Question about Troy Bilt 17 Inch 29 Cc Gas Powered Clutched Curve Shaft Trimmer #41ADT52C966
Electic scooter problem with head lamp
My headlamp bulb burns out immediately I replace it.
  • magron1 Aug 05, 2008
    When I replaced the bulb the light switch was in the on position. Could this have any bearing on it? I am thinking of trying again replacing the bulb while the light switch is in the off position. All the other lights on the scooter work normally.The battery pack in the scooter generates 36 volts. Perhaps I am using the wrong bulb.It is impossible to contact the manufacturer or to find any info in the owners manual for this problem.
  • 120 Answers
If you have a volt meter see how many volts are a the socket wires and get the correct bulb
Posted on Aug 16, 2008
Found the correct bulb.
Posted on Aug 06, 2008
How do I replace the headlamp bulb?
Hi, to get to the head light bulb you need to take the tiller head apart by removing the screws that go up from the bottom. The top will lift off but be careful not to pull any wires off. This will give you access to the lamp at the front. make sure you replace the bulb with the same type and voltage.
Jan 13, 2015 | Rascal 600 T Electric Scooter w Seat Lift...
Replacement of rascal 600t headlamp
Hi, To get to the head light bulb you need to take the tiller head apart by removing the screws that go up from the bottom. The top will lift off but be careful not to pull any wires off. This will give you access to the lamp at the front. Make sure you replace the bulb with the same type and voltage.
2004 Chevy Impala lowbeam headlamp socket/connector burns--though bulb is fine. Replaced once already and now same socket has burned again--and the bulb is still okay. What gives?
Hi Miles, Have you replaced the head lamp bulbs and maybe used a higher output? That can overheat the fuses and or the connectors. The over heating and damage will usually be caused by loose connections causing high resistance and heating. Make sure the connections are tight. Regards John
Dec 12, 2011 | 2004 Chevrolet Impala
I had a headlamp burn out so i bought a whole headlamp assembley and it has burnt out too. what do i look for now? and mine is a 2007g6
Hi, Why did you get a whole lamp assembly? All you need to replace is the bulb....If you have burnt out the connector on the back of the lamp assembly then you need to ensure the connector is replaced and when fitted back to the bulbs on the lamp assembly, make sure they are tight.
They burn out because the fittings are loose or the bulb wattage is to high and you need to drop the bulb wattage.
Hope this helped.
Jul 26, 2011 | 2005 Pontiac G6
Head lamp keeps burning out. replaced head lamp at
You either have a bad ground or the bad electrical connection at the light socket is "simulating" a bad ground. This is putting a high resistance on the bulb and it's taking it's toll by burning out the bulb. I would start with a new socket, and CHECK the ground. If you still have the issue, I would run another complete ground wire and not even worry about checking the ground itself. the Stick
Dec 10, 2009 | 2006 Suzuki Grand Vitara
Please tell me how to replace a burned out head light, high beam.
To replace the headlamp, turn signal, or parking lamp bulb:This information should be in your owner's manual.
Turn the wheel to access the wheel well.
  1. Remove the fasteners located on the wheel liner. To access the headlamp and the turn signal/parking lamp bulbs.
  2. Reach in behind the wheel well liner and locate the bulb to be changed.
  3. Turn the bulb socket counterclockwise and pull it straight out of the lamp assembly.
  4. Pull the old bulb straight out of the bulb socket.
  5. Push the new bulb straight into the bulb socket until it clicks.
  6. Push the bulb socket straight into the lamp assembly and turn it clockwise to lock it into place.
  7. Reinstall the wheel well liner using fasteners.
Nov 11, 2009 | 2006 Chevrolet HHR
How do you remove the head lamp assembly on a 1993
1. Make sure headlamp is off and open hood.
2. Taurus model years 1990-1999: you must remove the whole headlamp to replace the bulb. Not a horrible task. Just annoying.
3. Facing the driver's side headlamp, and looking at the headlamp itself, at clock positions 8, 11 and 1 are the headlight housing screws. They all look the same. Using a 10mm socket wrench, remove these 3 screws and set them aside.
4. Just to the right of the "11 o'clock" housing screw is a bolt (same hexagonal 10mm sized top as the housing screws). This just needs a few turns to loosen it.
5. Gently pull the whole headlight forward. Now you can get at the bulb.
6. Disconnect the electrical connector from the bulb. Now the headlamp is free to work with. Remove the bulb, replace with a new bulb, make sure the bulb housing cylinder is in place and reconnect the electical.
7. Place headlamp back into position. Line up screw holes. Tighten the bolt. Replace housing screws and tighten.
8. Passenger side headlamp is mirror image of driver's side. Screws at 11, 1 and 4 o'clock positions. Bolt should be to the left of the "1 o'clock" housing screw.
Oct 12, 2009 | 1993 Ford Taurus
Low beam of one headlamp not working. Do I need new bulb or other possible cause? 50cc chinese scooter. thx!
With all bulbs on this lamp being LED the fault has to be the individual bulb. Unfortunately these are not repairable or replacable. Is the lamp still within warranty? If so I'd get it back to BD.
Hope this helps..
Aug 14, 2009 | Black Diamond Icon Headlamp
I have 2006 Grand Prix How do I change head lamp?
Caution Halogen bulbs contain gas under pressure. Handling a bulb improperly could cause it to shatter into flying glass fragments. To help avoid personal injury:
Turn off the lamp switch and allow the bulb to cool before changing the bulb.
Leave the lamp switch OFF until the bulb change is complete. Always wear eye protection when changing a halogen bulb. Handle the bulb only by its base. Avoid touching the glass. Keep dirt and moisture off the bulb. Properly dispose of the used bulb. Keep halogen bulbs out of the reach of children.
Raise the hood.
Remove the headlamp assembly bolts from the upper fascia support.
Slide the headlamp assembly outward enough to release the headlamp bracket tabs from the slots in the upper fascia support.
Position the headlamp assembly away from the vehicle body to access the electrical connector.
Disconnect the electrical connector from the headlamp assembly.
Remove the headlamp assembly from the vehicle.
Disconnect the electrical connector from the headlamp bulb/socket.
Remove the headlamp bulb/socket retainer ring from the headlamp, by turning counterclockwise.
Remove the headlamp bulb/socket from the headlamp assembly.
Jun 13, 2009 | 2006 Pontiac Grand Prix
Electical problem on my electric scooter
You may have shorter the bulb when installing with pwr on. Try it again and make sure you do not touch the bulb with your bear hands as the oils in your hands will contaminate the bulb and cause it to fail early.
Aug 05, 2008 | Electrical Supplies
Troy Bilt 17 Inch 29 Cc Gas Powered Clutched Curve Shaft Trimmer #41ADT52C966 Logo
70 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
