Question about GE Model: WCVH6260HWW Kitchen Hood
Will not dispence fabric softner - GE Model: WCVH6260HWW Kitchen Hood
  • GE Master
  • 8,220 Answers
Fabric softener does not dispence
Just fixed the fabric softner dispenser for my wife, so I wrote a tip about it...
Fridgidaire Washing Machine Fabric Softner not going into washer
http://www.fixya.com/support/r5660917-fridgidaire_washing_machine_fabric
heatman101
Aug 24, 2010 | Frigidaire Affinity ATF7000E Front Load...
My fabric softner will not dispense into the washer
Clean out dispenser it maybe clogged due to softner,rember clean dispencer and machine once a month.
Jul 05, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Cant get it to use softner out of dispencer
if this is one of the newer(less then 3 years old) it probably has a button on the control panel that will say fabric softener. it will only flush the cavity out if you push that button. if it is an older model then the fill line for the softner cavity is brobably clogged
Apr 24, 2010 | Maytag EPIC MFW9700S Front Load Washer
Fabric Softner will not drain?
That stuff tends to build up in there.. Might be clogged.. See if you can get the dispencer drawr out and clean the pathway of the softener..
Hope this helps !!
Please rate me good ;o)
Jul 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
FABRIC SOFTNER DOES NOT DISPENCE
Check to make sure the litle cups are set in place correctly and also make sure they are not blocked with hard fabric softner. A quick test: pour water directly into the fabric sofnter cup and fill it up,IF it siphons out, you will need a new inlet valve for that unit. The inlet valve has soliniods on it for the bleach & fabric softner.
Good Luck!
Feb 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
Fabric softner does not empty
I had a similar problem and removed the complete dispenser drawer and washed it in with hot water. The small inner cups for the fabric softener and bleach should be removed and the hot water directed into the small "stand pipes" on the back side of the covers. It appears the fluids in the cups are siphoned out and if the pipes are clogged at the bottom there will be no flow. Also is the plate is not fully seated, the siphon effect is will not work.
Also, my wife said she does not use the cheaper brands of fabric softener anymore because we think that might have caused some of the clogging.
As a side note, if you remove the top of the washer, there is an adjustable dial where you can fine tune the amount of liquid dispenced. You can try adjusting that too. I think my final fix was to clean the back side of the face plates inside the dispenser and ensure they are fully seated to allow the proper siphon effect.
Jan 15, 2009 | Frigidaire GLTF2940ES Front Load Washer
The fabric softner drains out as soon as I pour it in
the fabric softner drains or flushs down in the rinse cycles,,,now if you fill past the line or open in dispencer it will sphion down by it self,,in short your overfilling dispencers,,onthejob
Jan 07, 2009 | Kenmore Elite 45986 Front Load Washer
Water collecting in the fabric softner dispencer
you need to take out dispenser draw and clean out under tap
the softner dispenser syphons out and if channels are gluged up the dispenser will not empty
Mar 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
NO FABRIC SOFTNER
The fabris dipencer hose was clug need to remove hose , clean w/ stick not so tight rinse w/ water then assemble .
Jan 09, 2008 | Kenmore 43142 Front Load Washer
Problems with fabric softener
check the water solenoid for open circuit, this is the water valve that supplies water to the compartment
Sep 28, 2007 | Bosch Axxis WFL 2060 Front Load Washer
GE Model: WCVH6260HWW Kitchen Hood Logo
145 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
