Question about PfaFF Sewing Machines
Pfaff 803 - I disassembled the upper tension control and now I can't get it back correctly. Can someone please tell me how to get it back together? Thanks!
4 Suggested Answers
  • 106 Answers
SOURCE: Upper and Lower Looper Rub Together!!
Your loopers need adjusting, impossible to explain how to do this, you need to be shown. Can I suggest you contact a sewing machine tech, sure it will cost but if he is a decent guy he will show you how to adjust the machine.
Posted on Apr 24, 2008
  • 632 Answers
SOURCE: Can not adjust the tension
Nothing is too old, that is what the internet is for. You can google it or you click this link (PFAFF Manuals) which I found for you. Just look for your model and easily download the owners manual after purchase. Don't lube any part of your machine until you have a manual which shows you where. Oil attracts lint and could cause it to operate in a difficult manner.
Posted on Sep 15, 2009
  • 2973 Answers
SOURCE: I have a tension problem
Either the bobbin and the pin it spins on need thorough cleaning or the bobbin needs replacement if, even after cleaning the problem persists. Clean it by dipping it in spirit or gasoline and then using a brush on it.
Posted on Oct 18, 2010
What are the correct thread tension numbers on thePfaff hobby grand quilter 1200
Usually, the standard tension for upper thread is midway between high & low numbers. However, every machine differs and may need to be tweaked. Unfortunately, finding the correct tension is generally a test and adjust method. Be sure you are using a brand new needle and good quality thread.
Oct 10, 2016 | PfaFF Sewing Machines
My Pfaff Expression 2034 sewing machine is suddenly making an almighty mangled mess at the bottom - it doesn't matter how I re-set the tensions. What can be the problem?
Be sure to use a brand new needle.
Remove the upper thread and bobbin. Reinstall the bobbin making sure it is turning the correct direction and threaded properly in the bobbin case.
RAISE the presser foot and rethread the top thread. Confirm the thread pathway is correct.
Most often, knots (thread nests) occur under the fabric because the machine is misthreaded or the thread is not seated completely in the tension disk.
Sewing Machine Thread Bunching Up Here Why
What causes Bird Nests Superior Threads
Sep 22, 2016 | PfaFF Sewing Machines
Bobbin thread picks up when there is no fabric in machine,as soon as i put fabric under the foot it skips stitches or doesn't catch at all. have changed needles, re threaded and adjusted timing.
I have run into this problem on newer light weight machines.
Remove the nose cover and look for thread wrap in the upper tension control, even a small piece of fluff can keep the discs from closing when you drop the presser foot.
Try not to disassemble the upper tension control because they can be tricky to get back together.
Check around the slack arm, thread will wrap-up at the pivot.
Good luck.
Feb 18, 2016 | Singer 2639
I have a pfaff 1525 and My bobbin thread forms a loop every 2-3 inches and I am trying to make a veil. I am using a ball point needle size 9 and adjusted the tension wheel to a 6 since the lower the number...
check to make sure that around the tension dial there is no lint or dust
the upper tension spring could be bad
a sewing machine repair shop could tell about the tension spring
Aug 02, 2011 | PfaFF Sewing Machines
Pfaff machine -sews with thread loops forming on the underside of the fabric.
This is usualy a thread tension problem. Adjust the upper thread tension first. If tightening the upper thread tension doesn't work, then adjust the bobbin holder (lower thread tension) check with the user manual for your specific machine for the correct procedure.
May 17, 2011 | PfaFF Sewing Machines
I had to rethread my Singer Ultralock serger and now it won't sew correctly. Best I can tell the lower looper keeps coming unthreaded, but this doesn't happen until I put material in. I have rethreaded it...
I had read where someone said their lower looper tension dial had pulled apart. Sure enough, mine had too. We snapped it back together and Voila problem solved!
Dec 06, 2009 | Singer 14SH654
Aug 18, 2009 | PfaFF Sewing Machines
Obtain an instruction booklet for the Pfass Hobbymatic 803
have you contacted you local Pfaff dealer?
Jul 04, 2009 | Sewing Machines
Tension Problem on Pfaff 2034, bobbin loops
Rule of thumb.. Loops on the bottom, problem on the top. Loops on the top, problems on the bottom.
Set your upper tension at 4, and rethread the machine from the top. Just before you thread the needle, but the presser foot down. If the thread pulls right thru easily, then the thread is not thru the tension wheel right. Because, if you can't pull the thread thru with the presser foot down, you have it threaded right.
Apr 24, 2009 | PfaFF Tiptronic 2030
How to stipple with Pfaff 7550
Make sure you have the presser lifter lever in the proper position. When lowering it, push to the rear and it will stop half way down. This engages the upper tension but keeps the foot from lowering down and touching the fabric.
If this doesn't help please post the exact problem, i.e. thread pulling to the bottom etc.
Jan 29, 2009 | PfaFF Creative 7570
Sewing Machines Logo
Top PfaFF Sewing Machines Experts
SewTechWayne
SewTechWayne
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
