Question about Panasonic 471 Bagged Upright Vacuum
The motor for the carpet brush is not working is there a reset button?
I have a Dyson dc17 I have changed the belt cleaned the brush bar clean the bar motor reset the switch and still when i vacuum the brush bar just stops does not rattle. does not do it on bare floors or...
hooked rugs produce the highest amount of friction opposing the brush rotation, which can over heat the drive motor. try using a height setting that raises the brush so that it barely touches the pile. If this issue has been going on for some time, you may need to replace the drive motor.
Jun 26, 2014 | Dyson DC17 Animal Bagless Upright Cyclonic...
Hi, i have a panasonic eco max, the brush has stopped going round, the belt is as new and brushes clean.suction good from hose. Any ideas please? thank you
The brush on this model is controlled by the on/carpet/floor switch and will only work in the carpet position. If the suction motor is running then it could be the roller brush motor, but it's more likely to be the microswitch which stops the brush motor when the handle is returned to the upright position.
Dec 03, 2012 | Panasonic Mc-Ul594 Eco Max - Bagless...
Dyson DC14 reset button location
go to http://content.dyson.com/support/?basketTotal=0.00&basketQty=0&logged=false
proceed with your models, and see videos or troubleshooting or video for to se the reset button.
God bless you
Aug 02, 2012 | Dyson Ball DC24 Bagless Upright Vacuum
My broan cv30 purchased in 1996 carpet power head unit sucks up dirt and rocks but will not pick string or yarns up from carpeting. I find myself picking it up. It is sucking fine dirt and small...
It's possible you simply need a new belt or roller brush. Place the power nozzle upside-down turn the vacuum on. Ensure the brush turns. If it doesn't, the belt has broken or is too worn to turn it. Replace the belt. Make sure the tension is properly set prior to reassembling the power nozzle.
Next, with the power nozzle upside down, run the flat of your palm across the brush area. If you can barely feel the bristles, it needs replaced. A good brush will loosen the yarn and strings, but needs to be cleaned periodically.
As long as the powerhead motor is running, there is no need to replace it. If it's not running, look for a reset button and press it. There could also be a broken wire, loose connection, or bad switch causing a power head motor to not operate..
Dec 31, 2010 | Broan-NuTone Vacuums
The carpet sweeper on my electrolux stopped working....used it for a little bit and then it just stopped
Make sure the brush is cleared and clean, press the reset button, and try again.
If the motor runs, but the brush doesn't turn, it's likely due to a broken belt. Have it replaced by someone who knows what they're doing.
I strongly recommend taking it into an authorized shop.
Dec 04, 2010 | Electrolux Vacuums
I've had my Kenmore Progressive canister for at least several years and never had a problem. Now, the carpet head brush does not rotate, it's not getting the connection unless I push down maintaining...
Hi, try pushing the reset button with a pen or paper clip. If that doesn't work, the motor may need to replaced. If the reset button is stuck, if the reset button is stuck, use a pair of tweezers to pull it back out......
Secondly, your belt can also be broken or has come off the pulley. Remove the bottom plate and investigate.
Sep 19, 2010 | Kenmore 25512/ 25513 Progressive Canister...
Brushbar has stopped spinning on Carpets
Because the brush bar is electric, it automatically shuts off if you get something stuck in it to keep the motor from burning up. you have to remove the item and then push the small reset button on the side of the brush bar<!-- from fixya rte -->
Jun 29, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
My Sanitaire vacuum is not picking up well - works ok on floors but not on carpeting
Depending on the model you may have a single or two motor system. If it is not running well in carpet mode but still has suction check to see if the brush for the carpet head is turning. If not look for a red reset switch or spin the brush when the vac is shut off. It it spins freely the belt is either broken or badly stretched and needs replacement.
Sep 05, 2009 | Vacuums
I cant get the power brush to work is there a reset button? the vacuum is only 2 months old dirt devil 12amp bagless featherlite
can you turn the brush by hand? if it turns real freely the belt is broke or the brush siezed up make sure there isn't any carpet strans wrapped around the ends of the brush otherwise the brush won't turn.if its the belt make sure you clean the motor shaft before you put on the new belt,the old rubber from the old belt will make the new belt run unevevly and break again..good luck
Apr 06, 2009 | Dirt Devil M085850 Featherlite Bagless...
Panasonic 471 Bagged Upright Vacuum Logo
23 people viewed this question
Top Panasonic Vacuums Experts
jasbo
jasbo
Joseph Hoffmann
Are you a Panasonic Vacuum Expert? Answer questions, earn points and help others
