Question about RCA HD52W59 HDTV Projection Television
How do I setup my cable on this television set?
  • 760 Answers
If you are running cable straight from the wall, all you need to do is connect it to antenna, go into your user menu to channels or set up, and the set will auto program. If you are using a cable box, just connect it to what ever input suits you the best and leave the set tuned to that input.
Posted on Apr 04, 2011
How to do a complete initial setup on olevia 542-b11
Olevia initial setup Questions & Answers - Fixya
www.fixya.com > Forum > Tags > initial setup
I hit the reset buttom to default how do you setup auto channel ... i have no channel its not listed in the set up menu you have to do a complete initial setup .
How Do I Set Up Channels On An Olevia Television
www.mademan.com/mm/how-do-i-set-channels-olevia-television.html
Jun 17, 2010 - If you have figured out how to set up your cable box or antenna to yourOlevia TV, then the hard part is done and you just need to find an ...
Olevia auto channel search Questions & Q&A -Q&A - Answer
www.dqrkc.com/tags/auto_channel_search/browse/olevia
Dec 22, 2015 | Olevia Televison & Video
Mitsubishi Television Model WT42311 HD1080
ok sir! you said you got snowie screen!? make sure your cable is in good condition! or can you tell me the main problem of your unit?
Oct 21, 2007 | Televison & Video
The volume controls on both my remote and my Philips flat HDTV 37PF7320A 37." How do I fix it?
Read your Philips setup info that came with your tv very carefully and also if applicable read your cable box setup info very carefully then set every thing up like it says also check tv audio menu and make sure the audio is set to on
Sep 13, 2014 | Philips 37PF7320A 37 in. HD-Ready LCD...
How to connect a philips antenna to a trutech tv
Unplug your television and turn the set around so the back of the set is facing you.
  • 2 Disconnect the antenna or cable connection from the television's "VHF," "Antenna In" or similarly worded port if it is connected.
  • 3 Examine your splitter and notice one end of the device has a coaxial port while the other end has two coaxial ports.
  • 4 Plug the coaxial end of the television antenna into one of the two coaxial ports on the splitter.
  • 5 Plug the coaxial cable coming from the cable television connection outlet into the second coaxial port on the splitter. Use the port next to the one you used to plug the television antenna into.
  • 6 Place one end of a 2 foot piece of coaxial cable into the single coaxial port on the splitter.
  • 7 Plug the other end of the 2 foot piece of coaxial cable into your television's "VHF," "Antenna In" or similarly worded port.
  • 8 Plug in the television set and turn it around so the screen is facing you.
  • 9 Use your television's remote control to access the "Menu," "Setup" or similarly worded function. Or press the "Menu" or "Setup" button on the front of the television.
  • 10 Select the "Channel Setup" or similarly worded function. Set the Input to "Cable" and perform an "Auto Scan" to locate all available cable television channels.
  • 11 Select the "Channel Setup" or similarly worded function, then set the input to "Antenna" and perform an "Auto Scan" to locate all available broadcast channels. Your television will locate both broadcast and cable television channels.
  • 12 Scan the channels on your television to make sure all available channels have been found. If you are missing any channels that you know you should have, manually program the channels into your television using the "Channel Setup," "Manual Channel Setup" or similarly worded function.
  • Oct 17, 2011 | Televison & Video
    The TV works however I cannot get the set to read the channels. I have cable but no cable box. Have tried to program it for over 3 hours. I've tried it using ch.3 and ch.4. through the remote. After I scan...
    U used the tv remote go into ur tv SETUP.Pick Cable,before u scanning for cable chanels?U have pay cable?Must scan for cable chanels,by setup for looking for cable channels.
    Mar 18, 2011 | Televison & Video
    Just got tv yesterday, hooked regular cable wire into outlet on tv labeled cable/antenae, tv works, but not receiving cable channels
    when you go into the customer setup menu in the channel scan area make sure the set is set to cable also us ez setup if that does not solve your problem return it
    Nov 27, 2010 | LG 42LC2D 42 in. LCD HDTV
    How do I launch a channel search?
    you want to either find menu or setup on your remote. then choose the section that has something like channel setup or auto setup. just let your set scan through to see what channels you can get. if your tv has a digital tuner than you will receive more channels
    May 03, 2010 | TruTech PLV1615T 15 in. LCD Television
    Insignia NS-L42Q-10A Setup: Wrong TV Source Chosen
    You can change this option by going to the "Channels" menu and selecting "Auto Channel Search." Additional details can be foundat InsigniaProducts.com, under the Support tab for your TV.
    Mar 09, 2010 | Insignia NS-L42Q-10A LCD TV
    I have no sound on my games or movies but i have great picture.
    You need to do one of two things:
    Make sure that you have an audio cable (red/white connectors) going into back of television to get sound through the television
    If this is already hooked up and the cables are not defective:
    Make sure that the settings on the playstation are set to recognize the audio cable setup that you have going into the tv (red/white connectors versus optical out vs. digital coax, etc.) Make sure that the playstation setup matches what you have setup in your system.
    Feb 01, 2009 | Sony PlayStation 2 Slimline Console
    RCA HD52W59 HDTV Projection Television Logo
    Top RCA Televison & Video Experts
    matt martin
    matt martin
    Computer Repairing
    Computer Repairing
    Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
