Hi Is this issue regarding a dishwasher, if yes then please
post back with the manufacturers name and model no and also please elaborate.... Daniel
Either the wires of heating element is bad or the wire harness from the control is bad....and thats the reason it trips the breaker....you will have to open the unit and check for loose/burned/broken wires.
Yes...because the issue is not with the circuit its with this unit
Seamens model #SL34A006U3-01 Disherwasher runs half a cycle,the breaker trips,reset the breaker it run for about 4 or 5inutes the breaker will trip again.There are 3 other outlet on this circuit and when the dishwasher is on there ir nothing pluged into these outlets.when the dishwasher is not in use these outlets work fine.The circuit beaker is a 20 amp
Seamens model # SL34A006U3-01Dishwasher runs half a cycle ,the circuit breaker trips,reset the breaker and the dishwasher runs forabout 4 or 6 minutes then the circuit breaker will trip again.There are 3 other outlets on this circuit and when the dishwasher is on there is nothing pluged into these outlets.When the dishwasher is not in ure these outlets work fine.The circuit breaker is 20 Amps
Seamens #SL34A006U3-01 There are three other outlets on this circuit but are not used when the dishwaher is running.These out work find when the dishwasher is not running.The circuit breaker is 20AMPS
I brought a new dishwasher.Is it safe to install the new dishwasher?
