Question about Hotpoint HSS25GFP Side by Side Refrigerator
I HAVE A FAIRLY OLD USED AMANA REFRIDGERATOR WITH A FREEZER ON TOP...OVER THE PAST FEW WEEKS, BOTH THE FRIDGE AND FREEZER HAVE HAD A CHEMICAL/ALCOHOL-ISH SMELL...THE BUTTER AND FRUIT TASTE LIKE IT...I HAVE CLEANED IT THOROUGHLY AND IT STILL SMELLS ? ANY IDEA HOW TO FIX THIS OR WHAT MAY BE CAUSING IT ? SINCERELY STINKY FRIDGE OWNER- DANIELLE
    Brigadier General:
  • 3,917 Answers
Hi
All items stored in the refrigerator and freezer should be stored in sealed packaging. Frost free refrigerator operate with a very low humidity and will pick up odors from products. Somewhat of ozone smell will be in some frozen foods. This is a normal condition. Open food stuffs, and possibly a burning electrical connection or component Deodorizing packs are available on the market to absorb odors. Also put an open box of baking soda in freezer and refrigerator sections this will absorb odor. However It might be a Freon leak either.
Also this smell causes by a faulty heater or the heater could be melting the plastic where it is positioned. Un plug the refrigerator and remove the back panel inside the cabinet. Look for any signs of burning. If there are no signs of burning then it could be the insulation within the panel work rotting. Try sealing all the edges with sealant. Also, check that the drainage hole inside the cabinet is clean and clear. If you pull the refrigerator out and look at the back, usually at the bottom is the compressor (black motor). On top of the compressor is a plastic tray which collects the water from inside the cabinet, make sure that is clean. Be careful as the compressor will more than likely be hot. Do not pour lots of water down the drainage hole as the plastic tray can only hold so much. If you over fill this tray the water can spill over the electrics for the compressor.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Apr 04, 2011
Our Amana refridgerator does not get cool but the freezer works.
I would think that the slide from the freezer to the fridge is frozen over. You will need to check the top of the fridge to see where the air should be coming in from and see if it is clear or not. If the freezer is working then there is no reason for the fridge not to work also, has to be an air flow problem. Look for ice build up blocking the air.
Sep 07, 2012 | Amana Refrigerators
Water dripping inside KTLA22EMSS01
Your freezer actually cools your fridge. It sounds like you have ice build up in your freezer behind the back panel. You should be able to unscrew the back wall inside your freezer. A hair dryer should help defrost or keep it open for a few and use a screwdriver to remove the build up of ice. The ice has made its way down the vent and when it hits the fridge it is above 32 degrees so it is melting. Hope this helps. I manage rental properties and have had it happen on a few occasions.
Aug 16, 2012 | KitchenAid Refrigerators
Refridgerator door sags
Its a two person job. One person has to looses up the two hidges holding the door just slightly while the other person holds the door in place. Once in place tighten the screw/bolts for the hidges back up and check. If not aligned, redo it again until it is aligned and seals properly..
Good Luck!
Sep 15, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Fridge not cooling
The evaporator fan needs replaced they are fairly inexpensive.
Sep 04, 2009 | LG LRTP0931 Top Freezer Refrigerator
The the refrigerator just stop working
a new fridge is probibly needed. The sounds you heard was possibly the reeds in the compressor that were going bad. Good Luck
Dave
Jul 24, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Frigidaire model FRT21H7AS Not cooling, compressor makes noise
HI, The relay has gone bad and needs replaced. Probably not the compressor. Fairly common problem with these new fridges.
Let me know if I can assist you further.
Vic
May 18, 2009 | Frigidaire FRT21H7AS Top Freezer...
Amana refridgerator
water valve is in the rear on the right side at the bottom
unbolt it from the ref frame and pull it outward remove the hoses the white plastic ones place a pan under the valve and depress the qater in the door paddle if water comes out of the valve then it is good if no water out of the valve verify the voltage to the valve if 120 to the valve then replace the valve
if no voltage problem lies in the wiring harness or the despensor mech. has a problem
Apr 25, 2008 | Refrigerators
Refrigerator compartment not cooling
If you are sure the fan in the freezer is running and you don't feel any air flow out of the top middle vent inside the fridge section, then the damper motor must be bad. The damper motor is behind that vent cover inside the fridge section.
Nov 16, 2007 | Amana AFD2535DES French Door Refrigerator
Hotpoint HSS25GFP Side by Side Refrigerator Logo
49 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
