Question about Mtd Products Yard Machines 158CC Tiller
How do you get the gear box asy apart,Ive removed everything and can only get it spread apart about 3 inches.
You need to remove all rust from wheel and tine shafts
Posted on Apr 05, 2011
Do you have a handle set with a 7 inch spread instead of a 8 3/4 spread and model #
Yes we do. how many would you like?
  • Kingston Brass CC543T8 Vintage 7-Inch Spread Wall Mount ... www.amazon.ca/Kingston-Brass-CC543T8-Vintage-7-Inch/dp/B0026ZPI0Y
    • KINGSTON BRASS
    Kingston Brass CC543T8 Vintage 7-Inch Spread Wall Mount Leg Tub Filler with Hand Shower, Satin Nickel in Showerheads & Handheld Showers.
  • Kingston Brass KB967 Magellan II Widespread Lavatory ... www.amazon.com > ... > Rough Plumbing > Faucet Parts > Faucet Handles Kingston Brass KB967 Magellan II Widespread Lavatory Faucet 8-Inch to 16-Inch Centers 7-Inch Spout Reach, Satin Nickel and Polished Chrome
  • images of 7 inch spread faucet bing.com/images th?id=oip.m9aaf750d3da8ce6a24cbe32ef9078ae8o0&w=103&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.m643aef6e35c24789db3419b21dd47a91o0&w=103&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.ma09426c72dcc25d64ff92045ab194af1o0&w=103&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.m9b0dc70d9ab53ad1ecca18fd130db74bo0&w=103&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.m9afd6495c16d35699054f30b9ee4d7e7o0&w=104&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2 See more images of 7 inch spread faucet
  • Water Creation F6-0007-05 Vintage Classic 7-inch Spread ... www.overstock.com > ... > Bathroom Faucets > Water Creation
    • 5/5
    • 1 RATING
    • $409.17
    Shop for Water Creation F6-0007-05 Vintage Classic 7-inch Spread Deck Mount Tub Faucet with 2-inch Risers and Handheld Shower. Get free shipping at Overstock.com ...
  • Apr 16, 2016 | Plumbing
    Everything in the cluster works apart from the odometer, ive tried resetting the trip computer but no luck any help is much appreciated, is it possible the guy that sold it to me pulled a shifty and wound...
    CHECK THE SPEED SENSOR ON THE GEAR BOX WHETHER THE CONNECTOR IS EITHER BROKEN,DISCONNECTED OR THE SPEED SENSOR STOPPED WORKING AND NEED REPLACEMENT.
    Nov 08, 2012 | 2005 Holden Rodeo
    G/day i need help puting in a new clutch kit into a 99 leganza the car is off the ground wheel is off now do we start by taking off/or dropping the passenger side suspension and all so the plastic covers...
    It's best if you get a manual on this. Some times it is easier to remove the engine and transmission. some times you can remove enough of the steering and wheel parts to spread the trans and engine apart to get a clutch package out and in. these are always a look and see type job. They are difficult to do, not impossible. You also have to remove both drive shafts, so both sides have to come apart as you have stated.
    Apr 23, 2011 | Daewoo Leganza Cars & Trucks
    I have been told that my 98 Dodge truck which has 56,000 miles needs a new steering gear box. Steering wheel has about 2 to 3 inches of slack. Have put on a track bar and a tie rod for 700 bucks and still...
    The gear boxes are just cheaply designed and made, its a very very common problem with these Dodge's. Even the new ones experience whats called the "death wobble", where the truck will all of a sudden veer left or right. The most common things ive replaced on these trucks to cure it is the track bar, and the gear box. $500 sounds about right for a new one, they arent very cheap.
    Mar 28, 2010 | 1998 Dodge Ram 1500 4WD
    1998 Ford Explorer: No heat. Checked everything and can't find the problem. New thermostat was installed. still no heat.
    take out the glove box, you will see a white box about 3 inchs square with wires pulged into it, this is the diverter control,take the screws out, and remove it, then see if you cand move the diverter by hand too get heat, if you can then you need too replace the control or just lock the diverter in the heat position, i had this same problem last week in a 98 explorer and liked too never found it , ive got heat now!!!
    Feb 09, 2010 | 1998 Ford Explorer
    Yardman Rear Tine Tiller tines won't turn. Belt and tenson good. Belt will drive rear wheels in forward or reverse but tines will not turn. when I trun tines by hand nothing seems to be turning in the gear...
    The problem lies in the shift lever in the gearbox. A poor initial design that was upgraded twice. The shift fork arms have spread enough for pins to come out of the groove they run in when the tiller is shifted to the last position. (Bending back into position would only be a temporary fix as would not be any stronger.) To replace shift lever, the gearbox cover has to be opened. Seperating the cover can be somewhat challenging. When prying cover apart try to not damage the cover gasket. Gearbox grease is very thick, so gasket's real purpose is to keep water and contaminants out. Leave all gearing and chains in place. The shift lever part number is 618-0245B. Or use assembly kit number 753-0869 (contains shift lever 618-0245B, position indicator, and roll pin.) Part will run in the $56-$68 range and can be found through MTD as well as Cub Cadet. Also can get through Sears PartsDirect.
    Jul 26, 2009 | Mtd Bronco Rear Tine Tiller
    Front fork too narrow to fit tire
    sounds like the box may have been squashed. send it back to where you got it from or its not that hard to spread the forks apart by pulling them. used to do this all the time when servicing mountain style bikes that have been thrashed by customers :)
    Jul 06, 2009 | Razor Fz 2000 20-Inch Freestyle Bike
    1994 RCA P52753 Rear Projection
    Sounds like the screen asy has failed causing the color to change from black and white,turn your color all the way down and see it the picture is green,blue,or red,if so the asy is bad or the tubes are getting alittle weak,the asy is in front of the set behind the speaker grill,there is a access panel to remove and the asy has 6 controls to adj.,only move the ones that are marked screens below them,this asy is black and is only 4 inches square,do not move any adj. on the tubes
    Mar 06, 2008 | RCA D52W19 52" Rear Projection Television
    Color fading on Sony could be cable ?
    have the cable company come out and check there cable box and picture.
    Jan 28, 2008 | Sony KV-27V22 TV
    Mtd Products  Yard Machines  158CC Tiller Logo
    81 people viewed this question
    Top Mtd Garden Experts
    Roland W VanLue
    Roland W VanLue
    Tim Whalen
    Phil Walker
    Phil Walker
    Are you a Mtd Garden Expert? Answer questions, earn points and help others
