Question about HP Office Equipment & Supplies
INSTRUCTIONS FOR USING THE HP LASERJET M2727 (FAX,SCANNER,ETC) INSTRUCTIONS DID NOT COME WITH THE MACHINE
  • tduitsman Aug 15, 2008
    When faxing 6 pages, the person recieving the fax get the first sheet, and only a quarter of the next 3 and nothing on the last pages. How can thsi we fixed?
    Master:
    Sergeant:
  • 398 Answers
Go to hp.com and click on support, then you can go to downloads. They should have drivers, software, and user manuals for it.
Posted on Aug 05, 2008
HP Laserjet M2727nf Mfp Printer Scanner Error 8
The HP M2727 has a known issue with the scanner error 8 and bad formatters. HP has extended the warranties on this product. I suggest you contact them directly and they will most likely exchange the unit.
Nov 08, 2011 | HP Laserjet M2727nf Multifunction Printer
Tip
What is a Scanner Error 5 Hewlett Packard M2727nf MFP
"Scanner Error 5 or Error 8"
Hewlett Packard Laserjet M2727
The Copier Scanner is failing to initialize or find home position. The printer will have to have the Scanner replaced by an Authorized Hewlett Packard repair facility. The printer may at times "freeze" or "hang".
This printer is under HP Warranty until Mar 23, 2011
Contact Hewlett Packard for Warranty repair. See Link Below
http://welcome.hp.com/country/ca/en/contact/phone_assist.html
2 parts need to be replaced at the same time
Parts Required as follows
Formatter - CC370-60001
Scanner/Flatbed - CB532-67905
Warranty Extension Expiration 2011-03-23
on Feb 04, 2011 | HEWLETT-PACKARD Hewlett Packard 53A...
Fax machine not working on HP LaserJet M2727 nf
> Incoming & out going both are not working?> Check line is OK?> Remove left side cover
> Replace Fax card,P.No CB534-60117> Replace Formatter PCA P.No.CC370-60001 > Most of the cases found Fax card failure. see the snap shot of fax card.
Oct 13, 2011 | HP Laserjet M2727nf Multifunction Printer
I have an HP laserjet m2727 mfp series 4 in 1 multipurpose that can only print and recieve fax. What would be the problem? Please help me.
The detail isnt clear.
But if your machine doesnt do copies, scan or send faxes it would seem that ther is a problem with the scanner unit on your machine, Lift the ADF unit (as if you wer to do a copy from the glass) keep the lid open so you can see the scan unit, do a copy and check if the scanner unit moves and check if the bulb is burning.
These machines are notorius for dodgy formatter boards.
But i would start with checking the scanner unit.
Feb 18, 2011 | HP Laserjet M2727nf Multifunction Printer
Hp m2727nf does not recognize incoming fax calls. problem occurs in switzerland with analog port on isdn line. research for problem with swisscom engineer shows, that m2727 works with isdn nt V1 - V3 and...
Hello walter727, could you find a solution to your problem? I have the exact same machine over ISDN in Switzerland. My ISDN line had some changes and the fax won't pick up calls anymore.
Oct 07, 2010 | HP Laserjet M2727nf Multifunction Printer
Scanner LaserJet M2727 Output default
You cannot fix this by modifying settings, contact hp tech support and have them take remote access of your computer, they need to replace a file which is causing the problem.
Hp tech support 1800 334 5144
Al
Mar 30, 2010 | HP Laserjet M2727nf Multifunction Printer
HP 3055 All In One laserjet prints all black pages
Odds are that you have a bad toner cartridge; especially common when using remanufactured cartridges. (Staples, Corporate Express, etc.) Replace your cartridge with an OEM HP cartridge and you should be OK.
Feb 22, 2010 | HP LaserJet 3055 All-In-One Printer
Unable to receive fax from HP LaserJet 3050
Please make sure the machine is set for auto-receive in machine set up and make sure the phone cord is plugged into the line jack on the machine. If this machine is not on a dedicated phone line the machine (rings) should be set to pick up before the answering machine does.
Aug 28, 2009 | HP LaserJet 3050 All-In-One Printer
SETTING UP MY HP ALL IN ONE FAX MACHINE
Fax (HP LaserJet 3050 allin-
one and HP LaserJet
3055 all-in-one only)
● Full-functionality fax capabilities with a V.34 fax; includes a phone book, fax polling, and
delayed-fax features
For more information, see the online user guide.
I Hope this is good info for you.
See www.hp.com for the users guide.
Jan 07, 2009 | HP LaserJet 3050 All-In-One Printer
239 people viewed this question
Ben Johnson
