still cannot restart your Archos after trying a system recovery, you should contact Archos technical support.
http://www.archos.com/support/support_tech/faqs/en/faq_Archos405.html?country=us&lang=en
Feb 17, 2011 | Archos 405 Digital Media Player
My archos 5 IMT 160 gb has a blank screen. It looks like is charged. I makes noise while is starting up, but the screen is blank. I* charged for over 10 hours.
Screen is blank?
Do you mean you won't see anything at all like the signup colorful screen that says "ARCHOS Entertaining your way" ?
If your battery is full charged (did  the CHG LED green light blink when it finished charging?), and you have a blank screen, do you have a serious problem indeed. If your unit is under warranty your best and only way is contact Archos.
If when you turn it on, it takes you to the Recovery screen (white screen, usually says Code 101) then try to Format the HDD, download the latest firmware from www.archos.com for your unit, copy it from your PC to the Archos, let it finish the process wth the power supply connected, and once it's done the unit should be back working fine with the latest fimware.
But if you definetely do not see anything but a blank screen when you turn it off, your problem is more serious than a simple firmware upgrade, and you need to contact Archos tech support.
Mar 08, 2010 | Archos Internet Media Tablet MP3 Player
Recovery disk for Philips Freevents and system running slow
Readthis thread before you attempt anything.
http://lofi-gaming.org.uk/blog/2008/02/29/how-to-install-xp-on-a-philips-freevents-11nb5800-laptop/
Aug 02, 2009 | Computers & Internet
My new archos 5 is full how do i fix it??
Before you hook up to usb go into tools/settings/storage & see if your archos is set for pc hard drive mode which turns the unit into a external hard drive. That should fix it,Make sure you have a copy of the latest firmware downloaded onto your desktop from the Archos website before you try formatting or recovery functions. if that doesn't you might have to do a repair or format. You can try these functions in Customer assistance function in the tools/settings/customer assistance, but I have much better luck doing a hard reset. Sometimes the unit gets a glitch in it & you have to do a hard reset.
Turn on the power when the Archos screen comes on which has the Archos logo on it Immediately hold down the volume + button until the recovery page comes up
Jul 20, 2009 | Archos Internet Media Tablet MP3 Player
MY ARCHOS 704 TURNS ON BUT JUST SAYS ARCHOS ON SCREEN AND WONT DO ANYTHING ELSE
Try pressing and holding the TV/LCD button just after switching on, you should get a recovery mode screen. Select repair disk.
Jul 04, 2009 | Archos 704 WiFi Digital Media Player
My archos 605 won't do anything but to show recovery code 102.
recovery code 102 screen - this error message means the the hard disk has failed - I am guessing that the unit has been dropped at some point - Sorry but it back to Archos - The UK number is 0207 949 0115
Jan 20, 2009 | Archos 605 WiFi Digital Media Player
Slow computer -how to restore a Fujitsu Siemens Amilo Pro v1000
If the units are running slow, you can do some maintenance on them to speed them up.
First, run defragmenter on both units.(in Safe mode)
Download ScrubXP which will automatically clear your temp, cookies and TIF files.
Download CCleaner and run it.
Run your Anti-virus program: download the free version of AVG. (Great virus protection.)
Other programs to use are SpyBlaster and Winpatrol, all of which are free.
This should help, if you feel that you need to format and restore the units, youcan do so. But try this first.
Please remember to rate all users who assist you for free :)
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Sep 30, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
