Question about EIO Estate Bagged Canister Vacuum
Where to buy filter bags for Varia Estate EIO typ BS 97/9 Nr. 7594604?
3 Suggested Answers
advacak
  • 125 Answers
SOURCE: Eio Varia Estate Vacuum cleaner
contact the VDTA its a vacuum trade association. they will have contact info for all mfgs
Posted on Dec 02, 2008
SOURCE: were do I get replacement
4dfa5d4.jpg advacak
  • Rank: Wiz small_appliances_small.png
  • Rating: 83%, 100 Votes
contact the VDTA its a vacuum trade association. they will have contact info for all mfgs Call Suburban Vacuum Cleaner Parts at 1-877-592-5888 and they stock them.
Posted on Jan 07, 2011
Euro-pro EP57 vacuum bags
Call
EURO-PRO Customer Service at: 800-798-7398
514-842-8691
or Fax to: 514-842-6985
Monday to Friday 8:30 AM - 5:00 PM Eastern Standard Time
Replacement set of 2 Cloth Bags and 2 sets of Filters: $10.95 + $3.95 Shipping & Handling
Replacement set of 10 Paper Bags and 2 sets of Filters: $ 9.95 + $3.95 Shipping & Handling
Jan 30, 2013 | Euro-Pro EP055 Bagged Canister Vacuum
Nilfisk TYP GSD thermovalve
Hi There, The GSD components are now discontinued. You have to buy a new head unit to replace as a drop in unit.
If you are in Australia you can buy one here they are not cheap thought at $490
Dec 06, 2012 | Nilfisk GM 80 Bagged Canister Vacuum
Where do I get teh EIO Baria Estate or cottage replacement bags>
www.eio-vacuum.best-price.com
This is the web site that you can order bags from...if this helped you please remember to click on the yes box on the way out if you are satisfied with your answer. THANK YOU AND GOOD LUCK
Oct 10, 2010 | EIO Estate Bagged Canister Vacuum
Were do I get replacement bags for the EIO varia estate vacuum?
4dfa5d4.jpg advacak
Aug 24, 2010 | EIO Estate Bagged Canister Vacuum
Electrolux Model 2100 vacuum won't work
hi from uk may i suggest you remove cover and the new dust collection bag then if you look in the bag compartment there is a gauze filter fitted usually grey in colour ? at opposite end of compartment where bag connects this gauze filter is the outlet from bag compartment that the air exhales when vac is operating ie as vac **** up dust into bag the bag has microscopic holes that allow sucked up air and dust to collect but keeps dust from passing into bag chamber but allows air to escape thro holes and so enter bag chamber then escapes via the gauze filter to outside of vac hope you follow this ?? now if this filter is blocked/never been cleaned/changed ? then the symptoms of indicator bag full light will come on you can remove and wash filter if it is gauze typ? dry and refit then try vacuuming ? or replace filter they are not expensive usually in pack of 3 in uk DO NOT RUN VAC WITHOUT THIS FILTER FITTED ! or you will have some dust in the room ? hope this helps?
Feb 27, 2010 | Electrolux UltraLux 2000 Bagged Canister...
Filter cleaning
The fact is that the "bagless bandwagon" is powered by some excellent marketing that conceals what is often poor technology. In your case, the filter blocks because it's doing the job that a bag would do in a bagged machine (catching the dust), and then the machine overheats because the flow of cooling air to the motor is restricted. The only solution (for this machine) is to keep buying new filters - the only permanent solution is to buy a different vacuum cleaner. And my advice is to buy one with a bag!
Nov 03, 2009 | Dirt Devil M0105 Bagless Vacuum
Black & decker parquet 1800w hepa h13 need
I'm not sure what bag your referring to. The only bag for this is the carrying bag. So I have to assume you mean one of the filters.
There are three filters for this vacuum.
  • Primary Filter.
  • Exhaust Filter.
  • Secondary Filter Element.
I have included a link to a site that carries the replacement parts and a diagram of the vacuum.
Hope this helps.
On another note If it doesn't help I really don't feel to bad because I'm in Detroit Michigan. And I'd rather have a dozen useless vacuums hanging out in New Zealand any day. :)
Find me a job there and I'll buy you a new vacuum. :)
http://www.ereplacementparts.com/black-and-decker-hv6000-type-opp-corded-hand-vacuum-parts-c-4167_8887_10329.html
Oct 17, 2009 | Black & Decker HV6000 Bagged Handheld...
How do I work a Salton vacuum bag sealer (Model BS-20)? I can not figure out how to get the air out of the bag.
This style of vacuum sealer has to use a special bag with a " dimpled " surface to let the air escape through the pinch jaws of the vacuum sealer.
The folowing web site has bags and rolls that can be cut ro make any size of bag you require. You can buy on line direct from the manufacturer as well as purchase more industrial vacuum packers
http://www.foodmc.co.uk/Category/113-textured-bags-for-external-bag-machines.aspx
Jun 14, 2009 | Vacuums
Oreck 4080 the bag fell off the vacuum,
If the bag doesnt have a bag holder then the bags just push onto the black connector - there is usually a hook at the top of the oval connector where the bag once pushed on, sits over the oval dust channel feeder and locks into place. Once the Oreck is switched on, the bag in theory should stick to the oval hole.
Jan 16, 2009 | Oreck Vacuums
Aug 12, 2008 | EIO Estate Bagged Canister Vacuum
EIO Estate Bagged Canister Vacuum Logo
53 people viewed this question
Top EIO Vacuums Experts
Are you an EIO Vacuum Expert? Answer questions, earn points and help others
