Question about Sport & Outdoor - Others
I have lost the manual for the epic e760 and I can't get the power ramp down. It is locked in the full up position. We had it stored and now I want to use it. There must be a latch or a trick to getting it down.
Kimi
  • 277 Answers
SOURCE: Door latch is in "LOCKED" position however the door is open!
It is possible that you have a problem with the door?s sensor, maybe it?s turned off or maybe some water fell on it. This is the reason why the micro controller interpret that the door is still open, and that?s why the washing procedure does not start. You have to find the manual and determine where is the location of the sensor and then see in what state it is (Turned off, wet, or damaged)
Posted on Jul 12, 2007
SOURCE: LATCH belt storage in rear position
 it definitely is NOT self explanitory as to where the LATCH is supposed to be anchored when not in use. It took some time, but I figured it out. The Top Tether should be hooked on the recline prop/foot/base area - depending on which way you have this positioned - for forward or rear-facing use, the piece to hook the top tether on could either be towards the front (rf mode) or back (ff mode). It's just a simple cut out in the plastic. The Lower Anhcors need to be clipped to a small plastic notch along the back side of the seat shell - you have to lift up the cover to get a good look at them - they are towards the top of the seat on the back and don't really look like much but do secure the lower anchors when attached.
I hope that helps! Please let us know if there is anything else we can assist you with.
Posted on Mar 25, 2009
SOURCE: 2000 ford windstar - rear driver power door latch stuck in shut/locked position; can't close the door since latch won't open to latch closed
put a screwdriver in the latch jaws and force it open
Posted on Jun 11, 2009
  • 236 Answers
SOURCE: drivers door latch frozen closed while door is open
grab WD40, spray it excessivley, pull up on the handle, and at the same time, get a screwdriver and work it up
Posted on Jun 22, 2009
  • 75 Answers
SOURCE: hotpoint Door handle will not return to latched position
the spring in the door handle assembly is broken,the spring is replaceable seperatly.
Posted on Aug 24, 2009
Testimonial: "Will find part and replace. Thanks"
Power window won't roll up on auto
If window will not roll up it can be caused by a problem with the mechanism, no power getting to motor, bad switch, bad motor, fuse issue.
Feb 28, 2016 | Cars & Trucks
Unlock code and simlock for samsung sgh e760
Hi, You can get the unlock code for a Samsung SGH-E760 from www.superunlockcodes.com/samsung-sgh-e760/rs16wp9/ at affordable cost.
UNLOCKING STEPS FOR A SAMSUNG SGH-E760
Method 1:
1 - Switch ON your Samsung SGH-E760 with a NOT ACCEPTED SIM Card.
2 - Samsung SGH-E760 will ask for "Password".
3 - Enter the Unlock Code.
OR (if the Samsung SGH-E760 shows "Insert Correct SIM Card")
Method 2:
2 - Don't bother about what's being displayed on your Samsung SGH-E760.
3 - Compose : #0111*CODE#.
Oct 15, 2012 | Cell Phones
How TO UNLOCK network lock in samsung sgh e760
To Unlock SAMSUNG SGH E760 use Unlock code....Visit the site
Simpleunlocking.com/samsung-sgh-e760/rs16wp9/ get code and Unlock it ..You can enter code using the Unlocking instructions below and unlock it step by step.
Samsung SGH-E760 Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Samsung SGH-E760 mobile phones. If you enter over a certain amount of wrong unlock codes on your Samsung SGH-E760 mobile phone, your phone may get hard locked and sometimes become unusable.
Method 1:
Method 2:
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Samsung SGH-E760 is locked to.
CODE: Its the unique Unlock Code for your Samsung SGH-E760.
Can i lock the controls on my jazzy 1121
This is taken from the owner's manual from the 1121 with a VSI controller:
I suggest you print this out and keep it handy.
Locking/Unlocking the VSI
The VSI has a feature that enables you to
lock your power chair to prevent unauthorized use.
To lock the VSI:
1. With the VSI switched on, press and hold the on/off key. After 1 second, the VSI should beep.
2. Release the on/off key.
3. Push the joystick to the full forward position until the VSI beeps.
4. Pull the joystick to the full rearward position until the VSI beeps.
5. Release the joystick. There should be a long beep.
6. The VSI is now locked.
To unlock the VSI:
1. Press the on/off key and power on the VSI. The maximum speed/profile indicator should ripple up and down.
2. Push the joystick to the full forward position until the VSI beeps.
3. Pull the joystick to the full rearward position until the VSI beeps.
4. Release the joystick. There should be a long beep.
5. The VSI is now unlocked.
NOTE: If the above procedure fails to either lock or unlock the VSI, contact your authorized Pride Provider.
Jul 01, 2012 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
My VPC-E760 keeps saying card is locked but the sd card is not locked
For the card locked, make sure that you are using a 2GB or smaller card. The E760 can not use 4GB or larger SDHC cards. 2GB cards can still be purchased on Amazon if your local store no longer carries them. If you are using 2GB, then here are some more tips for card locked.
For the "lens error", see this article for tips and steps that might help you repair it.
Apr 11, 2012 | Sanyo VPC-E760 Digital Camera
Our treadmill is locked into the 12 degree ramp mode and will not go down. We have tried the reset button, tried turning off and reset, but it is still locked and will not go down. What could be the...
The incline sensor is probably defective and let the incline motor physicall jam against the stop. About 50% of the time a new sensor will cure the problem; otherwise, a new motor with the sensor is the cure. Either way the incline motor must be removed to address the problem and I would reccomend leaving this to someone with experience as you could possibly injure yourself trying to attemp this without the proper knowledge. The weight of the teadmill is on the incline motor and that is where the risk is.
Dec 31, 2010 | Epic 425 Mx Treadmill EPTL88105 !
Card is locked how too fix it
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Sep 25, 2010 | Sanyo VPC-E760 Digital Camera
Epic treadmill t60 is stuck in max incline how do
Usually when stuck at the max up position it indicates that you may need a new incline motor. It is not the sensor. I have been repairing treadmills for 15 years and incline sensors seldom if ever go bad. If can isolate the incline motor using a 110 volt power cord, this may un-jam the motor and get it back down to 0%.
I use www.treadmillpartszone.com for parts.
Jul 25, 2010 | Icon Epic T60 Treadmill
I left the red key in epic view 550 for 1 full day, next day when discovered now treadmill will not start, no lights, no noise, nothing!! Help
Check the reset/off circuit breaker located on the treadmill frame near the power cord. If the switch protrudes as shown, the circuit breaker has tripped. To reset the circuit breaker, wait for five minutes and then press the switch to the reset position.
Apr 30, 2010 | Epic View 550 Treadmill
Lost my installer cd
need software to down load, my computer crashed
Apr 11, 2009 | Sanyo VPC-E760 Digital Camera
Sport & Outdoor - Others Logo
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
