Question about RCA TH1101 MP3 Player
My MP3 keeps shutting off
I use my player when I work at the factory, so it gets dusty. I've also dropped it a couple of times. I took it apart looking for a broken battery wire, but that's not it. At least I haven't made the problem worse by poking around inside. The problem is it has started shutting down on me, which is really annoying when I'm in the middle of an hour long podcast or audio book. Strange side effects: often the shutdown occurs when I twist the plug to the earbuds. My favorite pair has a dead bud, which could, I suppose, cause a mini arc (before this problem began, the player would occasionally shut off if I shocked myself on a door knob). But I've tested the player on several headsets and it still wants to wink out. When it does, the display goes blank and the sound stops, but there is a faint background noise that persists until I pop the battery. Often when I try to restart, the "PEARL" icon appears, but it never goes to the "Please wait..." window. It just sits there. I usually have to pop the battery twice before it comes back, and then later on, it cuts out all over again. The problem doesn't seem to affect the player's function as a jumpdrive. Only once has it failed to interface with a computer. That one time, the screen came on (I had plugged it in cold, as usual), and instead of getting the "USB connected" window, the display simply said "PEARL" until I removed the battery, and then I could sync files just fine. Sorry for the essay, but since you can't tinker with my device yourself, I thought I should be as thorough as possible. Any suggestions?
  • 8,596 Answers
Try upgrading the firmware - otherwise, see if it's still under warranty by calling RCA - those conditions that you describe are more than sufficient to damage the player. Unlike TVs, mp3 players do not generally have saleable internal parts. If in warranty, just replace- don't tell RCA that you dropped it, or the warranty is voided
perform a firmware upgrade to
restore it.
– Please go to http://www.rcaaudiovideo.com/faq
for more details.
-Tha Mp3 Doctor
Posted on Sep 04, 2008
Why won't my Sansa 250R won't recognize an sd card?
Your 4GB card is actually a microSDHC card. The e250 works with microSD cards, 2GB and smaller.
Mar 10, 2013 | SanDisk Sansa e250 MP3 Player
My JVC KD-HDR50 was working perfectly up to a couple days ago. While driving it spontaneously powered down and back up again. None of my setting were changed. Later on, it powers down again and this...
did you hard-wire the radio(wired direct to your factory wiring) or use an integration harness to your vehicle? My first thought would be the wiring. Check mainly the yellow, red and black connections. if those are intact, next look at the harnesses, Be sure they are nestled together correctly, and all the wires are secure on both ends. If they are loose on the harness side, some hot glue should help to keep the wire in place. If the nestling of the harnesses is bad. then I would say just go get a new harness for $20 and re-wire it. You may end up with more problems down the road if you keep the same one and it's faulty.
If the wiring is all intact then my assumption would me the internal radio amplifier. They can spontaneously go bad at times, and cause an on then off again effect once it cools down. Sometimes off for extended periods of times as well. if that's the case. Just go for a new unit.
Jan 06, 2011 | JVC KD-HDR50 Car CD/ MP3 Player
Mp3 player full and can,t reset it.
ohh..i had a friend too who bought a chinese brand touch screen cellphone. .something about he just accidentally dropped it and the thing didint work back again..ever..like **** ..what the ****..just sayin that chinese brands are like not that gOod
May 18, 2009 | Jwin MP3 Player
Won't Work suddenly.
What is happening when you turn the device on? Does it go on and then shut off? If so you will have to reformat the drive for the mp3 player. Simply plug the mp3 player in and click the drive that appears for the player. It should say this device needs to be formatted. Then just follow the steps. Keep in mind you will lost your songs. If the device stays on, do you see your first song on the list. If you do, try pushing the play button, (very last one on bottom) hard.
Dec 08, 2008 | TruTech SMP-1 GBL MP3 Player
MP3 Player keeps shutting off
restore it.
for more details.
-Tha Mp3 Doctor
Aug 05, 2008 | RCA TH1101 MP3 Player
Did my BATTERY short, or my whole PLAYER?
I have yet to see an Mp3 player that can survive a water drop. You can "dry out" the player, and it may work sometimes. Replacing the battery most likely will not fix.
Apr 15, 2008 | SanDisk Sansa e260 MP3 Player
Shut down by itself
is it hot when it shut off ?.
if yes, please check the fan and heat sink. is it dusty ?
you just need to clean it up. make sure there is air come out from heat sink door.
Apr 06, 2008 | Acer Aspire 3000 Notebook
Won't turn on at all
Hello, I just fixed a friend of mine's mp-c7085. Same situation. Kid just got it for christmas, dropped it and it stopped working. I took it apart and found that the on switch broke it's soider connection to the board. I carefully resoidered the switch and it works. You can tell for sure if you take it apart and squeeze the on switch to the board while you try turning it on.
Feb 01, 2008 | Coby MP-C7085 MP3 Player
MP3 player not working even though its powered up keeps shutting off
hi,
it seems to be a problem with the battery.,,,i m sure replacing it with a standard one will solve it,,,,
Oct 14, 2007 | SanDisk Sansa e270 MP3 Player
Dropped MP3 player
It depends on wether the MP3 was dropped in water. If it was, it PROBABLY be dried out depending on the severity of the problem. If it wasn't, it's probably broken. If you plan on getting a new one, I suggest an RCA Lyra. They're very durable and tough. I've already dropped it 6 times at school and not one problem so far. Hope it works
Jan 01, 2007 | Creative Labs Zen Micro MP3 Player
RCA TH1101 MP3 Player Logo
41 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
