Question about Westinghouse LTV-32w1 32 in. HD-Ready LCD Television
Hello, my westinghouse tv has sound but no picture. when the tv is turned on, the pic comes on for a second then goes away. tv is 3 yrs old
  • 760 Answers
You have 1 or more bad lamps in your display panel. You can get replacement lamps, but there is a lot going on to change them. If you are not experienced in electronics, I would suggest you let a service provider fix it, or invest in a new set.
Posted on Apr 04, 2011
  • vidal chavez
    vidal chavez Apr 12, 2011
    Hello Csteven2727, the lamps have nothing to do with your issue, the problem is actually the board that controls the lamps which is called an inverter board. This board is in charge of providing power to the back light (florescent tubes) when the board functions properly, when this board goes out the lams no longer receive power which means they no longer turn on and you cannot see the picture. The rest of the TV should work fine which are the other electronic boars which explains why you have sound, also the power indicator light on the front of the TV should come on blue when the power is on and again the only problem is that you cannot see the picture. You will need to have your TV serviced at a local repair shop or you can email me at westytech@westinghousedigital.com to see what options you may have.
3 Horizontal lines distorting picture
When you say "distort the picture", are you referring to dark image? double picture
Jan 20, 2013 | Samsung Touch of Color LN52A650 52 in. LCD...
Westinghouse ld-3235 led tv no picture
t con board on the back of the screen will need replacing, its the one with the wires going to it from the main av board to the screen. the chip can become damaged due to heat or even come away from the board. if its working when you bag the board it could be a lose connector or the connections that is soldered to the board have come away and will need soldering back on.
Jun 05, 2017 | Westinghouse SK-32H540S 32 in. LCD TV
Television comes on with picture and sound but" picture" goes black after about three minutes, the sound stays on. If you turn it off for about 20 minutes and turn on again the picture will again go...
Look for cold solder joint in the power supply module, the easiest thing to do is to resolder all the connections on the power supply board. Also chek the DC outputs of the power supply.
http://s807.photobucket.com/albums/yy352/budm/Westinghouse%20LTV-32W1/
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps
Oct 02, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
My Westinghouse 36 inch TV has picture and sound when I turn it on but when I change channels, the picture disappears and I have only sound. The picture comes back if you turn the TV off and back on but...
Hello, it sounds like your inverter board is goin out on the set, when you change channels if you notice on almost any TV the screen goes dark and the new channel appears, it sounds like you are not getting enough power out of the inverter board to power up the backlight enough to come on. This is why the sound remains because everything else works fine and the sound is connected to the main board.
Nov 22, 2009 | Westinghouse LTV-27w6 27 in. LCD HDTV
40" LCD Westinghouse Pictures comes and goes rapidly
Take it in to a service center for an Estimate. Parts are very difficult for Westinghouse sets.
Jul 15, 2009 | Westinghouse Electric VK-40H580D 40 in....
Picture appears for 3 sec then shows no signal
HELLO MAKE SURE ALL THE CONNECTOR CABLES ARE TIGHT ON THE MAIN BOARD IF THEY ARE OK CHECK THE INVERTER BOARD FOR DRY JOINTS GOOD LUCK
SHAUN
Apr 27, 2009 | Westinghouse W4207 42 in. HD-Ready LCD TV
Sony KDS-60A2020 turns on, then pic goes off and on off and on.
Hi:
Replace you lamp or have it replaced by a technician. Lamps are only good for about 6500hrs depending on use. Thats about close to 3yrs.
Mar 10, 2009 | Sony KDS-60A2020 60" HDTV
TV has audio sound and no picture
major repair; requires 16 pin ic
Apr 19, 2008 | Televison & Video
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Keeps going black and coming back on - green light blinks
Our tv is about 2 1/2 yrs old and did the same thing we had to replace the bulb and bulb driver board this fixed the problem
Jan 27, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Westinghouse LTV-32w1 32 in. HD-Ready LCD Television Logo
1,370 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
