Question about YouTube Videos
My you tube videos and pictures are not open 3 days ago,, what did i do???
I have a Sony Trinitron Tube Tv...45 inch..one day it just won't turn on. Is this possibly a fuse or power issue...or would it be the picture tube? Is it worth repairing? Thanks for your help
It could be many things, but if it has a 'picture tube' and is 3 feet from front to back, it is past its Best By date. Technology has moved on. We are now in Flat Screen, Smart televisions that connect to the Internet, that as 2" depth from front to back and have pictures in High Definition and Ultra High Definition 4K. The difference is astounding!
If you are short of money, then yes it can be repaired and it was a great set in its day, but as I said, there is better.
https://www.bestbuy.com/site/samsung-55-class-54-6-diag--led-2160p-smart-4k-ultra-hd-tv/5754304.p?skuId=5754304
Jan 07, 2018 | Sony Televison & Video
My Samsung hlt5055wx/xaa has 2 green lights lit up but won't come on ? We replaced the picture tube 2 weeks ago and it has been working fine until I tried to turn it on today.
Your TV doesn't have a picture tube but rather a bulb. I would eliminate other possibilities first like cable connections etc first before looking into the set. Check all inputs with DVD or Bluray and see if it malfunctions across all inputs. If so it would be time to open up the set. If you are not comfortable with electronics you will have to bring it in.Really these sets are being given away these days and a repair should be considered carefully before spending any money.
Jul 03, 2016 | Samsung Televison & Video
Hi, I have a JVC 32inch Model# AV32050 and at first it took several attempts to get it to power on, but now it will not power on at all.I hear a high pitched sound while it is plugged in outlet. A few...
Take the tv aparts.Take out the tv video board that is connect to the CRT tv tube.Plug the tv back in "High Voltages" be very careful now.Find wire with solid insulaition grounded in a metal frame some where the other end of the wire go toward the "High Voltages" Open CRT tv tube,u will hear a big "POP".Now unplug the tv.Put the tv back together again,nor tv CRT tube should be clean out of bad contamination poison.The tv Focus well be clear up and work as normal tv again.If u scare don't want to mess around with open "High Voltges" pay the tv shop like $50 bucks they can do this job for like 20 mins.
Jun 06, 2011 | JVC AV-32050 32" TV
Cant find you tube video i made two days ago
You may find all you videos in your My Videos page.
Here is the link to that page:
http://www.youtube.com/my_videos?feature=mhum
If the above link doesn't work, then follow following steps:
Step 1: Signing to your account
Step 2: You will see your user name in top right corner, Click it. Drop down menu will be open.
Step 3: Click My Videos
Feb 24, 2011 | YouTube Videos
No picture onTV screen only audio after lightning
May be your picture tube got damaged in that lightning. This may be an effect of the magnetization of the picture tube due to a huge electric current passing near it. Try demagnetizing the tube and if it doesn't work get it replaced. Try having a properly working tube of an older television as modern picture tubes lack quality.
Apr 17, 2010 | Televison & Video
The TV was working fine until one day the picture no longer appeared. A friend told me that he had a similar problem and he was able to easily change a bulb inside. I pulled the TV from the wall and I have...
These don't use bulbs to my knowledge,they have 3 different picture tubes in them.
I would look for what's called a pico fuse around the transformer. If they open that would cause no power,and no picture. Usually though, if this is the heavy 3 picture tube projection that I believe it is,then I would suspect the IC Chips which are video amps and have 40-60 legs on a single chip.
Nov 01, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Flickering screen with semi-circular middle whitish flicker and static sound
Use your warranty, as most warranties are vioded if you open the set up.
Jun 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Pictures have lines
some people say that winter storage does this.it is ,apparently,to do with moisture and the residue it causes when it dries.to all of you i recommend putting your cameras in a sun-lit window for 20 minutes a day for 3 to 5 days.if it does not work,try a tape head cleaner.
Dec 18, 2007 | Canon ZR800 Mini DV Digital Camcorder
Phillips tv 32pw9544
it is 100% sure that your tube is ok.
there are few problems in different section like
  • sound section for no sound
  • video & crt base  due to low light in picture.
  • red video output circuit.
  • though problems are very easy & can be fixed at your house.but you need skilled technician.
Oct 16, 2007 | Televison & Video
Component Video inputs do not work
I started back in the day of tubes. A family would have one set and it would be a 19" black and white. There are different resolutions now. The components probably do work, but, they don't pass the 480i signal. The satelite converter's analog signal needs to be set to 480p and the DVD needs to be set to progressive if it does have that setting. If the DVD is not a progressive scan DVD, then, the only inputs that it will show on is the analog signal. Some of the dish converters have a switch on the face for changing the resolution. If yours doesn't then put it in an analog source and go to the menu and change it there. Then move it to the component input. Hope this helps.
Jun 23, 2007 | Panasonic PT-53WX42 53" Rear Projection...
YouTube Videos Logo
18 people viewed this question
Top YouTube Computers & Internet Experts
Rizwan Hanif
Level 1 Expert
LP
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
