Question about Casio EXILIM ZOOM EX-Z60 Digital Camera
Flash wont work
The flash on my camera is not working for some reason... what caused it and how much to get fixed?
  • 374 Answers
Call repairs and they can tell you estimate. 800-706-2534 option 2
Posted on Sep 10, 2008
SOURCE:
Nikon flash repair
On page 190 of the manual (English) are 5 causes why the flash does not fire, and still the camera is ok. there are even some more reasons why the camera can't use the flash.
But most of the time, the battery is not powerful enough to share the speed light. If nothing works, you should visit the Nikon service centre.
Jan 02, 2014 | Nikon COOLPIX P100 Digital Camera
Canon G9 wont power up.
The reason it won't work is because when you went in to fix it, you shorted out the flash. That's what the flash was that you saw when you reconnected it to the main board. It's best not to open these and try to work on them yourself. There are steps to take when servicing electronics and it sounds like you forgot to drain the capacitor first. I'd suggest to go this site and see if they can help you www.camerasandparts.com They're very knowledgable with the Canon cameras and I'm sure they can get working just right again or maybe they can tell you the part you need to fix what you did when you were working on it.
Feb 02, 2012 | Canon PowerShot G9 Digital Camera
Flash wont work
You need to take it in for repair...some cameras can be dropped with minimal damage but not yours.
Oct 08, 2009 | Nikon COOLPIX S200 Digital Camera
Wont take a picture unless I turn off the flash
Here are some simple things to try first for a camera that won't take a picture when the shutter button is pressed, or with an inoperative flash. They won't work for every case, but they're worth a try:
http://camerarepair.blogspot.com/2008/05/simple-fixes-for-cameras-that-wont-take.html
Jun 15, 2009 | Canon PowerShot A710 IS Digital Camera
Wont take a picture with the flash on!! help
Apr 25, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Nikon Coolpix L4 flash not working
This has happened to mine a couple of times. I cannot select flash, and the blur indicator is on most of the time.
Solution is to go into 'menu', select 'SET UP' then 'reset all'. My flash selection then works again.
Since one doesn't tend to set much up with a basic camera like this, resetting shouldn't cause any issues.
Hope this helps
Mar 31, 2008 | Nikon COOLPIX L4 Digital Camera
Flash wont work
This error is shown when the camera can not charge the flash compasitor in the camera it can be fixed with a new flash circuit.
Mar 07, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Flash wont work
i have a vivitar vivicam 3330 and i lost the C.D. to download my pictures on my computer. where can i get a new one??
Nov 22, 2007 | Vivitar ViviCam 3330 Digital Camera
Flash Will Not Operate
Flash doesn't operate from various reasons. Try to reset your camera if you find in the instructions manual a procedure like that. If it doesn't work here are some possible reasons. The flash works because a power inverter will charge a capacitor at about 350 volts. These are required to make a small lightning inside the flash tube. If the capacitor is damaged it will not charge, and the flash woun't work. If the invertor is damaged, it woun't charge the capacitor, and without those 350 volts the lightning inside the flash tube woun't go on. If the components that links the the camera's internal processor to the inverter circuitry doesn't work because of some failure to those components, again the inverter woun't work. Any shortcircuit or open circuit or imperfect contact can result in this. Even if the camera's firmware was corrupted in some way it could fail to instruct the camera to charge the flash circuitry. As you can see there are many reasons for that but only a service center can make the correct diagnostic. It isn't adviceable to dissasemble de camera yourself and tamper with the invertor circuitry as you are exposing yourself to those 350V. You may get some nasty electric shocks or damage other components. Therefore, I think the best aproach to this problem is to have it diagnosticated and fixed by a specialised service facility.
Mar 13, 2007 | HP Photosmart 735 Digital Camera
Casio EXILIM ZOOM EX-Z60 Digital Camera Logo
Top Casio Cameras Experts
Ekse
atollminsk
Level 1 Expert
Parshiv Luthra
Are you a Casio Camera Expert? Answer questions, earn points and help others
