Question about Sharp ELM332BBL Calculator
Sharp EL- M332 caluclator- have a 'O' along top line- can't seem to get rid of it- must have accidentally selected something. It is not showing any decimals.
Hold (C.CE) then whilst holding it press (M+) for approximately a second and it will move one place along in the three settings (F, 2 and 0) F shows full decimals, 2 shows 2 decimal places and 0 as yours is set to now round to the nearest whole number. I have just been sat at my desk trying to work this out as my calculator was too set to '0'. Took me reading the 'DEC DET' text with lines pointing at 'M+' and 'C.CE' to finally crack it!
Hope this helps.
Posted on Oct 17, 2011
Sharp el w531 wont give answers in decimal
Press the CHANGE key to cycle through the different views.
If you don't want results showing up as fractions, switch out of the WriteView mode into the Line mode. Press SETUP, select "EDITOR" then "LINE."
If you need a manual, you may download a copy at http://www.sharpmea.com/cps/rde/xbcr/documents/documents/om/30_cal/elw531-g-h-ha-w535_om_gb.pdf
May 06, 2014 | Sharp Office Equipment & Supplies
I accidentally entered a function on a calculatot
No you do not have an exponential p. The p at the bottom right of the screen says that the numeration mode is the one in base 5 (pental mode). Change it to decimal (Dec). Find the key that has the marking (->Dec) above in on the faceplate of the calculator. It s probably the + key. Press [2nd F][+] (>Dec). The letter p will disappear.
Mar 04, 2014 | Sharp el-531x scientific calculator
Can't get rid of deg in sharp calculator
It simply indicates that the calculator is set to degrees. The calculator has three angular modes (degrees, radians, and grads). No matter which mode you set, the appropriate indicator will light up.
Dec 06, 2012 | Sharp Scientific Calculator El-509s,...
Hi I have a sharp el-W535 and want to know how to get rid of the fracton in the line editor as the answer so I can get .500 for example
To change from fraction to decimal, all it takes is a keypress. (change key)
.Not all decimal results (approximations) will be converted to fractions.
Anyway, if you want to set the calculator to display decimal results only,
Press SETUP
Press 2:EDITOR
Select 1:LINE.
Jan 26, 2011 | Sharp ELW535 Calculator
How do i get rid of the "p" on my sharp caculator. I have a EL-520W
On the back of the calculator, there is a little "reset" hole. Use a pen and press it into that hole for a few seconds, then release. You should now be able to turn on your calculator as if it was brand new from factory without the "p".
May 19, 2010 | Sharp EL-520WBBK Calculator
Setting correct date
You may download a copy of the manual here. The clock setting instructions are in the middle of the first page.
Sep 02, 2009 | Sharp EL-1197PIII Calculator
Get rid of the RAD
You use the key combination [2ndF][DRG]. Every time you press the two keys in sequence it changes to the next angle unit. If your calculator is on RAD, you press [2ndF][DRG] once to change to Grads, and another time [2ndF][DRG] to change to degrees.
Hope it helps
May 09, 2009 | Sharp EL-531VB Calculator
Unable to open any of my applications
from program's menu select system tools and restoration. restore to an earlier restore point(available restore point dates will be in bold). have good spyware. my recommendation is spybot software.
godd luck!
dont forget to rate this post
Aug 21, 2008 | Acer Aspire 5100 Notebook
2 parallel lines show up on the copies
try to clean the cover glass at the top of the copier with alchol.
be sure that ther is no any dot or lines on top of tha glass specialy the right side.
Apr 11, 2008 | Sharp AL 1631 Copier
FIX numbers
If you press the setup key then 1 under FSE it will say TAB (0-9)? enter the amount of decimal places you want and it will change that for you.
Dec 06, 2007 | Sharp EL-531VB Calculator
Sharp ELM332BBL Calculator Logo
291 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
