Question about Mercury Appliances 2002 02 Mercury Sable Radio/harness/mounting Kit
Door open alarm won't clear so dome light stays on, and outdide courtesy lites on also. Have checked all doors and they are closed. Thanks,
    President:
  • 1,961 Answers
This is usually caused by the door switch plunger sticking (due to dirt, other elements or rust). The switches are on the backs of the door latch assemblies inside of the doors.
This can often be corrected by performing the following:
1. Thoroughly spray the door switches (on each door) with:
  • Cleaning spray - clear the sludge out of the mechanism - electronic contact cleaner, carb, brake, etc
  • Air, canned or even better, from a compressor
  • Spray lubricant - a dry lube (best), silicone spray, WD-40 or similar
2. Open and close each door several times to work the lube into the mechanism. This is usually sufficient to clean the electrical & plunger mechanism inside the door switch. If this doesn't work, you could remove the door panel and do the spray treatment from the inside also. Spray a whole bunch of WD40 up inside the latch itself. I mean drown it until oil starts running out underneath. Do all the doors, and see if the problem goes away.
That will fix it, if not If not, then you will need a new door latch switch on one of the doors.
Good Luck!
Posted on Apr 04, 2011
2009g6 dome light comes on all by its self why
The dome lamp switch has 3 positions: DOOR, OFF, and ON. When in the DOOR position, the dome lamp operation is controlled by the body control module (BCM).The ON position provides a ground for continuous operation. Ground is provided at G302. The OFF position turns OFF any dome lamp operation. The courtesy lamps, may be manually turned ON by placing the instrument panel (I/P) dimmer switch in the DOME position. When the dome lamp switch is in the DOOR position, the dome lamp will illuminate when a door is opened. When a door is opened, the courtesy lamps turn ON. After all the doors have been closed, the courtesy lamps will remain illuminated approximately 10 seconds after the last door closes. When the driver places the dome lamp switch in the OFF position, the dome lamp will be disabled.
Do you hear any chimes when the light comes on ? Door ajar switch problem , maybe . Picture of car with door open light lit on the instrument cluster ? When does it come on , when driving or sitting still or both ?
You mite want to take it to a qualified repair shop and have it checked for DTC'S - diagnostic trouble codes .
DTC B2555 05: Passenger Compartment Lamp Control Circuit Short to Battery or Open
The body control module (BCM) applies battery voltage to the courtesy lamps through the courtesy lamps high control circuit. When any door is opened, the door ajar switch contacts close and the BCM receives a door-open input. If the BCM receives a door lock or unlock input or a rear hatch open input, the BCM will activate the courtesy lamp high control circuit, providing battery voltage to all of the dome lamps, reading lamps, rear compartment lamp, and vanity mirror lamps. In the event that any of these lamps were to remain illuminated for more than 20 minutes with the ignition switch in the OFF position, the BCM will deactivate the courtesy lamp high control circuit to prevent a total battery discharge condition.
Do you know how to do basic automotive electrical testing ? How to test inputs and outputs of a control module ? in this case the BCM - body control module ? Find wiring diagrams at
http://www.bbbind.com/free_tsb.html also watch this video ECM Inputs and Outputs Diagnosis
Jan 19, 2017 | 2009 Pontiac G6
Can't get dome lights on when door is opener even with override switch off?
The following lamps may be manually turned ON by placing the interior lamp switch in the ON position, or by opening a door while the switch is in the AUTO position.
The dome lamp
The liftgate lamps
Courtesy/map lights
The courtesy lamp supply voltage circuit of the body control module (BCM) supplies battery positive voltage to the dome lamp, the liftgate lamps, and the map lamps. When any door is opened, the door jamb switch contacts close providing a door open input to the BCM. The BCM then provides a ground to the interior lamps with the switch in the AUTO position. The interior lamps receive a ground at G401 with the switch in the ON position.
Important: If the liftgate is opened after all the modules go to sleep, the dome light will not come on. The liftgate ajar switch input to the BCM will not wake up the BCM once it has gone to sleep, so the dome light will not come on. Once the BCM gets an input to wake it up, from remote keyless entry (RKE) or a door handle, the dome light will turn on when the liftgate is opened.
If the driver inadvertently leaves any interior lamp ON, the BCM will turn it OFF after a 20 minute time-out.
The courtesy lamps will turn OFF immediately if the ignition switch is turned to the ON position or approximately 20 seconds after all doors are closed.
The courtesy lamps are controlled by the body control module (BCM). Inputs from the dome lamp switch and the door ajar switches are monitored by the BCM. When a door ajar switch is closed, or the dome lamp switch is turned to the ON position, the BCM supplies the B+ for the courtesy lamps.
With out a factory Tech2 scan tool or equivalent an knowing how these systems work ,you best bet is to take your vehicle to the dealer or some other ASE certified repair shop !
Sep 04, 2015 | 2009 Buick Enclave
Interior lights
This is both a courtesy and safety issue on many high end vehicles. The light from the interior lights can cast enough light to get to front door and possibly show dangers in your path. And after first getting into you car and starting it, you can check the back seat for any unwanted hitchhikers. As for the 10 minute timer, I don't know if this can be adjusted. A Chiltons/Haynes repair manual for you car may have that answer, or, the Buick dealership shop foreman. Best of luck.
May 31, 2015 | 1998 Buick Park Avenue
Dome light and courtesy light stays on in my 1987 S-15 GMC Jimmy even when car is off and doors are closed
courtesy lights have a 3 position switch 1 is for doors open --on /off 2 is for light off permanent and 3 is for light on in car permanent for reading etc. Other than that check the door switches for a permanent earth fault.
Apr 23, 2013 | 1997 GMC Yukon
93 buick regal courtesy lights stay on when car is off
One of your door sensors (or trunk sensor) is signaling that it is open or the dimmer switch is turned all the way up, which turns on the dome and foot lamps. Try turning the dimmer switch all the way down. If this does not fix the problem you will have to get all the door sensors (and trunk sensor) tested to determine which one needs to be replaced.
Mar 15, 2010 | Buick Regal Cars & Trucks
2001 Sequoia, door ajar light goes off, but dome light stays on. Door ajar light comes on with slight pressure against closed door. Can replacing the door jam switch solve this problem? Why would the door...
To temporarily solve the light problem, I taped a washer to the inside of the door where the door hits the plunger on the light switch. A permanent solution would be to drill a hole in the door at this spot and put a self taping screw in that will trigger the switch sooner. I figured out the reason the dome light stayed on is due to the courtesy light timer and the lights would have eventually gone off.
Nov 12, 2009 | 2001 Toyota Sequoia
My 2001 pontiac sunfire dome lights, and reading lights dont work. when i open the door there is also no beep sound. check fuses they seem to be ok. what else should i check?
hello,
is this problem only with the drivers door? or all doors?
if it is just one door you should check the door open courtesy light switch located in the door jamb (it will be in the jamb towards the hood only accessible with the door open) its a small cylinder shaperd switch that sometimes sticks due to corrosion. if its stuck the car has no idea the door is open. if it is stuck try and free it up with some pliers and lubricate with some wd40. another thing could be that the lights are burnt out. check this by turnig your dome lights on manually by turning the headlight switch (this adjusts your gauge lights) all the way until it clicks ...your dome light should be on if not repalce bulb and try again.
As far as the door ajar beep...do you have an aftermarket stereo installed...because the stock radio makes the chime throught the drivers side speaker...
i hope this helps
Aug 14, 2009 | 2001 Pontiac Sunfire
Ctsy/dome lites remain on dimly when door is closed
Try removing one bulb or the other at one time preventing power completing the circuit if the problem in a light. Those ones are tuff to find but second place I would start is removing front door cils and cleaning out and playing with wires in there to see if you can find a problem, also wires in the boot between door and frame, usually drivers side cause it's used more often.
Apr 11, 2017 | 1987 Chevrolet S-10 Pickup
2004 crown vic interior lights stay on
Don't think you have a door ajar switch problem , more then like the lighting control module is the culprit . Does the door ajar light on the instrument cluster stay lit ?
The interior lighting can be separated into two distinct modes of operation: the courtesy lighting and the demand lighting. The lighting control module (LCM) controls all of the interior lighting in the vehicle, as described in the following text.
The front dome lamps, rear reading lamps, and instrument panel courtesy lamps, can be illuminated either by opening any of the vehicle doors (courtesy lamp function) or by depressing the headlamp switch (demand lamp function).
When any door is open, the door ajar switch grounds an input to the LCM which then sends power to the courtesy lamps. The voltage sent to the courtesy lamps gradually increases from 0 volts to 12 volts within 500 ms (± 50 ms), to achieve the theater lighting effect. When the door(s) are closed the door ajar switch(es) break(s) the ground to the LCM input which then gradually reduces the power from 12 volts to 0 volts within 5 seconds. (± .5 second).
When the headlamp switch is depressed it grounds an input to the LCM which in turn sends 12 volts to the front dome lamps, rear reading lamps, and instrument panel courtesy lamps. When the headlamp switch is depressed a second time, it breaks the ground to the LCM input which then ceases to send power to the front dome lamps, rear reading lamps, and instrument panel courtesy lamps.
The battery saver will disrupt power to the courtesy lamps after 10 minutes, the demand lamps after 30 minutes, and the headlamps after 10 minutes. Turning the ignition switch to the RUN or ACC position will terminate the battery saver feature by disabling the interrupt timers and reinstate power to the lamps.
Do you know what DTC'S are ? diagnostic trouble codes !
LCM Diagnostic Trouble Code (DTC) Index DTC Description Source Action B1322 Driver Door Ajar Circuit Short to Ground LCM Go To Pinpoint Test F . B1442 Door Handle Switch Circuit Failure LCM Go To Pinpoint Test G . B1445 Door Handle Switch Circuit Short to Ground LCM Go To Pinpoint Test G . B1563 Door Ajar Circuit Failure LCM Go To Pinpoint Test C . B1566 Door Ajar Circuit Short to Ground LCM Go To Pinpoint Test H . B1685 Lamp Dome Input Circuit Failure LCM Go To Pinpoint Test I . B1687 Lamp Dome Input Circuit Short to Battery LCM Go To Pinpoint Test I . - All Other DTCs LCM REFER to Section 419-10 .
PINPOINT TEST C: THE COURTESY LAMPS STAY ON CONTINUOUSLY CONDITIONS DETAILS/RESULTS/ACTIONS C1 CHECK THE SYSTEM OPERATION Open and close each door, making sure that each door is completely closed.
  • Are the courtesy lamps still illuminated after the 25 second time-out period?
Yes GO to C2 .
No The system is operating correctly. C2 TEST DOME LAMP SWITCH Depress the dome lamp switch.
  • Are the courtesy lamps still illuminated?
Yes DEPRESS the dome lamp switch a second time. GO to C3 .
No The system is operating correctly. C3 CHECK THE LIGHTING CONTROL MODULE
LCM C2145a
Yes REPAIR circuit 53 (BK/LB). REPEAT the self-test. CLEAR the DTCs.
No INSTALL a new LCM. REFER to Section 419-10 . REPEAT the self-test. CLEAR the DTCs.
Apr 16, 2017 | 2004 Ford Crown Victoria
Mercury Appliances 2002 02 Mercury Sable Radio/harness/mounting Kit Logo
26 people viewed this question
Top Mercury Appliances Car Audio & Video Experts
xxxxxx xxx
Are you a Mercury Appliances Car Audio and Video Expert? Answer questions, earn points and help others
