Question about Dryers
How to hook up all four
Hi i bought an older kenmore series 70 dryer and i have a four prong outlet so my cord i need to hook up has like a pony tail of red white black and green but on the back of the dryer is r w &b in one spot then a green wire is like folded back on itself and bolted to the shell of the dryer.
i need to know do i replace it w/ the one from the ponytail or do i overlap the two greens or leave it and just don't connect my green or what?
    Genius:
  • 1,028 Answers
Code says disconnect green wire from dryer and tape off and put green wire from new cord in its place green wire from dryer actually connects right back to white wire
Posted on Aug 06, 2008
What type of power cord do i need?
An electric dryer has an opening in the back, older units use a three prong cord, there will be three posts to attach cord, newer units have four prong cords, Bought separately. there will be four posts to attach, double grounded cord.
Jan 17, 2013 | Admiral Dryer. 6.5 cu. ft. Electric Dryer...
My four prong plug Kenmore dryer is different than my four prong wall outlet. How should I correct this
What you will have to do is buy th correct cord for you outlet. Most homeimprovement stores stock the or appliance store. Get the correct cord for your outlet and replace it on the dryer and it should plugg-in. These are pretty simple to replace with an sdjustable wrench and a screwdriver.
Jan 28, 2010 | Dryers
Changing from a 3 prong to a four prong
grasshopper_2.gifWiring in a new power cord for your electric dryer? Upgrading your electric dryer outlet from the old three-prong to the new four-prong outlet? Well, grab hold of those two large lumps at the base of your spinal cord and let's romp through the wild and wacky world of dryer cords and outlets.
tn_3cord_dryer_terminal.jpgtn_4cord_dryer_terminal.jpgThese two pictures illustrate the power wiring on a the terminal of an electric dryer. The one to the left here is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown to the right. These are just just thumbnail pictures that you can click for a larger view. But I'll bet you already figured that out, didn't you?
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
tn_3prong_dryer_outlet.jpgtn_4prong_dryer_outlet.jpgIf you need to re-wire the outlet, these pictures will explain the anatomy of the three-prong (left) and four-prong (right) outlets. Once again, these pictures are just thumbnails--click 'em for a larger view.
Sure hope this helps you find a resolution to your delimma! Best wishes.
Jul 23, 2009 | Dryers
We have a Kenmore 70 series Electric dryer and it heats just fine and stays hot, air flow is good,(checked), however the clothes are not getting dry. My husband replaced the cord to the outlet from a 3...
Did the dryer get clothes dry in your old home with the 3 prong plug?
If so, id put the 3 prong plug back on it, and switch to outlet to a 3 prong...
Jul 10, 2009 | Kenmore 63942 Dryer
Have a three pronged power cord, need a four pronged power cord
four prong sould be installed as followed, black and red go to eitehr ends( amkes no difference which, white goes to middle and the green wire gets screwed directly to the dryer cabinet itself( usually an existing green screw just outside the connectin box. if there no power after that then check to be sure oyou indded have 220v going to the outlet
Mar 28, 2009 | Whirlpool Dryers
Kenmore series electric dryer need to replace 3 prong w/4 prong
The following link explains how to convert a 3-prong appliance cord to a 4-prong and vice-versa:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
If you still have questions, please let me know. I hope this helps you.
Feb 15, 2009 | Kenmore 62802 Electric Dryer
Install four prong plug kit
hi thanks for the question the green wire goes to the frame of the dryer other wires red to red white to white black to black thanks the appliance doc
Sep 15, 2008 | Kenmore 62872 Electric Dryer
Dryers Logo
100 people viewed this question
Top Dryers Experts
