Question about Gigabyte (GA-880GM-D2H) Motherboard
I have 880 motherboard with amd phenom quadcore the fan is to loud can any one give me an idea what fan would suit and make less noisy as its to load.
    Brigadier General:
  • 10,406 Answers
Some fans are temperature-sensitive, i.e., when the CPU is "hot", the fan spins at high-speed, with more noise. For other fans, you can restart your computer, and enter BIOS SETUP, and set the speed of the fan, e.g., 50% or 70%, to make it quieter.
Posted on Apr 04, 2011
Can you tell me if AMD Phenom X4 9550 95W works with motherboard ASUS M2V-MX? Or if just that motherboard support quadcore CPU?
go to Asus web site and get the pecs for the board. it should tell you what processors will work with the board.
Feb 27, 2015 | AMD Phenom X4 9550, 2.2 GHz...
Problem with AMD 2.1GHz Phenom X3 Tri-Core 8450 AM2+ 3.5MB HD8450WCJ3BGH
Your motherboard might finally need replacement. If the temperature sensors aren't working and the motherboard isn't controlling the CPU fan, that shows you might have some problems with it. Did you try going into BIOS Setup and checking your settings? Check the cooling settings. Many motherboards have aggressive CPU temp monitoring as well, so if the CPU gets hot, the PC will shut down.
Jan 09, 2014 | AMD 2.1GHz Phenom X3 Tri-Core 8450 AM2+...
Toshiba L675D-S7014 CPU Upgrade
From what i can tell you can use
AMD Phenom II X940
Jun 21, 2013 | Toshiba Computers & Internet
Upgraded cpu and fan om HP p6320y desktop won't stay powered up
The AMD Phenom II X4 850 (HDX850WFK42GM) uses up to 95 Watts of power,
http://www.cpu-world.com/CPUs/K10/AMD-Phenom%20II%20X4%20850.html
(Electrical/Thermal parameters)
While the AMD Phenom II X4 965 uses up to 125 Watts, or 140 Watts; depending on which Part Number....
HDZ965FBK4DGI uses up to 140 Watts.
HDZ965FBK4DGM uses up to 125 Watts.
http://en.wikipedia.org/wiki/List_of_AMD_Phenom_microprocessors#.22Deneb.22_.28C2.2FC3.2C_45_nm.2C_Quad-core.29
Scroll down a little.
I'm going with Not enough power from the Power Supply.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01969880&tmp_task=prodinfoCategory&cc=us&dlc=en&lc=en&product=4120661
Power Supply is ONLY 300 Watts?
Yes, the Power Supply is too small IMHO.
Is there also a graphics card you have installed, and not stated?
Regards,
joecoolvette
May 14, 2013 | Computers & Internet
CPU upgrade for ACER rs780hvf
you could upgrade to AMD PHENOM II X4 960T but you should probably try and overclock and save your money.
Apr 03, 2012 | Computers & Internet
Can processor AMD Phenom X4 9650 Quadcore to use motherboard Asus M4A78T-E ?
you cannot use m4a78t-e to amd phenom x4 9650 because it does not support am2+ socket, it only support am3,phenom II,sempron 100, and athlon II processor.
Aug 18, 2011 | AMD 2.3GHz Phenom X4 Quad-Core 9650 AM2+...
With asus m4a785-m motherboard and amd phenom x4 9600b quad core cpu why does monitor displays a cpu fan error when fan is running full speed.
Hmm, I've never seen a computer give a CPU fan error. Maybe if the fan is really dusty it's clogging it up, try getting some canned air and spraying it out.
Dec 17, 2010 | ASUS M4A785M Motherboard
AMD Athlon 64x2 brisbane 2.9 ghz fans too loud now WHAT TO DO!!!
If you have no heating problems,and you used good cooling paste ,for resplace the CPU ,only loud problems, you can leave the original copper core cooling fan.first reset the pc, when you see the Welcome window of the motherboard (ASUS FOXCOMM, BIOSTAR ECT) click delete repeatedly, you will enter the bios setup, very carefully,only looking for (cool and quiet) and check this, you can also need to check the CPU temperature ,,normal is 35 C to 45 C ,(if the temperature is over 50 C,reistall the CPU and used new cooler paste) ,then you give scape. save the changes and restart the PC, now the motherboard fan speed controlled, as required, only spun faster when you really need to cool the prossesador, such as a very graphical game ect, really going to notice a big change cpu fan sound, if that cool and quiet and had been activated o this is a factory PC like DELL ,ACER ,ect ,and have no change, you can buy a new cpu fan on e-bay very cheap,like factory amd 64x2 6000 cpu fan and for no will have more trouble
Aug 05, 2009 | AMD Athlon 64 X2 5600+ 2.9 Ghz Skt Am2...
Gigabyte (GA-880GM-D2H) Motherboard Logo
140 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
