Question about Vizio VO47L 47 in. LCD TV
HAVE A VIZIO GV47L. NO SOUND. NO PICTURE. While watching TV the TV went black. Tried turning it off but was unable to via remote or the touch panel.Finally unplugged it from the power surge protector. when I pluged it in I switched the TV on using the remote but still getting a black screen. Touch panel and remote still unable to switch TV off. Can you assist on a diagnosis?
  • 4,889 Answers
Despite of no image do you still have sound(happens in case of malfunctioning backlight or T-con board)?
Posted on Apr 04, 2011
  • 5 more comments
  • lroman879 Apr 04, 2011
    no sound
  • eagle338
    eagle338 Apr 04, 2011
    If the tv turns on and does not respond to any commands and there is no picture, it is definitely due to a malfunctioning tv-micro circuit. Easiest way to fix this would be to replace the main A/V board. Please remove the back cover off the tv and get me the part number off the board so that I can find you a replacement
  • dnitzman Apr 05, 2011
    I am having this same problem. Is this a fairly easy fix or should I find a repair person?
  • eagle338
    eagle338 Apr 05, 2011
    Well iys not that hard if you have the basic know-how of electronics i.e, ESD precautions, which components hold residual voltages and hence should not be touched etc., The replacement is fairly simple just unplug the connectors from the older board and plug them into the newer one.
    What about the fuse bypass some people are talking about? I found the 3 fuses on the upper right of the board. 2 of them are white and 1 is brownish. I haven't put a meter on them, but what do you think of the bypass solution some people are using?
  • eagle338
    Which board are you referring to? Power supply? And if yes then are all the fuses of the same type?Note that ceramic fuses come in different colors even though they are usually white. You need to test them with a meter to confirm that its open. So please do so and let me know
I received a VIZIO VA220E from my kids Christmas 2009 for my kitchen. Kitchin finished and TV wall mounted in April 2010. About 6 weeks ago I was not able to turn on in AM after watching the night before. BLACK SCREEN / NO AUDIO.
Now what?
Posted on Apr 11, 2011
My Vizio LCD TV went out. Its just a black screen. The Vizio symbol turns on and off but no picture and no sound. It sounds like its similar to most peoples issues on here. How do I know if its my mai
There could be a few things that would cause this. I would suspect that you have a problem with either the power supply board or the main board. Based on my experience, the main boards go before the power supplies. What is the model #
Jan 26, 2013 | Vizio E550VA 55 in. LCD TV
My Vizio p50hdtv herd spark, and TV went black, no picture no sound
Check and replace the main power regulator board as card basis. It has damaged.
Oct 11, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
My vizio gv47l went black. where do i start
Search on blown fuses for gv47l. There are three fuses that you can check (open the back of the TV) and if one is mad you can jumper it with another fuse. I did this nad it fixed my gv47l
Dec 03, 2010 | Vizio GV47LF Television
I have a Vizio GV47L LCD TV. I bought this about 3 years ago. The other day when it was on and working fine, I went in the other room for about 5 minutes and when I came back in it was making a fizzle...
ANy sign of DC filter caps with open top (may be that was the sound you hear was cap is blowing its tops). You need to do some voltage checking and some visual inspection.
http://www.shopjimmy.com/catalogsearch/result/index/?q=Vizio+GV47L&limit=100
You have to remove the heatsink to see the caps under it.
Post back what you see.
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Aug 31, 2010 | Vizio GV47LF Television
VIZIO TV Black screen. Cannot turn off TV without unplugging.
I had a similar problem after having a Vizio for 2 and a half years. I left the room for a minute, i came back and the screen went black. I didnt hear an arcing sound though. There was still power to the unit and you could see that the back light was working, just no picture, no sound, and you couldn't use any of the buttons. The only way to turn it off was to unplug it. It would then start up, with the Vizio logo going from orange to white, and then do the same thing all over, no pic or sound. I would check the ceramic fuse first on the board that gets power from the plug.
HOW I FIXED MINE: I ordered a new "main PCB" from tigerdirectparts.com (you can also use searspartsdirect.com). This is the circuit board with all of the inputs on it (hdmi, cable, etc.) I opened it up, disconnected the old one, put in a new one and now it works fine.I used both serial numbers on the board to search for it online. It cost me $144 to do it, but that's better than $450 for a new TV. My tv is the vx32l hdtv10a. I hope that helps.
Jan 13, 2010 | Vizio VW42LF 42 in. LCD HDTV
Vizio GV47L not turning on after a pop noise
screen went black due to power supply failure. check also inverter.
May 30, 2009 | Vizio GV47LF Television
Vizio GV47L screen went black and is now unresponsive
Could be the power supply gone bad.
No easy solution I'm afraid.
May 20, 2009 | LG 47LC7DF 47 in. LCD HDTV
check your power board, most likely that's the part that is causing the problem.
Feb 09, 2009 | Vizio GV47LF Television
Vizio VO47L 47 in. LCD TV Logo
1,299 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
