Question about Dryers
How can I tell if the heating element has gone out?
  • 5,911 Answers
If your ELECTRIC dryer is still running, but does NOT produce heat, the following two links can give you advice on how to troubleshoot an ELECTRIC dryer with a no heat problem:
http://www.fixya.com/support/r3576548-dryer_runs_but_does_not_heat
http://www.fixya.com/support/r3574266-thorough_dryer_advice
IMPORTANT: Your problem may or may not be related to a heating element problem as there are numerous factors that can cause a dryer not to heat. The heating element has protection devices that are designed to regulate the heat and internal temperatures. If the dryer overheats the Thermal Cut-Out (TCO) typically will blow BEFORE the heating element. The replacement kit is much cheaper than purchasing a new heating element that may or may not be the problem.
Begin by unplugging the dryer and verifying the voltage at the wall receptacle. You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.
If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.
NOTE: If the wires at the terminal block are not color coded, the outer two wires (left and right) are the hot leads. The center conductor is neutral or ground.
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer may exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the dryer on the right hand, or under the dryer drum. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum.
On a Whirlpool Duet or Kenmore Elite model, the heating circuits are located inside the dryer under the dryer drum on the right hand side. You will need to remove the lower toe panel under the door to access. The toe panel comes off by locating and removing the screws under the bottom front edge of the panel. The Heating Element is located inside a heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals (all the way towards the back of the dryer cabinet). The Hi-Limit Thermostat will be located adjacent to the heating element terminals.
If either the TCO or Hi-Limit Thermostat are determined to be bad, replace BOTH components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace.
If this is a GAS dryer, the problem may be attributed to a defective or weak burner igniter and/or blown thermal fuse.
Replacement parts (if required) may be found at the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average cost of these components varies, so shop and compare. The first three websites I listed have helpful
exploded view parts diagrams that can help you locate and properly identify any parts you may need. The heating components are usually listed under the "Bulkhead" section.
If you have any questions, please post back with your MODEL NUMBER and let me know. I hope you find this information helpful.
NOTE: If your model number is not listed on some of the websites, use the part numbers from the Sears website and use that as your search criteria. Some model numbers will not reference on some sites, but the part numbers will.
Posted on Apr 04, 2011
Dryer low heat
It sounds like one of the heating elements has gone out. I've replaced the one in mine and it's not difficult. They just plug in like the ones in an oven. You'll be able to tell which one when you get inside if that's it.
Jun 06, 2014 | Whirlpool WED8300S Dryer
Dryer wont heat. how can I tell if it is the heating element
If there is no heat at all, it is the heating elment is most likly broke a wire in the elment. Be safe. Vern
Apr 26, 2014 | Dryers
Hi, heating element gone I assume. It works well but does not heat up anymore.
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker
Mar 16, 2011 | Whirlpool 24 in. ADG7540 Built-in...
Dryer is not drying and how can u tell if heating element is gone
Locate your heating coil...
Remove the two wires from the terminals of the heating element.
Using an Ohm Meter set it to check for continuity accross the two terminals.
If you Ohm Meter buzzes or shows continuity across the terminals then the coil heater is good.
Please Rate Me
Aug 29, 2010 | LG DLE2514 Electric Dryer
F3-error. Kenmore classic oven Heating element will not go pass 100 deg. Heating element recently replaced. Broiler is also malfunctioning
Hello there:
Whenever you get the dreaded f-3 code this is the code that tells you that the temperature sensor is going bad or already has gone bad and needs to be replaced immediatly. It should look something like this and cost about 50 dollars
Jun 20, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Heating element no longer working. dryer still operating except clothes wont dry
it is the theromstats or heater element has gone the only way to tell is to meter them out u need an expert to do this
Jul 31, 2009 | Fisher and Paykel SMARTLOAD DE62TG1...
I have a GE Single Wall electric oven.(JTP25SOH2) The heating elements just stop getting hot. unit is about 4 years old purchased brand new. first the broiler stop getting hot then the baking heating...
First your broiler heating element may have gone bad and now you oven heating element may have gone bad. Using an OHM meter disconnect them and test for their value.Full scale on the meter means it is shorted. No meter movement means that it is open.Eitehr means to obtain a new element(s) and replace it/them.
Jun 11, 2009 | Ovens
Electric Heater
If the heating element may be failure, or heating fuse may be gone . Pl. check and tell me or send me Photo of heater.
May 24, 2008 | Heating & Cooling
Dryer leaking water
it sounds to me like the heating element that heats up to dry the clothes has gone faulty or tripped out. Cant really tell from here.. when you open the drier is there a good level of heat ? If not, its the heating element section at fault.
Mar 17, 2008 | Dryers
Dryers Logo
63 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
