I am trying to add a desk top to my wireless router
  • Frank van den Berghe
    Frank van den Berghe Apr 07, 2011
    i couldnt ever get by the security key .and i had already tried most of the stuff in your note.i gave in to myself and ran a earthnet cable acroos the basement so thats that.it could be me as i am only slightly comp literate .i am completly self taught ,thanks anyway
    Brigadier General:
  • 3,917 Answers
Hi
To set up wireless Internet access on your desktop, you will first need a wireless router in addition to your cable modem, as well as a wireless adapter. Two different types of wireless adapters are available to choose from-a USB adapter is easier to install but requires the use of a USB port; an internal network card requires installation inside of the computer case. In either case, installation in a desktop computer is the same as any other PC with Windows Vista or XP.
Connect your wireless router to your cable modem per the manufacturer's instructions. Name your wireless network and password protects it to keep others from using your connection without your permission. Write your network name and password down in a safe place for future reference.
Install your network adapter per the manufacturer's instructions. Your wireless adapter and wireless router do not have to be the same brand to be compatible. Keep in mind that different routers emit different signal strengths and choose the strength that fits your needs. For the best results, you should choose an adapter that corresponds to the signal strength you chose.
For Windows Vista, access the Start menu and select "Connect To" which will open a network dialog window. Click "Set up a Connection or Network" and follow the on-screen prompts. In Windows XP, access the Start menu and select the "Control Panel" and then "Network Connections". Click on "Wireless Network Connection" and follow the on-screen prompts. In the prompts you will be asked to enter the network name and password you set up in Step 1.
Look to the right-hand side of your menu bar for an icon with two computers and a blue dot. This confirms that you are connected to the Internet. Mouse over the icon to show what network you are connected to. It should show the name that you provided in Step 1.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Apr 04, 2011
What do I need to add to my desk top to have my internet run wireless?
A Wi Fi adapter card. Like the ones on the link below, just copy and paste. I'm NOT endorsing anything, just for demonstration purposes.
http://www.altex.com/Intellinet-Wireless-300N-PCI-Card-523981-P149321.aspx
Sep 05, 2011 | D-Link DIR-615 Wireless Router
Trying a add another desk top to an existing Belkin wireless G router at home. Right now there's a desk top and laptop working off this router.Try several times and still can't connect to internet.
Make sure the Belkin wireless is the only device directly connecting to your internet service provider's router/modem. Usually that port is labelled "WAN" or even "Internet". The Belkin should have extra ports/jacks for WIRED connections, right? You then connect the PC into the other remaining ports/jacks on the Belkin (if they're wired) or just use the wireless for the laptop if the laptop has wireless. After getting the wireless going, though, you should lock it down by using WPA encryption key if possible.
Feb 24, 2010 | Belkin (F5D7230-4) Router (587009)
No Internet via zoom X6 wireless router to desk top, lap top ok.
Access your zoom router by using the laptop which still has access to the router.
Your going to have to open your Wireless Network Connection Status window located under your network settings.
If you see this window your going to left click the (details) button
Now you should see a IP DNS server address
for example: 192.168.1.xxx
Type that address onto the address bar of your web browser.
it should take you to your router setup page.
There you will need to check if the lan port is enabled
Feb 04, 2010 | Zoom X6 Adsl Modem/router Rohs...
DESK TOP TO WIRELESS CONNECTION
First make sure you have the correct drivers installed, go to the Belkin website to get the latest drivers for your device.
Next make sure that your router is set to broadcast, and that is in Wireless G mode. You can find that information at the router manufacturers website.
Apr 15, 2009 | Dell Dimension 2400 PC Desktop
Belkin router is working with desk top computer. add laptop
It's asking for the security word that you entered into the router when you set up wireless security. You will need to enter both the wireless SSID, and the security key to make the system work.
Jan 24, 2009 | Belkin N1 Wireless-N Wireless Router
Can not connect another desk top to wireless router
the link below will show you how to work on the wireless settings of your router and how to connect multiple wireless computers in a single network.
Setting up your Linksys router to have wireless security.
hope this helps, if you have other questions just let me know.
Nov 03, 2008 | Linksys WRT160N Wireless Router
Connect
Hi - Absolutely. If you have any problems or need more help just add a comment and I'll be happy to assist you. PLEASE rate this fixed and don't forget to holler if you need any help. Thanks,
Jeff
Sep 04, 2008 | NetGear WGR614 Wireless Router
I'm a little confused how to install this router I just bought. Model #wrt54g2. do I put the cd into my desk top which is already connected to the internet or do I install the cd in the new laptop I just...
Hi sheena -Is your desk top hooked up throgh the router? If not, plug your modem into the wan port on the router. The router should have come with a couple of short cables, most likely blue and yellow. Use the blue to connect your modem to your router. You can check the manual just to be sure. Use the ethernet cable that had been connecting your desk top to your modem, and plug into one of the wired ports on the router. I imagine you'll be using wireless for your laptop. Make sure that it is on. Put the cd in your desk top and run from there. Follow the directions. If you need more help just add a comment and I'll be glad to assist you further. If this solves your probleb PLEASE rate this as fixed. Remember. Need help? Just holler Sheena.
Jeff
May 04, 2008 | Computers & Internet
Setting up router having problems
You don't need to have a WiFi adapter for the desktop. It can be connected using a LAN cable from the PC's Ethernet port to one of the routers Ethernet port. AS long as the desktop is set to "Auto obtain IP add" then it should work straight out.
If the LinkSys WRT54G did not came with a setup CD/Wizard, then you would need to reset it since I can only assume that it has been tried/used elsewhere before and the settings/configuration may not match your ISP and/or your network configuration. Reset involves pressing a small recessed button at the rear of the unit for about 10 seconds or more.
Once the reset was done and your router can connect to your ISP and therefore your desktop to the Internet, the laptop would also follow suit as long as the network settings is likewise set to Auto obtain.....
To verify if you can connect to the router, on your desktop, open a browser and log on to your router using 192.168.1.1,
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 04, 2008 | Linksys Wireless-G WRT54G Router
Wireless - G router
If the Linksys is not yet configured use the desktop to put the CD in and follow instructions to add the Linksys Router to your existing network setup.
Once inside there are a few more steps to getting a desktop PC to see & network with a laptop PC within a router/wireless environment. Once the Linksys is setup you may want to repost something to get the computers talking to each other.
Take care...
Feb 09, 2008 | Linksys Wireless-G WRT54GS Router...
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
