Question about Ovens
We have an old cannon pearl duo cooker 10243G. The auto light is continuely flashing and will not turn off using the instructions from the manual. I am also unable to set the time. Is there anyone out there who can help us? We have tried turnering the whole cooker off and on again. Until the auto light turns off the gas with not start. Thanks
jason0110
  • 66 Answers
SOURCE: hotpoint electric cooker sy36
it sounds like you have had bad insalltion caused by your element becoming open circit try replacing and this should solve your problem regards jason
Posted on Sep 14, 2007
SOURCE: "door lock" light stays on and oven won't work
This happened to me, had the appliance repairman come out to fix. He hit and held a combination of buttons on the oven controls and reset the panel somehow. But now I don't know what he hit to clear it. Do any of you?
Posted on Jan 16, 2008
SOURCE: No gas to lower oven - Cannon Camberley
Hey Stephen - try setting the clock then set the cook period. the oven will only work when that's on i think.
Posted on Jun 10, 2009
SOURCE: cooker clock
Look here, it is a different model, but the clock maybe the same
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Creda/Cooking/HB48904_489000069-05.pdf
Posted on Jun 22, 2009
barkencoa
  • 3463 Answers
SOURCE: Cannot set time and Oven will not operate
Depending on the make of oven, you have to press the buttons in a certain sequence if it is a digital one, try pressing the buttons in sequence, sometimes you have to press 2 together, and a third one at the same time,if it is a anologue timer, then make sure you can see the symbol of a hand in the display.
If you cannot get the timer of auto, then it is probably faulty.
Please rate my solution.
Thanks.
Posted on Jul 19, 2009
Stoves 720G Manual
SOMEONE POSTED
However...I discovered the little buttons on the timer come out completely. So I used a cocktail stick to poke about inside the holes where the buttons go till the Auto mode light disappeared and the cooker went back to manual. And my oven works again as before.
Jan 04, 2015 | Stoves Ovens
Hi, I've tried to programme my cooker on auto following the instructions, everything works apart from when the time comes to turn the oven off automatically it doesn't work. The buzzer goes...
Are you sure it's the oven still running and not the built in cooling fan...next time look at the fan at the rear of the oven if it's not turning it's off and you will be hearing the cooling fan
Oct 08, 2017 | Ovens
The ovens on my Indesit FIU20I cooker won't heat; the display is flashing and the manual says to reset the clock but I can't... apparently if the automatic cooking function has been selected you canno
Does the "manual" button not do anything in this state?
Have you tried this sequence?:
SETTING THE TIME OF DAY
Step 1 Make sure all oven controls are turned Off.
Step 2 Check the electricity supply to the cooker is turned on.
Step 3 When switched on the display will show 0.00 and the Auto symbol,
flashing intermittently.
Step 4 Press & hold in both the Cook Period & End Time buttons together.
Step 5 With the Cook Period & End Time buttons still held in, press either the "+"
or "-" buttons to set the correct time of day.
Step 6 Release all the buttons simultaneously.
Oct 30, 2014 | Ovens
The bottom oven on my zanussi zuq 875 has stopped working. No power indications of any kind.Top oven works fine. Followed instructions in manual but no power at all.ie; indicator lights, fan ,oven light....
Have you checked that the timer clock is set and not flashing,because the rest of the cooker will work after power outage but for the main/fan oven to work the clock needs resetting.
Hope this helps.
Jun 13, 2010 | Zanussi Ovens
Cant turn cooker on
Depending on the brand of oven, you need to get it off auto, and onto manual to be able to use oven.
You should find the info you require in your user manual.
Thanks.
Sep 22, 2009 | Ovens
Creda europa solar plus double oven
Hi, hold down the minute and cook button and at the same time hit either the plus or 1 button to set a time and then oven will work. each time the power is off this needs to be done. hope this helps
Dec 02, 2008 | Ovens
Ovens Logo
287 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
