Question about Ovens
Maytag Elec. Range Model MER6772BAW circa 2003/2004. Example: Set oven bake temp to 300degrees F. Oven clicks off when clock temp reaches 300degrees F. Hand-held Digital thermometer shows inner oven temp @ 350degrees F (+/-). Hand-held Digital thermometer reads oven cooldown to 260degrees F (+/-) before oven clicking on. Same cycle repeats over & over consistently. Food doesn't cook correctly. Heating element? Sensor? Clock unit? Help!
SOURCE: Kitchenaid kebc107 not heating
You need a themostat part #9759242
Your welcome
Jamie
PS Its easy to install!!
Posted on Jul 05, 2008
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    • 409 Answers
    SOURCE: maytag mgr5870 not baking correctly
    hi there,
    sounds like the TOD may be at fault. can you supply me with the model # on your stove please?
    as far as the popping sound, that would the spark module.
    Posted on Sep 14, 2008
    • 1214 Answers
    SOURCE: Maytag oven top heating element won't come on unless on broil
    You are probably going to find the lower heating element has failed. Your symptoms describe that failure exactly.
    Reply back if you want instruction as to how to repair.
    Posted on Feb 16, 2009
    SOURCE: 5 yr old Jenn Air Electric oven won't maintain oven temperature
    Technician just left our house with same issue. Jenn-Air had issued a technical bulletin as the temperature probe is mounted directly to the heating element, and measures the heat of the element, not the oven. Their fix is a revised temperature probe that goes at a 90 degree angle away from the heating element.
    If your temperature is consistent, just off by a set amount of degrees, there is an adjustment you can make at the control panel.
    Posted on Oct 23, 2009
    Oven temperature will not cycle
    How To Fix Oven With Little or No Heat When Baking ...
    www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
    Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
    Electric Stove Repair ' Electric Oven Repair Manual ...
    www.appliancerepair.net/oven-repair-4.html
    Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
    Electric Oven Will Not Heat ' RemoveandReplace.com
    removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
    Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
    Oven Temperature Not Accurate - Repair Parts ...
    Jan 28, 2016 | Frigidaire Ovens
    Frigidaire Oven Problem
    please post the model Number here..so i can look it up but just off hand there maybe an oven sensor (thermistor) problem this in inside the oven and tells the electronic ctrl board what the actual temp is in the oven it says 135 beacause it will until the temp reachs that after that as the temp goes up it will read 140 150 160 .. and so on until it reachs the set temp .. Is the oven getting hot and are there any fault codes coming up??
    Jan 28, 2008 | Ovens
    How to turn on electric frigidaire oven; fgf337gud?
    Good Morning Friend,
    I understand you want to know how to turn on the oven on your Frigidaire range, model# FGF337GUD. First, make sure you have set the clock. You will do this by pressing the "Clock Set" button and then press and hold down the up or down arrows, until the correct time shows. After you have set the clock, you are ready to turn your oven on.
    To set the temperature for your oven, you will press the "Bake" button and three dashes will appear. Press the up and down arrows to change the temperature. Note: The temperature will begin at a default temperature of 350 degrees. Once you have released the up or down arrow, your oven will begin heating to the selected temperature. When your oven reaches the desired temperature, it will beep once.
    To cancel the baking function, you will press the "Clear/Off" button.
    If you wish to change the temperature after baking has begun, you will press the bake button again, and then change the temperature by pressing the up or down arrows to either increase or decrease the temperature.
    I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your air conditioner status has changed successfully. Hope this is helpful.
    -Best Regards-
    WP
    Jun 13, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
    Neither oven or broiler work. Upper elements work well. Why is the bake light flashing / blinking?
    if it is not coming on then you may have the same problem again with the ignitor.
    May 04, 2014 | Ovens
    F1 when bake on oven is 350 degrees.
    You also have a defective electronic control. Replace the clock.
    Aug 30, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
    Maytag, slide-in, over and under oven. Circa 2007ish.
    see if it is set on bake or broil
    Aug 11, 2009 | Ovens
    Maytag gas oven wont restart after pre heat
    you have a bad oven sensor /faulty connection or bad control board.look for probe coming thru inside rear wall.should read 11k ohms cold.go bad a lot part number Hope this helps ,please rate my response :)
    12001655
    Jun 25, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
    Wall Oven won't work
    I tried randomly pushing 2 buttons at a time, and when I pushed "Timer Off/On" and "Cancel" together it unlocked and is now working fine. The following day it beeped a lot for an hour or so (must have been catching up on previous pushes) but now is back to normal.
    Mar 14, 2008 | Tappan 30IN ELEC IGNa Oven
    Ovens Logo
    64 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
