Question about Linksys Wireless-G WRT54G Router
I need to know the network key for my Linksys routerWRT54GL-EU in order to establish a wireless LAN to my PC (a Fujitsu moidel) Best regards, Preben Lund prebenlund@plt.dk
    Brigadier General:
  • 10,406 Answers
When you first installed your router, you used the "Wireless Networking Setup Wizard" to"
* set an SSID ("network-name") for your network.
* set an encryption-level. Hint: use 'WPA' or 'WPA2'.
* set a password or pass-phrase for your network.
Enter that password. Or, rerun that Wizard, to create new settings.
Posted on Apr 04, 2011
Driver download
Go to the Linksys support site at
http://support.linksys.com/en-eu/support/adapters/LNE100TX
Jan 28, 2014 | Linksys Etherfast 10/100 Lan Card Lne100tx...
I dont know my wpa key to get online
Use an Ethernet cable between the network-port on your computer and one of the LAN ports on your wireless router.
Start Internet Explorer.
Connect to the web-server "inside" the router.
Run the "Wireless Networking Setup Wizard", to establish an SSID, choose an encryption-level (use 'WPA'), and to establish a password/pass-phrase/network-key.
Use the SSID and the password to connect to your newly-configured wireless network.
Sep 24, 2010 | Computers & Internet
2.4GHz Wireless Lan And 5 GHz Wireless LAN
this is usually caused by your router and your wireless network card are not compatible... you need to purchase as well cisco wireless network card adn tehn when you press your wireless security on the router, it will automatically apply all security protocol to the connection.
if you do not want to purchase new card, you always can setup these devices manually,
connect to the router via rj45 cable, establish what protocol, security and transmission method/frequency you will be using, write that down, disconnect the cable, enter your wireless network card settings and apply same settings to your network card, this should solve the problem.
as you did not stated what operating system you are using and what card is in your computer, this is unfortunately best advice which can be given.
how to set up your router, you have downloadable pdf file on linksys site.
Jul 28, 2010 | Linksys Wireless-G WRT54G Router
I had ATT DSL w/ a linksys wireless router. I was
So, both computers are on the lan segment of 2wire? How many lan ports on 2 wire? Can you do ipconfig from the command line on both computers to see what the addresses are? In most cases, the first 3 octets xxx.yyy.zzz.### should be the same. If not, then 2wire is configured for vlan and the computers are actually on different lan segments & cannot communicate with each other.
Another thing you can do to troubleshoot is to ping each other's address.
You have to first establish there is communication between the 2 systems before troubleshooting further. Otherwise, you could be wasting a lot of time.
Jun 04, 2010 | 2wire (1000-000005-002) 802.11g/b Wireless...
How do I secure my wireless internet? I just got a new laptop and I need to secure the wireless connection before I start using it. I have a Linksys wireless-g 2.4 GHz broadband router and I never secured...
your router has a driver cd..try to run it and set up it again in the installation process you will be prompt to insert security for your wireless lan...create your passsword and your wi-fi will be secured...
just remember your your password so that you can connect to it...
Feb 12, 2010 | Linksys Wireless-G WRT54G Router
Right, do not know what I am doing but here goes....connected desktop pc to wireless router, then tried to do the same with my Fujitsu Amilo laptop and can't, i've gone into adminstrator command prompt...
Make sure first that you know the wireless settings on your router. Take note of the SSID (wireless network name), wireless channel, wireless security settings (WEP/WPA, preshared key/passphrase/wep key/wireless network key).
For Win XP/Win Vista: On the system tray (lower right corner of the screen; near the clock), right click on the double-monitor icon that says Wireless network connection. Then select View available wireless networks.
You should detect the SSID or wireless network name. Highlight it, then if it asks for a network key, you need to type the wireless network key. Then click connect.
Hope this helps!
Oct 22, 2009 | Computers & Internet
Unidentified network which has limited connectivity
You're network card may be disabled, and that would be why you are unable to connect to yout network/the internet through your network card, to check this go to your network settings, right click on the "Local Area Connection" and if the option is there to "enable" then click it because your card has been disabled, if disable is there in stead then I'm stumped. with regards to "unidentified network" This usually comes up when someone has a wireless network created, but they have the settings made to not broadcast (show) the SSID (name) of the network. This is done for extra security, because in order for someone to connect to the wireless signal they need to know the type of encryption used, the key or passphrase for the encryption and on top of that the network name. Limited connectivity means that you are "connected" only in the sense that you can see the network connection, but you are unable to do anything with it.
Oct 14, 2009 | Linksys WRT160N Wireless Router
Wireless router connection problems
Assuming "cannot connect to linksys router directly" means you cannot connect to a Wireless Lan managed by Linksys router,
1) try to connect new computer to LinkSys Router using a Lan cable, add new PC to your network.
2) recover protocol (WEP or WPA) and Key of WLAN (Passphrase or Key: TKIP or AES) either from other PC on same network either from your Router.
3) If you missed actual key you must connect to router and reset it to a new key to be eventually used for every connected device.
Call for detail on this possibility
Dec 29, 2008 | Linksys Access Point WAP54GP Wireless-G...
I am connected to the access point but the internet cannot be found
an Access point is to add Wireless to a LAN. (which is ok if you have a Router connected to your LAN).
if you have no Router,  and only have an ADSL/Cable modem connected to a PC then you should have got a Router +ADSL/Cable modem instead of an Access point.  you can get routers like this which also have wireless, so you get all the functionality in 1 box
Here is a Wireless router, with hub and ADSL +Cable Support
http://www.linksys.com/servlet/Satellite?c=L_Product_C2&childpagename=US%2FLayout&cid=1133202177241&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=7724139789B01
Oct 13, 2007 | Linksys WPC54G Wireless-G Notebook Adapter...
Linksys Wireless-G WRT54G Router Logo
60 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
