Question about Belkin (F5D7230-4) Router (587009)
I bought a Belkin 'Play' router to provide wireless internet connectivity from my CLEAR modem. I can't get the router to speedtest at half the speed as being directly connected (via ethernet cable) to the CLEAR Motorla modem. I'm by no means a router expert (more like a novice), and so I've tried every configuration I can find on the internet and nothing seems to help. And, yes, I have a 3+ feet distance between the modem and the ROUTER. Any suggestions are appreciated.
    Brigadier General:
  • 10,406 Answers
Use an Ethernet cable from the CLEAR modem into the WAN (or 'Internet') port on the Belkin.
Take a close look at the 8 coloured wires at each end of the Ethernet cable.
The 8 wires must be coloured in the _same_ order at both ends.
Be sure that you have a 'CAT-5' or 'CAT-5E' cable, not a 'CAT-3' cable, which is much slower, over long distances.
Use another Ethernet cable from one of the (three? four?) 'LAN' ports on the Belkin to the network-port on your computer. Again, check that you have a "straight-through" cable, not a "cross-over" cable.
Turn the CLEAR modem off.
Turn the Belkin off.
Turn your computer off.
Turn the CLEAR modem on, and wait until its lamps settle-down to a consistent pattern.
Turn the Belkin on, and wait until its lamps settle-down to a consistent pattern.
Turn your computer on, and let it boot.
You now should have Internet access.
Note that the router "dynamically" shares the Internet connection.
If there are 4 'LAN' ports, then each of the LAN ports gets as much speed as it needs;
you do not have a 25/25/25/25 split, unlike cutting-up an apple-pie to feed 4 people.
Run a "speed-test" on your computer, and you should be getting as much speed as you are paying for. Having the Belkin in the "middle" of your network should *NOT* slow-down the speed-test at all.
Posted on Apr 04, 2011
My downloads are extremely slow and the movies i watch online keep pausing now and then.
For the most part all networking equipment minus Cisco use the same industry wide standards to communicate so there should not be an issue with mixing gear. Most likely your simply downloading during peak times. Are you using wireless or a wired connection to the router? This can have an impact on your speed, are more than one person using the network at the same time this can also affect performance. Also periodically go to http://www.speedtest.net and check your download speeds you should notice that at peak times your speed will be reduced simply because more people in your area are on the internet at the same time using up more of the ISP's available bandwidth
Jan 27, 2012 | Belkin N450 Wireless N Router
My belkin 802-11g is 1 hour slow how do i cange
You can easily check your internet speed bychecking it online via tis website, http://www.ip-details.com/ . Ithelped me to check my PC's internet speed in it.
Jul 27, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How do I test my broadband speed using a Belkin ADSL Modem Wireless Router G
Hi. Go to www.speedtest.net and select a location from the map. It will test your broadband upload and download speed.
Jun 21, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Internet extremely slow on one network, fine on the other
Not knowing if this relates directly as i am not from Australia but have you checked with the ISP.
The phone line providing the internet access may be damaged in some way or require calibration to reduce line noise (which can cause slow speeds).
Alternatively, have you got a usage limit that you may have reached. ISPs have the ability to throttle back your connection speed.
Thanks
Dec 22, 2009 | D-Link DSL-G604T Wireless Router
Always lose connection while playing playstation 3 online. Sometimes my computer displays a launchmodem error when trying to get on the internet. If I unplug the modem and router, it works again.
Please give some information on your router and modem brand/model, also what type of connection do you have, cable, dsl, etc. Go to speedtest.net and post your upload and download speeds as well.
Are you connecting to your play station wirelessly or through network cable directly to the back of the PS3?
Depending on your speeds your connection could be overloaded by the high demand the PS puts on your internet connection, or if you are wireless you could be in far range from where the router is located. Hope this helps. The extra information might help.
Sep 17, 2009 | NetGear WGT624 Wireless Router
Change settings
The router ports autosense the speed of the device that you are connecting to it. If your xbox is set to run 100 mb the ports will run 100, if the xbox is set for 10 then thats what it will run. Test the speed of your internet connection with a wired pc and then test directly into your modem and see what speeds that you get. You can test your speed here:
www.speedtest.net
Jun 01, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Internet speed not as indicated by modem
problem occurs usually after upgrade of internet speed. contact your ISP again, ask them to check for latency or dropped packets within their network. they need to run a traceroute from their end and it would also be better if you can run a traceroute from your end. also run a speedtest through speedtest.net or speakeasy.net. There's also a possibility that the modem is becoming faulty. If your ISP provided you the modem it's still best to contact them for possible replacement.
May 08, 2009 | Actiontec GT704WG Wireless Router...
Set up my belkin g router
You may have to configure the belkin router depending on the type of ISP that you have.
Basically, you can do these to configure your router:
1. connect the computer to the numbered port of the router and connect the modem to the internet/WAN port.
2. turn off the modem, router and the computer for 30 seconds
3. turn on the modem first, wait for the lights to stabilize then turn on the router, wait for the lights and lastly turn on the computer.
Sep 04, 2008 | Belkin (F5D7230-4) Router (587009)
Weak connection
HI,
As you have changed the router still the connection speed is slow, in this case it's better to contact your ISP get the line tested or a proper signal strength.
Also conduct a speedtest by going to the website internetfrog.com....indications are towards a line fault.
Apr 23, 2008 | Belkin (F5D5231-4) Router
Internet speed with wireless connection to my router is almost half as compared to when i connect to my router using a cable.
As far as i know the coonection speed on internet should be the same, the speed at which you connect to the router wirelessly would be half the speed ,hence 54 mbps as apposed to 100 mbps via cable, when downloading. I assume you have done a speed test at http://www.thinkbroadband.com/speedtest.html to give you your modem connection speed, although your wireless connection to your pc; will stream the connection at half that of cable.
Dec 20, 2006 | D-Link AirPlus DI-524 Wireless Router
Belkin (F5D7230-4) Router (587009) Logo
104 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
