Question about Timex Expedition WS4 WideScreen 4 Function Watch for Men
I calibrated my Timex WS4 using a known barometric pressure and set the weather conditions but the watch is telling me I'm at an altitude of -42 meters (which I'm not) and the temperature is at least 10 degrees too high (I'm not wearing the watch)
    Genius:
  • 1,689 Answers
You should carefully read the manual on this watch. It is a very sophisticated instrument realitive to its cost.
The barometric pressure in the CAL mode is set to the reference sea level. The pressure that is read in the other areas is the actual or relative pressure at your location.
There are some tollerences for the accuracy of these watches. What they are excellent at is seeing the relative differences or changes. I found that when I set the reference barometric pressure (Sea Level Pressure), everything falls in to place. I found the WP4 to be accurate to within about 15 to 20 feet accuracy for altitude most of the time. It is important to periodically check the barometric pressure from the weather office if you want it to be as accurate as possible.
When hiking or out trecking, it is advisable to check the watch's altitude relative to the map that you are using, or to a known reference. Then as you travel you can check for the altitude change.
Take care that this type of watch is to be used as a quick or easy reference only. It is not certified to be used in situations where life and safety are fully dependent on the readings from this type of watch. It is a precision instrument, but not as precise as the high end professional certified types. It is best to refer to proper maps (charts), and depend on a certified mechanical compass for absolute reference.
Jerry G.
Posted on Oct 28, 2012
  • milanhalajml
    milanhalajml Dec 25, 2012
    Hello Jerry, maybe u can help me. I did set up Baro, Alti and Weather on my WS4 watch. The problem is the watch wont show me the graph after 24hours of calibration. Is it normal?
2 Suggested Answers
Noggin
  • 944 Answers
SOURCE: Incorrect altitude changes
Here is the link to the user manual for this watch if you need it; http://www.lacrossetechnology.com/k2100/manual.pdf page 12 gives you all the contact details for lacrosse. I couldnt find the info online to be sure, but some of these watches do have a separate pressure sensor for altitude and barometric pressure, and sometimes the path to one could get blocked or it could become faulty. I would contact la crosse and find a dealer to get the watch serviced, you could probably do it yourself but you need to get replacement seals from them anyway (these are important). ask them to check if the sensor is clogged, it happens sometimes. Hope this helps :)
Posted on Apr 14, 2007
The compass on myTimex WS4 fails to calibrate. Have tried removing the battery and resetting everything but still no joy. Is the any other way to calculate the compass?
There is a process to make an all reset. After the reset try again. The user user manual can be downloaded from Timex. Make very sure the watch is absolutely flat and far from metal objects. Even being near most furniture can effect the reading because they can have metal springs. Many homes have a lot of metal in their construction. It's best to calibrate the compass out doors away from power wires or cars or anything metal. On the street you can have metal under the pavement.
If this does not work call Timex. There have been instances where the compass module or sensor had to be changed. I have the same watch. It's a very good one.
Sep 25, 2014 | Timex Expedition WS4 WideScreen 4...
Is there a reset button on my timex ws4
Yea, but it isn't a button. This is probably two 'pads' on the circuit board within the movement of your watch that need to be 'shorted' together with metal tweezers. Consider a watchmaker.
Oct 06, 2012 | Timex Expedition WS4 WideScreen 4...
Can not seem to set my altimeter on the ws4 timex i have tryed do this but it is giving me the wrong hight ? and know one in the shops can figger this out to????? what am i doing wrong iv tryed to folow...
Setting and Calibrating Your Altitude
1. Press MODE until CAL is shown.
2. Hold SET to begin the calibration.
3. Press START/SPLIT (+) until HOME ALTI is displayed (or choose WEATHER when calibrating weather).
4. Press MODE (NEXT) to begin the setting process.
5. Press START/SPLIT (+) or STOP/RESET (-) to increase or decrease setting values.
6. Set the value to your current elevation.
7. Press MODE (NEXT) to advance to the next setting option.
8. Press SET (DONE) to finish.
9. To complete calibration for the REFRENCE HOME altitude (or WEATHER setting), press and hold STOP/RESET until watch beeps.
Repeat this procedure for WEATHER, making sure to choose the proper weather condition on the WS4 that matches your current weather.
Once these two variables are calibrated, your WS4 will be ready to go, providing you with accurate altitude, pressure, and weather forecast information at your fingertips. Enjoy.
Jan 05, 2010 | Timex Watches
How does the altimeter function work? we can't find it on the enclosed instructions
Altimeters on watches are usually based on barometric pressure, since the pressure changes all the time you generally need to adjust the altimeter to a known altitude. You can look on USGS website to find the altitude of your area, or simply type in "altitude of city, state" in a search engine.
I hope I understood your question; if not, please reply.
Oct 17, 2009 | Timex Adventure Tech Altimeter 41501 Wrist...
Altimeter setting creeps up on Suunto Vector
It sounds like IC (integrated Circuit) in your watch is mulfunctioning, but can be something else. Can't say without inspection.None of the readings mentioned by you is acceptable.
As the watch is purely microelectronic, there is nothing you can do but to take it back to the retailer and ask for repair or replacement. If your watch is just 10 days old, this must be done under warranty and at no cost to you.
Don't forget to rate, please.
Jan 05, 2009 | Suunto Vector Wristwatch
Alti does not read correct alti.
Don't forget that the altimeter is barometric, and therefore the altitude reading will change depending on the air pressure - i.e. the weatherman may give the 'high pressure coming through' or that there is a low pressure giving rain - to get the true altitude, you need to know the true air pressure at any given point on the earth ~(where you are) then set this as the 'normal'. you will then get the correct altitude. Don't forget that if you are in a pressurised aircraft - as in allcommercial flights, the cabin air pressure is artificially kept at appx 4000-6000ft altitude
Dec 02, 2008 | Casio PRG-40T-7 Pathfinder
Jun 18, 2006 | La Crosse K2-100 Wrist Watch
Timex Expedition WS4  WideScreen 4 Function Watch for Men Logo
850 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Brett Duxbury
Brett Duxbury
Vladimir Frolov
Are you a Timex Watch Expert? Answer questions, earn points and help others
