Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Motorcycle wont start
I turned the ignition key and all of the lights went on as expected then when I tried to start the bike everything went dead. I don't know if it's the battery or an electrical problem. The battery is over a year old and the bike has been running fine up to a few days ago. Any suggestions?
  • andrewmoran Aug 06, 2008
    I have a similar problem with my 99 Sportster 1200. Turn it and all i get is a loud "CLICK". Took apart and cleaned all relays, checked fuses.
    Odd thing is, I pop started it and and ran, although very poorly. The tach and speedometer where spinning in circles, the digital odometer was flashing random numbers and the headlights would flicker on and off.
    Something is shorted - any suggestions where to start?
  • andrewmoran May 11, 2010
    Hey Pyrhyc,
    Thanks for the initial suggestions - both make perfect sense. However, I've done both and exact same situation still. I hate electrical problems!!! I've tried cleaning and fully charging the batter too, as well as loosening and adjusting the starter at the suggestion thats sometimes the starter can become misaligned.
    At any rate, I'm bringing my bike to the shop Wednesday, and I'll let you know whats up. My thoughts at this point - a wire must be fried or something is not grounded properly. I'd rather bring it to someone to figure that part out.
    Cheers,
    Andrew
    Genius:
  • 2,028 Answers
Check the battery connections, especially if you hear a click just before it goes dead. I know that on my bike, when this happens, the screws that hold the battery cables in place have backed out and not getting a good contact. You would think that with a bad contact that it would stay dead when you turn the key off then back on, but oddly, everything comes back on normally until I hit the starter button. Check the cables.
Posted on Aug 07, 2008
  • Ryan Rogers
    Ryan Rogers Aug 07, 2008
    andrewmoran, your problem is going to be with the voltage regulator or bad relay. If it were just a bad battery contact, you wouldn't have the inconsistency issues with the tach, speedo, lights, and running rough. Try changing out the regulator, if this doesn't cure it, then it's going to be a relay.
SOURCE:
Bike wont start, turn the key n everything lights up as normal, press the start button n just nothing
It could be the link from the starter button to the ignition coil. If you can check this for a current it should give an indication of the problem.
Jul 11, 2015 | 2005 Yamaha XVS 1100 Dragstar
Harley sportster headlight and brake light work but not the turn signals. Engine lights does not come on and bike wont start
The soft click sounds like the starter relay. Check that out first and see that current is getting through when it soft clicks. ARE there any codes set??? What led up to this???
Apr 14, 2014 | 2004 Harley Davidson XL 883C Sportster...
2000 vulcan 1500 ignition light not working
Take the cables loose from the battery. Clean the cables. Might need a wire brush. Reconnect.
Jan 30, 2014 | Motorcycles
Recently went for a ride and everything was good. Made a stop, when I came out bike wouldnt start. turning the key everything was normal, rpm gauge spiked, lights turned on, fuel pump was heard. Went to...
Did you leave your motorcycle in gear when you turned it off? It sounds like the side stand safety switch is keeping the bike turned off. If my Suzuki is running and I pull in the clutch, with out raising the side stand, and I place the bike in gear with the side stand down, it will immediately shut off. The cycle is set up that way so you will not drive with your stand down and go out of control when you take your first left turn. If your cycle is not in neutral and your side stand is down, that would cause the condition you describe. If that is not the case start by inspecting the side stand safety switch and the clutch safety switch for proper operation.
Jun 24, 2011 | Suzuki GSX-R 750 F Motorcycles
I have a s50 I put my key in tonight and the light came on as usual, but when I pushed start everything went dead no power any ideas
dead battery, your lights could still work but not enough power to turn the engine also check fuse or maybe a sticky starter selinoid ?
Jun 24, 2009 | 2005 Suzuki Boulevard S50
I recently washed my 2005 custom chopper and thought that I had dried it off well enough, obviously not! The bike has an S&S 111 engine and when I went to go for a ride I turned the ignition key and...
take a leaf blower and dry the bike with it, after washing any bike you should use a "light" powerd leaf blower to dry your bike. Just let the water dry out and you should be fine. If not pull out all the fuses and hand dry them before you them back in and try it...
Jun 22, 2009 | 2003 Harley Davidson FXSTDI Softail Deuce
2002 Pontiac Grand prix wont start; unable to remove key
On many cars, if the battery is dead, it locks the key in the ignition. Put a battery charger on the car or replace the battery and give it a shot.
Good luck.
May 15, 2009 | 2002 Pontiac Grand Prix
Electrical Help Please
nada. No gauges no lights absolutely nothing. All that happens is when I turn the ignition switch off the tach bounces backward quickly about 6 or 8 times. I put the bike on the battery tender and within 20 minutes it was showing in good shape. Still nothing. Checked battery leads. No problem. I checked all the fuses around the battery and up next to the dash. Nothing there. I R & R'd all of the relays next to the dash and the 3 behind the tool kit with the same relays off of my Mille. Still nothing. I changed the odd relay next to the battery that says UP on it. Don't know what it is but it rattles. Maybe a tip over sensor? Nothing. I tried jumping the bike off with a portable jump start battery. Nothing. I switched the battery out. Nothing. I pulled the front fairing and checked all connections. Found everything to be just fine. Put a battery charger on the fully charged battery and suddenly got ignition lights and headlights. Turned the key back off and once again nothing. A few more times it would come back and show lights and gauges but when I went to start everything went dead again. I'm thinking maybe the ignition switch? It doesn't seem worn out at all. I jiggled the key didn't seem to make a difference. The bike only has about 10k miles on it. Any ideas? ,Some 'friend'... did this ever happen to him? Good diag work so far, and I don't have anything specific to look at. Hopefully one of the sm-m-m-marter members can assist. ,,,
Nov 10, 2008 | 2004 Aprilia Tuono Racing
Lands Phones Logo
278 people viewed this question
Top Harley Davidson Lands Phones Experts
Tom Diffin
Sheldon Dedek
WTF Chuck.....
WTF Chuck.....
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
