HP pavillion 8000
My computer has suddenly started to go into hibernation if not used for an hour and if lid closed, I need to take battery off to reboot... any suggestions?
  • 1 more comment
  • CAT2000 Aug 06, 2008
    No its not a new computer I have been using it for two years, what do you mean by the power option in the control panel?
    Kind REgards
  • CAT2000 Aug 07, 2008
    Hi thanks for your help I have manages to disable hiberate but the problem probably wasn't that as now it is going to standby but still not rebooting until disconnected and battery removed..
    PS I am using windows XP home edition
  • CAT2000 Aug 08, 2008
    Now not able to wake computer up when on standby, any suggestions.
  • 293 Answers
Is it a brand new laptop?
what operating system you are using?
- remove the hybernation in the power option in the control panel.
Posted on Aug 06, 2008
  • Allan Ocenar
    Allan Ocenar Aug 07, 2008
    click start , control panel, performance & maintenance, power options.
    remove the check from enable hibernation box.
    what windows operating system you are using?
My hp pavilion dv7 keeps running after the lid is closed
Change the settings in the Power section to shut-down when lid is closed. Power Settings, Advanced Settings, Change setting to shut-down when lid is closed.
Oct 29, 2012 | HP Pavillion Dv7-6165us 17.3" Amd...
HP Elitebook 2530p power lights stays on after
are you switching off, or just closing the lid? On most laptops, closing the lid just hibernates and constantly uses power, it can be changed in the control panel power options.
Mar 26, 2010 | HP EliteBook 2530p Notebook
Hp pavillion dv6000 shuts off and wont power back up
make sure laptop is having sufficient power on battery remove the battery and directly connect the main power and see it is switching on or not otherwise connect the battery and connect the power adopter and don’t switch on the laptop keep for 10 minutes and then switch it on.
Jan 15, 2010 | HP Pavilion dv9000z Notebook
Screen will not come on hp pavillion 2000 laptop help
try powering the laptop on, and open/closing the lid.
this is to ensure, the closed lid catch is activating/de-activating.
you should get a beep or tone, when the lid is closed.
Or the laptop, will go into Sleep/hibernation Mode.
Also try pressing and holding the power on Button for more Than 5 seconds, This will eliminate that the laptop hasn,t gone Into sleep/hibernate Mode.
If none of this Works for You. Try removing and replacing The memory modules ( RAM ) and use 1 stick of memory in each slot individually. failing any of this. i,d suspect. Screen Inverter/tft Panel Or Motherboard Fault. Or possible graphics driver Corrupt/missing.
Mike @ Compurepair.
Oct 22, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
When I hit Fn and Spacebar still no backlight?
You might have to remove the tiny switch that is under the Right hinge. Your laptop thinks that the top is still closed. Just remove it and cut the two wires. Closing the lid won'd sleep the PC anymore, so be sure to hibernate before closing the lid.
Oct 05, 2009 | HP Pavilion dv5000t Notebook
HP Pavilion dv9700 black after closing lid.
when you changed it to do nothing on battery or power did you save these settings........I know it is a silly question but it sounds like the laptop is going into Hibernate mode
Jul 31, 2009 | HP Pavilion dv9700t Notebook PC
Pavilion Dv1000 monitor won't show anything
Power management lets you reduce your Notebook power consumption. Your Notebook has two power management modes:
  • Hibernation is an energy-saving feature and safeguard that saves information to the hard drive, then turns off your Notebook. When you resume from Hibernation, your information returns to the screen where you were previously working. Your Notebook hibernates when the Power button is pressed, when the battery has little power left, or when your Notebook (operating on battery power) is in Sleep mode for more than one hour.
  • Sleep, also called Standby, is an energy-saving feature that reduces power to system components that are not being used. When Sleep is initiated, your information is saved in Random Access Memory (RAM), and the screen is cleared. Your Notebook is still on, but the display is blank. When you resume from Suspend, your information returns to the screen where you were previously working.
Automatically put your notebook into hibernation Windows can automatically put your computer into Hibernate mode after a specified period of inactivity. Or Windows can detect when your batteries are running low, and then automatically put your computer in Hibernate mode to save your work before the battery fails. NOTE: Using Power Options in Control Panel, you can adjust any power management option that your notebook's unique hardware configuration supports. Because these options may vary widely from computer to computer, the options described may differ from what you see. Power Options automatically detects what is available on your computer and shows you only the options that you can control. To automatically put your computer into hibernation:
  1. In Category view, click Start , click Control Panel , click Performance and Maintenance , and then click Power Options . In Classic view, click Start , click Control Panel , and then click the Power Options icon.
  2. Click the Hibernate tab, select the Enable hibernate support check box, and then click Apply . Figure 1: Enable hibernation check box c00035872.gif
  3. Click the Power Schemes tab, and then select a time period in System hibernates. Your computer hibernates after it has been idle for the specified amount of time.
Manually put your notebook into hibernation This feature is available only on notebooks with the Windows XP operating system installed.
  2. Click the Hibernate tab, and then select the Enable hibernate support check box. NOTE: If the Hibernate tab is not available, your computer does not support this feature.
  3. Click OK to close the Power Options dialog box.
  4. Click Start , and then click Turn Off Computer . In the Turn off computer dialog box, hold down the Shift key. The Stand By button will change to Hibernate. Click Hibernate .
Jan 06, 2009 | HP Pavilion dv1000 Notebook
Software problem
Does this happen every time you download something from the internet?
Has the computer turned itself off while doing anything else?
How to Stop Laptop/Notebook Goes To Sleep or Hibernation when Closing Lid in Windows Vista
  1. Log on to your computer as an administrator. Click on Start, go to Control Panel -> System and Maintenance -> Power Options.
  2. Click on Change plan settings for the currently active plan.
  3. Click on Change advanced power settings link.
  4. In the “Power Options” dialog box’s “Advanced Settings” tab for the active power plan, expand Power buttons and lid.
  5. Expand Lid close action.
  6. Change the value to Do nothing for “Lid close action” by selecting a new option from drop down menu for both On battery and Plugged in.
740549c.jpgBased on own preference, it’s possible to set other action from the menu too. Available for selection is Do nothing, Sleep, Hibernate and Shutdown.
  1. Click OK button.
How to Disable Notebook Computer to Stand By or Hibernate on Closing Lid in Windows XP
  1. Log on to your computer as an administrator. Click Start, and then click Control Panel.
  2. Click Performance and Maintenance.
  3. Click Power Options.
  4. Click Advanced tab.
  5. Under “Power buttons” section, select Do nothing from drop down menu for When I close the lid on my portable computer option.
e461aeb.gifAgain, any other settings such as Stand by and Hibernate can be set based on own preference.
  1. Click OK button.
Let me know if this helps - if not - PLEASE, further clairify so we can continue to find a fix for your problem....
Jul 22, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
