Question about Asko W6021 Front Load Washer
My ASko washer machine will not start up, all I hear is a short humm when I press the start button. I took the cover off and noticed the control board has a burned chip on it. There is also a resistor with burn marks around it as well. I also checked the fuses and they were fine. I can also press the lock reliece and it opens the door with no problem. That is all that works.
    Problem Solver:
  • 4 Answers
Sounds like the control board is fried. If you have gotten it open here is a link for a new board:
http://www.superiorapplianceparts.com/shop/asko-washer-control-board/?q=/shop/category/washer/asko/
Good luck! And make sure the thing is unplugged before you work on it!
Joseph
Posted on Apr 16, 2011
  • tefox940 Apr 16, 2011
    I did find a new board online and decided not to fix the machine as it is 10 years old. The new board costs over $350 plus tax and shipping. With the age of the machine there are undoubtedly more things that will break down in the near future. I have also found that this washer is too small and too slow as well. Takes up to 2 hours to do a single load. Investing in a new washer would be the best route to take.
    Thanks for your help on this matter.
I got an error code e5e from frigidaire front loader
Hello barnessursula - Typically error code E5E indicates that there is a communication problem. Base on the intensity of the issue, I suggest contacting a professional technician to accurately repair the unit. Technician will need to check the wiring between the main control board and the speed control board. Depending on the diagnoses and if the wiring is bad, it has to be corrected. However, if the wiring is good the main control board will need to be replace or if the problem is not corrected, the speed control board will need replacing.
Dec 15, 2012 | Frigidaire ATF6000ES Front Load Washer
Asko 6221 washer. push start button and here the click but the washer does not fill. Cleaned coin trap and cleared a dime from one of the lines
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Aug 13, 2011 | Asko W6221 Front Load Washer
I have an asko w6021 washing machine that won't run. All it does is when the power on button is pushed, and nothing else, it makes a humming sound almost like it's in the middle of the wash cycle. Also you...
Open the hatch at the bottom left of the unit. If there is water still is machine, remove the drain hose and drain machine. Open the drain pump and check for foreign objects, make sure that the rotor spins freely and that there is nothing holding it. This will prevent the machine from working properly
Mar 13, 2011 | Asko W6021 Front Load Washer
The machine will not go on. It is stuck. It is a front loading Asko. I opened it and took out clothes by popping it open. Now nothing works.
Welcome to FixYa.
I wonder if you could elaborate and clarify on the issue and the events which led to it as well as the model number of your Asko.
When you say "machine will not go on. It is stuck", is there no power, no led indicator light or it just won`t start.
Specifically what you mean by "I opened it and took out clothes by popping it open".
Do you mean you opened via the button which "pops" it open, or did you pull the emergency pull cord or in fact force it open some how ?
Also when you state "Now nothing works" does this mean the unit has no power and will not come on or does it just mean there appears to be power, but will not start.
I should be able to assist you when I can speak directly towards your model as opposed to generalizing since even within the Asko brand there are many models to cover.
I`ll watch for your reply.
Regards,
Macmarkus :)
Sep 22, 2010 | Asko W6021 Front Load Washer
Asko washer w6021 doesn't work. I've checked
See whether water is flowing into the wash machine. Then the door close switch.
Mar 28, 2010 | Asko W6021 Front Load Washer
Push start button on control panel - machine does not start
only 2 things can cause this.
1 the control is set to lock out mode. just hold the lock button for 5 seconds and it should go back to normal mode.
or 2 the controls user interface has an internal failure. its the part that has the switches and tells the computer what to do. either way call whirlpool and see if its still covered by their warranty.
of yeah and the 3rd thing is you have no power to unit. make sure the outlet is good by trying something else in the same outlet, like a light or hairdryer.
Jan 05, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Asko W6021 won't start
change the carbons theres nothing wrong with the board
Jul 30, 2008 | Asko W6021 Front Load Washer
Asko 7005 and washer 10505
1) there is a reset button on the back panel of you dryer it is in the middle black rubber...
2) you really can't the asko washer needs a 240v to run... You can hire an licenced electrician to wire a 240v plug for your asko washer if you do not want to plug it into the dryer
Jul 01, 2008 | Asko W6021 Front Load Washer
Please help me..
Maybe the 5hr. button is pressed? If so, the machine will wait 5 hours before it starts:)
Feb 09, 2008 | Asko W6021 Front Load Washer
Asko W6021 Front Load Washer Logo
451 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Joseph Hoffmann
marley mcelhinney
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
