Question about Toshiba Televison & Video
Does the fan in the DVD video recorder/ video cassette recorder\r\nD-VR7KC2 always run even when the machine is turned off?
  • Toshiba Master
  • 467 Answers
No, the fan is not meant to run all the time, and not with the unit in standby. The fan in many DVD recorders is usually only meant to be active whenever a disc is loaded and is either recorded or played back - the fan is designed to circulate the airflow for the DVD drive and its associated digital controller circuit. If the fan is still running even after you ejected all discs/tapes, and turned the unit off at the front, then it will require a service technician's attention in a fully equipped workshop. If the fan does not run when the unit is in standby, then you have no fault; it is a normal condition.
Posted on Apr 05, 2011
Tip
How to record a program you are watching on your cable satellite receiver.
Hello,<br /><br />Most of the time we watch TV programs with our cable satellite receiver/decoder. And sometimes we would love to record these programs so that we can watch them again. You can learn how to record your TV program while you watching a TV program. <br /><br />All you will be needing is a DVD recorder or VCR (Video cassette Recorder). It all depends on the one you prefer.<br /><br />There are two methods of doing this connection. 1. is RF connection and the other is RCA. But I will start with the RF connection method;<br /><br />This is how is works. Get a RF cord, check the back of your TV, you would see RF in, connect the RF into TV in, then connect the other part to RF Out at the back of the Cassette or DVD Recorder.<br /><br />Turn the Cassette or DVD Recorder and the TV on. Go to Channel 1 or any channel on the TV, search the TV stations automatically or manually in order to get a display of the Cassette or DVD Recorder on the TV. To easily get the Cassette or DVD Recorder's station, play a movie on the Cassette or DVD Recorder while you search for the station. Once you see the display of the movie on your TV, you would easily know that that's the Cassette or DVD Recorder station. <br /><br />Once you have gotten a display from the Cassette or DVD Recorder, save the channel on the TV.<br /><br />Then get another RF cord, connect it to "RF out" at the back of the Satellite/cable decoder/receiver and the other part to "RF in" at the back of the Cassette or DVD Recorder.<br /><br />Now with the Satellite/cable decoder/receiver turned on and the Cassette or DVD Recorder also turned on, press the Cassette or DVD Recorder's channel, you should find search. Scan for channel/stations on the Cassette or DVD Recorder just like you did on the TV and you will find a display of the Satellite/cable decoder/receiver showing on the TV via the Cassette or DVD Recorder. Note that on some Cassette or DVD Recorder, you will have to select "Source" to RF before you can get a display of the channel.<br /><br />Now since the Satellite/cable decoder/receiver program is now showing via the Satellite/cable decoder/receiver, insert a black disc or cassette into the Recoder and press record. The Satellite/cable decoder/receiver programs showing on the TV via the player will be recorded and that would be all.<br /><br />For some recorders that has internal hard drive, you can just press record without inserting a blank disc......<br /><br />USING RCA CONNECTION METHOD.<br /><br />You could also achieve this by using a RCA (yellow, red and white cord).<br /><br />The connection procedure is the same with the RF explained above.<br /><br />Connect the Recorder to the TV. That is, from "Video and audio Out" of the recorder to "video and audio in" of the TV accordingly. Press AV or source on the TV to confirm that there is a display from the recorder on the TV.<br /><br />Now connect the RCA cord to "OUT" from the Satellite/cable decoder/receiver to "IN" at the back of the Recorder.<br /><br />Then, press source on the recorder to "INPUT" (RCA) and the Satellite/cable decoder/receiver's program will automatically display on the TV. <br /><br />While the Program is being displayed on the TV via the recoder, insert a blank disc and press record on the player and it will automatically start recording. You will see the record or record symbol while the recoding is in progress.<br /><br />I hope you understand the above. Please follow steps closely and you won't have any problems.<br /><br />Good luck.
on Mar 09, 2011 | Televison & Video
Video Cassette is being automatically ejected when I insert it for viewing
You need to take the cover off and look inside to see if there is something inside that should not be. Perhaps you can look with a flashlight through the entrance hole. You could pick up the machine and shake it and see if anything is rattling around. These things have many plastic and nylon parts which can break over time and the machine will sense a problem and eject. If you cannot find a problem by the suggestions above then it will need to go for repair-unfortunately it would probably cost more than it is worth to have it repaired.
May 16, 2014 | Goldstar GBV241 DVD Player/VCR
Nd.comI have a set top box awa DT 2030 trying to connect to a standard tv through a video recorder/player what are the instructions as I cannot get it to work
Hi, With new DTV's these days, there will be problem running old players.(VCR) Video cassette recorders will not be able to record Digital signal. You will have to get (PVR) personal video recorder which can record and play Digital programs with great picture.
Jun 11, 2011 | Televison & Video
Panasonic DMR-E85H
No VCR required - A VCR is a video cassette recorder, which requires a video cassette in order to record source material. A DVD recorder, requires DVD discs and this model in particular has a built in hard drive so you don't even need discs either, unless you plan to share recordings with others. All you need is a 'feed' / 'source' from an external aerial like Cable or Sky etc.
Does that help?
Mar 01, 2009 | Panasonic DMR-E85H DVD Recorder
I want to transfer material from video cassette to dvd. I have a Sony cassette recorder slv- se610g and a sony dvd recorder rdr-gx3. Can you please tell me how?
Though Connection details are available in DVD recorder User Manual, yet here is procedure. Find Video Audio Out terminal on Cassette Recorder SLV-SE610G and hook Yellow-Red-White cable in matching color pins and other end of cable will hook in Video Audio Input terminals at DVD Recorder RDR-GX3 and please note, same color pins will be hooked. Insert desired VHS cassette in VCR and push Playback. select input source at DVD Recorder and confirm playback picture and sound of vcr at TV. Now system is ready to record VHS movie on DVD.
If you need further info, please post back here.
Aug 19, 2008 | Televison & Video
Record onto DVD
No. This machine only plays DVDs. You would have to obtain an entirely different machine. One that is a DVD Recorder. This one is a DVD Player + Video Cassette Recorder
Apr 28, 2008 | Zenith XBV243 DVD Player/VCR
Sanyo DVD Player & Video Cassette Recorder - DVD-7200
dvd does not play but video cassette does...fixable???????
Apr 16, 2008 | Sanyo DVW-7200 DVD/VCR
JVC DVD Player/Video Cassette Recorder Model HR-XV2EK
try to clean your machine by playing a lens cleaner disc coz the lens might be dirt enough not to pick on data from the discs you play. if it does not work then isuggest you change the lens coz it might be weak
Aug 01, 2007 | JVC DR-MV1S DVD Recorder/VCR
Televison & Video Logo
96 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
