I cannot install my hp6400 all in one with windows 7 - it says OS not compatible?
  • 196 Answers
Here is your printer & scanner full feature HP Officejet Full Feature Software and Driver click here size about 250MB
here is your printer & scanner less HP Officejet Basic Print and Scan Driver drivers only click here size about 250MB
do write a review?? if it helps
Posted on Apr 04, 2011
    Problem Solver:
  • 12 Answers
Kindly have a compatibility check before going for installation
http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx
CanoScan 8000F Installation for Windows 8.1
Unfortunately, the Canon 8000F is not compatible with Windows 8.1. You can find this at http://www.microsoft.com/en-us/windows/compatibility/CompatCenter/ProductViewerWithDefaultFilters?TempOsid=Windows%208.1&Locale=en-us&Architecture=X64&TextSearch=CanoScan%2B8000F&Type=Both&CurrentPage=0&TotalPages=1&ShowCriteria=0&SortCriteria=Relevance&Compatibility=Unknown&LastRequested=14. Canon choose not to write a Windows 8 or 8.1 driver for this scanner. The changes between Windows 7 and 8 mean that the old driver won't work. The compatibility mode doesn't help in this case.
You have two choices: The cheapest option (if you buy a used machine): You can get a second computer with Windows 7 or an older version of Windows installed that does support the Canon 8000F. Alternatively, with a computer with more than 4GB of memory and a CPU that supports can support a virtual OS to buy 1) an upgrade to Windows 8.1 Pro and 2) a Windows 7 license and DVD. (This will cost at around $200 for Windows 7 Home Premium and the upgrade.) Then you can add the Hyper V feature and install Windows 7 as a virtual OS with at least 2 GB of your memory assigned to virtual OS. Install the scanner in that virtual computer.
I hope this helps.
Mar 06, 2014 | Canon CanoScan 8000F Flatbed Scanner
Ultimate Writing and Creativity Center isn't compatible with windows 7.
  1. You can run the software in compatibility mode. Read about that in the Windows 7 help file.
  2. If your copy Windows is authentic you may want to install Microsoft Virtual PC and XP Mode if they are still available on the Microsoft web site. Note that your hardware must be able to handle Virtualisation, and that feature is enabled in the BIOS.
  3. OR get a version that is compatible with Windows 7 32bits or Windows 7 64 bits (whichever you are running).
  4. OR install an OS that is compatible with your Writing Software.software. The last suggestion is done in jest.
Dec 14, 2013 | Computers & Internet
Cannot install MGI PhotoSuite4 on a computer running Windows 7 OS
The PhotoSuite 4 program is very old and won't work under Windows 7. http://sonic.net/mnitepub/pccafe/reviews/photosuite4/photosuite4.html says that the version 4 Platinum edition ran under Win95-Win2000 versions of the Windows OS. Thus even the compatibility mode probably won't help under Windows 7 32-bit. You can try it though by right clicking on the installer and then selecting Properties. In the Compatibility Mode tab, select Always Run this program in the compatibility mode and an older version of Windows. Then right click again and choose Run as Administrator. (You may have to do this again on the program itself.) Since Win7 64-bit requires signed drivers or programs, it is not as likely to work. (Check your version of Windows 7 by clicking Start > Control Panel > System and Security > System. If the title of your OS ends with x64, you have the 64-bit OS. Otherwise, you have the 32-bit OS.)
If you have Windows 7 Pro or Ultimate (or upgrade to one of those versions), you can run a virtual version of XP for free. Download and install Microsoft's Virtual PC and then XP mode (in order). This works best if your CPU supports virtualization and you enable the feature in your computer's BIOS. (There are work-arounds for computers without virtualization. See the MS support pages.) Install your PhotoSuite inside the virtual XP program in that case.This old software may run in that case. (However, I've had some Win2K software that ran under XP with the compatibility mode but didn't run under the virtual XP. Note: virtual computers do have some additional limitations. They do not talk to the host hard drive and other hardware directly. (You can install a printer on the host machine or the virtual machine but not both.) You'll need to save files on external media (flash drive, optical disc or other hard drive) to transfer them between the machines).
Another option is to run an older version of Windows on another computer, as a dual boot computer or with Virtual PC (or another virtual computer package - VMWare or Parallels). In that case, you need a licensed version of the older Windows OS. Again install the program while running the older OS.
The final option is to upgrade to a Windows 7 compatible Photo editor and organizer. (Even the Microsoft Windows Live Photo Gallery has some of the features of Photosuite SE.)
I hope this helps.
Mar 24, 2012 | MGI Software PhotoSuite SE V4.0
After installing Garmin 405 drivers on my new computer sync does'nt work, no device found
May nt be compatible with your new OS ...Check the Windows 7 Hardware Compatibility List for full details and more information. Search Windows 7 Compatibility to find the list. You can also check Vista, XP and other OS from there.
Thanks for your question this morning ...
Jun 11, 2011 | GPS
Unable to install Print Shop verison 11 on my Window 7, why?
Print Shop Pro Publisher version 11 was built for Platform OS: Windows 98 / Me / 95. It is an old software which is not for Windows 7(x86 or x64) OS. This is due to software compatibility issues with Windows 7 ie an old software running on a newer OS Platform.
You have to get a newer version which is compatible with Win 7.
Hope it helps.
Mar 11, 2011 | Broderbund Print Shop Pro Publisher 11
SPECIAL EDITION SCRATCHES won't play on my windows 7 laptop. Chris
i think the problem is with compatibility with your OS. first, u need to check that your windows 7 is installed with 32bits or 64bits system. second, check your game compatibility (is it compatible with 32bits, 64bits, or both. if your OS installed with 64bit then your game only compatible with 32bits so the game will not work, and the contrary.
my opinion (probably wrong):
maybe your win 7 is installed with 64bits and your game only support 32bits system, so you need get another 'scratches' game that support 64bits. another solution (worst scenario), try to installing your win 7 with new win 7 with 32bits system.:)
Feb 17, 2011 | Computers & Internet
Is the deskjet 656c series compatible with windows 7 OS?? if not, can i use the vista installer instead?? many tnx..
Yes it's compatible with windows 7. Click here Click on above link select your os windows 7 32 bit or 64 bit then download driver and install. Let me know if you need further assistance. Thanks for using FixYa.
Feb 14, 2011 | HP DeskJet 656c InkJet Printer
F5d5050 Belkin USB 10/100 Ethernet Adaptor - Does it work with Windows 7 64 bit OS? I have spent hours trying to install a Swann and a Digitech product but none seem to work with the above OS. Any...
You cannot install this adapter in a Win 7 computer because the drivers are not compatible with Win 7.
So far Belkin haven't updated the drivers for win 7 OS. The latest drivers for this adapter is compatible only with
" Windows 98SE, Windows Me, Windows 2000, Windows XP 32-bit, Windows Vista 32-bit "
Click here to see the belkin compatible drivers in the website.
With Regards,
Prema.
Jan 06, 2011 | Belkin Ethernet Adapter F5D5050 Network...
I have Vista OS on my laptop & have never been able to get automatic updates to work. I have had nothing but problems with this OS & want to instal Win 7 but I am told I can't do that until I see...
Don't worry about "compatibility" issues. You can pretty much force Win 7 onto just about any laptop.
What you need to do is backup your files (that is if you have any you want saved)
You need to do a CLEAN install, not the UPGRADE when you boot from the Windows 7 cd.
Delete ALL of the partitions...then hit NEXT.
When it's done installing, run the updates and if you're missing any drivers after the updates post back the model of your laptop / desktop and we'll help you patch the missing ones.
Best of luck!
Jan 02, 2011 | Microsoft Computers & Internet
Call of Duty 2 won't install on my Windows 7 computer
Call of Duty 2 compatibility issues with win 7 OS, it is not compatible with your OS. Read the link below,
http://www.bit-tech.net/gaming/pc/2009/10/22/windows-7-games-compatibility-testing/2
Hopes it helps.
Sep 28, 2010 | Computers & Internet
Computers & Internet Logo
94 people viewed this question
David Payne
David Payne
