Question about Reddy Heating & Cooling
My heater starts and runs but then shuts off and I have to push the reset after a short cool down time before it will run again. I replaced the nozel, cleaned the photo eye, set the pump preasure, replaced the spark plug and air filter. It still shuts off.
    Brigadier General:
  • 4,736 Answers
In case you have misplaced your Owners Manual here is a link to where you can find it.
http://www.desatech.com/constructionheaters.htm
Where it' says Construction Heaters, open that and scroll down until you find the Model Number of your heater. Click on that Model Number and it will bring up the Owners Manual and you can download and print it. It has an extensive troubleshooting guide, that should help you.
Posted on Apr 04, 2011
Shuts off on its own after a short running time
You more than likely have a high temp sensor opening up the circuit when it reaches its limit. It would have to cool down to close again. Either that high temp sensor is bad or your heater is getting too hot.
Dec 12, 2013 | Enerco Brands Mr. Heater ENEMH55FAV...
I have a Nordyne Intertherm water heater in a 2004 manufactured home. The water heater is tripping the internal circuit breaker. The first time this happened I found that a wire nut had melted. I never...
hi,
if its an electric water heater then it sounds like a calcified or shorted element. you have to shut the water heater off at the breaker box, drain the tank and replace the elements theres usually two. they make a special element wrench at the hardware store they just unscrew and screw back in. make sure all your electrical connections are tight..
jm
Jul 04, 2017 | Heating & Cooling
Tv shuts down after 20 mins or so need to unplug for a time to re start then will run again for a short time
projector tv works like a projector.
the superhot bulb needs cooling, and if the cooling fails, it shuts down.
so what you have is either the fan is not working, or the cooling system is not working.
have to fix it professionally.
Jul 01, 2011 | Hitachi Televison & Video
I have an older 30,000 BTU spark plug type kerosene Reddy Heater. My problem is this; The heater will run for an hour or so then shut off. It seems as though it needs to cool down before it will allow me...
http://www.reddyparts.com/FAQ_spark_plug_heater.htm
Try the link below. You can run down the list of checks and also get parts. You need to repalce the nozzle or clean it yearly. If it's older replace plug too. Check pump pressure.
Jan 10, 2011 | Reddy REDR40T Heater
Fire stoppes and fan still runs
1st take a air gun and blow in the fan to clear of debris. 2nd make sure to push your reset button on the back by your fan. Last you can calibrate your flame/heat by removing the fan housing & you will find 2 set screws try a small 1/16 turn on them and try to run, should run better for you.
Oct 09, 2009 | Master Heaters BLP375AT
Sterling garage heater wont always light.
The flame sensor is dirty - have the unit serviced. Modern furnaces require regular maintenance!
Mar 10, 2009 | Sterling RF30 Natural Gas Garage Heater
Htr shuts off after awhile and won't come back on till it's cooled down
I had the same problem with my heater. It was a cracked fuel line. I replaced the rubber hoses. On mine there was a pick up hose and a feed hose. They were dry cracked. Works great now. Hope that helps you out.
Nov 02, 2008 | Reddy Heater-30-55,000 BTU Variable
Heater kicks out
Honeywell heaters like HZ3650 have a screen on the air inlet at the back side of the heater. This screen can be partially blocked off by an accumulation of lint, etc. The lint blocks some of the air flow which may cause heat increase within the heater to the point that the safety shutoff thermostat shuts off the power. Operation is returned after a cool down period only to repeat the shut down cycle after a short period of operation. If this is the cause of the problem the screen must be cleaned.
Sep 19, 2007 | Honeywell HZ365 Ceramic Compact Heater
Heating & Cooling Logo
82 people viewed this question
Top Reddy Heating & Cooling Experts
Mack Baxter
paulcarew
Richard Marsh
Richard Marsh
Level 1 Expert
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
