Question about Karcher Vacuums
Karcher K6.80 It pulsates on high pressure. What is the problem. Low pressure is OK.
Karcher K6.80 how 2 repair
Posted on Jul 27, 2012
My Dyson V6 started suction and motor pulsated instead of staying on. Filter cleaned - nothing blocking wand....help
Hello, this is Ava with Think Crucial.
There are a number of reasons why your Dyson cleaner is pulsating off and on. First, it can be due to a battery of the cleaner. Make sure that the power cable is properly plug to the power and seated properly from the unit while charging. If you find that the battery isn't charging at all, you may need to replace the battery. Second is to check the MAX button of your cleaner. If the button lights up and flashes when your Dyson keeps on pulsating, press and hold the power button and depress the MAX button to turn off the function. You may need to do it for a few times to get the hang of it. Third is to check for any blockages or clogs in the attachments. Look down through the tube and check to see if there are clogs on the sweeper end or if the roller is tangled up in fibers. Clean the roller brush are if it it's necessary. You may need to empty the dust bin of your unit as debris can build up in hard to reach places. Lastly, cleaning the filters may fix the pulsating of your cleaner. Remove the filter and rinse it with cold water and air dry it for 12 hours. Don't use detergent when washing your filters. If the pulsating doesn't go with the given quick fix, I suggest to contact Dyson for further assistance on this.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Jan 07, 2017 | Dyson Vacuums
My Dyson pulsates while I'm using it. It has a full charge, but hesitates.
There are a number of reasons why your Dyson cleaner is pulsating off and on. First, it maybe due to a battery of the cleaner. Make sure that the power cable is properly plug to the power and seated properly from the unit while charging. If you find that the battery isn't charging at all, you may need to replace the battery. Second is to check the MAX button of your cleaner. If the button lights up and flashes when your Dyson keeps on pulsating, press and hold the power button and depress the MAX button to turn off the function. You may need to do it for a few times to get the hang of it. Third is to check for any blockages or clogs in the attachments. Look down through the tube and check to see if there are clogs on the sweeper end or if the roller is tangled up in fibers. Clean the roller brush are if it it's necessary. You may need to empty the dust bin of your unit as debris can build up in hard to reach places. Lastly, cleaning the filters may fix the pulsating of your cleaner. Remove the filter and rinse it with cold water and air dry it for 12 hours. Don't use detergent when washing your filters. If the pulsating doesn't go with the given quick fix, I suggest to contact Dyson for further assistance on this.
Ava B.
Jan 03, 2016 | Dyson Vacuums
Karcher wv50 spare on off switch
If you contact one of the Karcher Centers ( details are on Karcher.co.uk website) they may be able to help.
regards Gary
Aug 02, 2014 | Karcher WV50 Window Vacuum
Can't switch Karcher window vac off
I had the same problem and I let the battery run down to stop it cycling on and off. My husband investigated it and found that there is a fault with the on board battery charge sensing circuit. (when the charge is about 10 to 15 % remaining the onboard ic controller cycles the unit on and off, irrespective of the switch. He checked it by cutting wires to the switch and it still cycled off and on so the switch was not faulty.
He put it all back together and said to charge it before it gets too low. If it cycles on and off it probably needs a re charge at that point.
Unfortunately there is no battery level indicator on the tool and nothing to suggest in the manual of what may happen when battery is flattening.
I am taking this up with Karcher as I only used it three times so far and it it was not a cheap gadget. Hope this helps
Mar 08, 2013 | Karcher WV50 Window Vacuum
Karcher 4.91 m leaking a lot of water as soon as hose is turned on, also rsulting in low pressure. It's approx 15 months old and used approx 12 times. Stored in spare bedroom during the cold winter. Was...
I could be that the rubber washer that is on the piece that the hose screws on to is dried out. Try replacing it. Any outdoor products store would have it.
Mar 27, 2011 | Vacuums
Cant get my soap dispenser hose working on my karcher winner 10, any suggestion?, lost my instructions manual so dont know weather i need to be doing anything for it!
If you have not yet found a solution, then here are some steps to take.
1. The soap dispenser only works on low pressure!!!!!!! So you have to REMOVE the high pressure Sprayer so that all you use is the Trigger Gun without the Extender.
2. Pull out the thin Plastic Hose with the filter attached in the end, and insert into your container of detergent.
It will only splatter the detergent over the area you want to clean, so you will then need to REATTACH the SPRAYER into the hand gun to work with the soap to lather, clean and spray of till clean.
This seems to be the way the system works on this model......also known as K2.36M (AU) in Australia or (EU) in Europe on the Karcher.com.au site then Service then Manuals. or on the link below.
Hope this helps any of you who has misplaced their Owners Manual just like I did and had a great problem trying to find a link as Karcher doesn't recognize the Model No: as Winner 10 or 11.
Cheers, Luke
Nov 19, 2010 | Karcher Vacuums
DE4002 Steam Vacuum: Is there a manual for The Karcher DE4002 steam cle...
Hi There,
Here's a link to the owners manual for your Karcher DE4002.
If you found this information helpful, please be sure to rate the repair helpful, or leave feedback. This is really appreciated.
Owners Manual For Karcher DE4002 Steam Cleaner
May 05, 2010 | Karcher DE4002 Steam Vacuum
My Karcher is leaking from the motor I think. Is it fixable? It's a KB 5050
My Karcher K 3.99 is leaking and dropped pressure. is it fixable (not filter)
Apr 04, 2010 | Karcher K DS 5500 Vacuum
I have just used the karcher steam cleaner and now cannot get the safety top off. Rio
i cannot get the cap off my karcher sc1122 even though its cooled down
Nov 16, 2009 | Karcher 1201 Canister Vacuum
Karcher Press & Ex 800
The water pump is not working or the pump line is blocked. Check the pupm hose, if ok replace water pump
Oct 09, 2008 | Karcher K DS 5500 Vacuum
Vacuums Logo
515 people viewed this question
Top Karcher Vacuums Experts
richie46
Are you a Karcher Vacuum Expert? Answer questions, earn points and help others
